- Joined
- May 25, 2019
- Messages
- 158
- Likes
- 218
I actually use Ubuntu as daily driver. For clarification, I mean turn the digital volume down on bit perfect modeOf course you can, just give it a try on a Linux live distro.
Well, turning the digital volume down means to lose bits, so not sure if this is bitperfect or not. What's important is by lowering the volume to not decrease DAC's SINAD lower than it's default value (probably any figure between 18 to 20 bits should do).
On what basis? Can you explain your concern?Question. If there's no volume knob... can you use bitperfect audio? Say in Windows or Linux.
Not using BP audio would be a no go for me...
If the noise doesn't gets attenuation you lose snr. It doesn't matter if it's 24bit or 64bit digital volume control.32 or 64 bit volume control does not lose any resolution.
It certainly is protected. It will be in the manual (along with a note about "super duper" alternate power supplies not doing anything beneficial). I know you will probably find a dozen examples but do many bits of kit these days have neg on centre pin?Oooh, I like it!
One thing. There is no polarity symbol on the 2.1/2.5mm DC jack. I'm hoping there's a diode to protect it, or a full wave bridge so it doesn't matter...
NotedIt needs better looking lock-ring washer.
No, I agree. Thank goodness most 'sensible' manufacturers have standarised on centre pin positive.
But you know consumers, if they can f#$k it up, they will.
As for the nut, I quite like it. It's convex, chromed and looks the goods. Sure, you can have some scalloped, fluted, gold plated fiasco, but it's purely a mechanical mount and a hex nut does it well.
just the photo, my very amateur quick snapLooks good to me (is the lettering on the dac much bolder or is that just the photo?)
