watchnerd
Now back up and available:
https://drop.com/buy/massdrop-x-edd...55522.517902514705881161542451&referer=8Y8N8D
SPECS
I have no idea if it's any good. Looks okay, but not amazing. Price isn't god awful.
SPECS
- Massdrop x Eddie Current
- Frequency range: 10 Hz–30 kHz (+/- 1 dB)
- Noise: -90 dB
- Gain: 12 dB
- Dynamic range (under a load of 24–600 ohms): 87 dB
- THD: < 1%
- Input voltage: 0.25–2 V
- Tubes: 2 x NOS Russian 6ZH1P, 2 x 6N24P
- Transformer output: "Ш-iron" M6
- Headphone outputs: 2 x ¼ in (6.3 mm)
- Low-impedance output: 32–100 ohms
- High-impedance output: 100–600 ohms
- Power supply: Built-in, IEC cable
- Input: RCA
- Pass-through output: RCA
- Chassis: Black painted steel
- Faceplate: Staron
- Dimensions, W x H x D: 6.3 x 4.3 x 8.7 in (16 x 11 x 22 cm)
- Product weight: 4.4 lbs (2 kg)
- Packaged weight: 6.8 lbs (3.1 kg)
