Zoomer
- Joined
- Oct 5, 2019
- Messages
- 323
- Likes
- 468
XLR/TRS combi jacks
Nice touch!
Will they be for sale in Europe through Purite?
XLR/TRS combi jacks
Yes, sending Keith his first pair next weekNice touch!
Very nice. I take it that touch switch power control means that this uses a relay? Looks nice and compact but what are the dimensions? One more question: do you have the cases made locally or abroad?Hi
Our P451 Purifi MonoBlocks are now ready, will be on the website this weekend.
They follow the form of all our amplifiers, compact enclosure milled from aluminium block with tough anodised finish.
Features:
Piccies
- OPA1632 based fully differential input buffer with very low noise LT3045/94 voltage regulators. These are particularly suited for regulating the SMPS output as they have high PSRR at high frequencies where most of the SMPS noise resides. These also feed the analogue sections on the 1ET400A module.
- Separate regulated supply for the 1ET400A digital section (for info its actually missing on the prototype board shown below).
- Solid copper ETI Research speaker binding posts.
- Balanced XLR inputs (XLR/TRS combi jacks) also fully compatible with single ended RCA with adaptor cable.
- Audio input RF filter
- Touch switch power control
- Mogami balanced signal cable
- Speaker cable tightly twisted
- Mains input booted, cabling twisted, double insulated and routed away from speaker/signal wiring/boards as far as practicable.
- Power Supply is significantly over specified for a single channel amp.
- All the lovely Purifi technical performance and sound
Just for info the bottom plate actually fits the other way round (psu to front) in the top shell.
It toggles the main SMPS, part of its control logic. The main SMPS does have a relay.Very nice. I take it that touch switch power control means that this uses a relay? Looks nice and compact but what are the dimensions? One more question: do you have the cases made locally or abroad?
Clean and neat!
Will there be a stereo version?
Eventually, it will require a new case.
It is because you need 2 monos, put them side by side and they look squarish.Oh, that is a great news for me!
I found the current case's width-depth ratio quite odd.
A more squareish case would look better in my opinion. Looking forward to its release.
Thanks.
Nice. But my one significant concern is the connection for getting the output off the board!Thanks
Yes, fairly big but they allow for good access for large CSA cable and large spades. Plus bananas of course.
Missing from my wish list: 12V trigger in (not out).Hi
Features:
Where are you seeing this? Looks IEC C13 to me.20A IEC
Rectangular shape, looks like 20A to me.Where are you seeing this? Looks IEC C13 to me.
One big advantage of mono amps is that you can put them really close to, or hidden behind, the speakers and use really short speaker cables.It is because you need 2 monos, put them side by side and they look squarish.
Or the source/preamp in the middle and each of them on the sides, also looks good.
Clearly not @solderdude , what were you thinking? The soldering is in a whole other league of excellence.
IEC C20 has horizontal pins. <https://en.wikipedia.org/wiki/IEC_60320>Rectangular shape, looks like 20A to me.
Sorry I didn't reply about the dimensions:Very nice. I take it that touch switch power control means that this uses a relay? Looks nice and compact but what are the dimensions? One more question: do you have the cases made locally or abroad?
