Marantz SR8015 Review (Home Theater AVR)
You can replace your gear with AV10 pre-processor and Dan D'Agostino power amps all around and you will still have bad sound with the current position of your subs and speakers running a bad DSP.
Hi OCA,
Can you clarify. Not sure what photo you saw but this is my setup currently. I have moved the sub locations a number of times. this seems to work the best. I had the subs inside the towers and had the right sub moved onto several locations on the right wall basically 90 degrees to its current location. I also put one sub in the back of the room and left one sub in the front. And I have also played with taking the subs out of phase by 90 or 180° depending on where I had put the subwoofer, using the Martin Logan app. I have also run ARC correction and then the Denon room correction. The sound and feel of the base currently seems to be the best with the subs in this location. Would you have any other recommendations on set up? The sound is good I'm just always looking to improve.
Please look at post 377, I attached a photo there.
Thanks
Hi OCA,
Thanks
I had not seen the set up, was just talking in general about the power of DSP in terms of sound quality.
Your current placement is impressively symmetric and that's a very good start. There'll be too much bass because everything is too close to walls and corners but that's not a problem with DSP otherwise bringing them all a bit forward in the room would sound better. Try A1 Evo Acoustix with your Denon. It's free, cross platform and uses the bundled Audyssey mic for its measurements. Just run the "Express workflow" for now. The whole process takes about 10 minutes from start to finish including measurements, optimization and filter transfer to your 8015 - all automated. I believe you will change your mind about your system needing upgrades.
Thanks for the reply. I do not have an 8015. I did have one in my old system. I was looking at a used one to upgrade from my Denon 4800H and wanted to know how to tell which units had the better DAC's. As I said I have moved the subs a number of times. I do like them in the corners because they have a stronger response. They are 12's and I would like a pair of 15" or 18" but the wife is fighting it. We do 70% moves and maybe 30 percent music. I have just ordered an apple TV to get Hi Res music into the AVR from apple music. Again hoping this will improve the sound but we will see, I would also like to hear Hi Res Atmos music. I will look at your software. When watching Movies I run the subs at about 52-56 in the Martin logan app. When I listen to music I turn the subs down to about 34 in the app. When I calibrated with Anthem Room Correction software first then used the Audyssey correction the Audyssey took out 2.5 and 3.5db on the subs because of being in the corners. Can't remember the number when I had the subs inside the towers but the -DB was lower. I think I may get away with the SVS R 5000 or the Martin Logan Grotto 12 as these are only a couple inches bigger in H,W. I will also be looking at your software. Below is a couple shots of the ARC software curve before and after. I combined 6 measurements in different locations to get the final graph.
Thanks
Thanks
Audyssey leaves a lot on the table and from what I hear ARC is not much better, either. A1X works with all Denon & Marantz AVRs.
You can use this tool to decide where to place the subs in your room. It can work with irregular room shapes:
It doesn't take into consideration front mains crossover frequency or speaker/sub pass filter slopes or move subs automatically to the best position in the room. For these you will need Evo 32.
Thanks
I would suggest you try OCA's. Audyssey is fine imo, but if you really want to see pretty REW curves you have to spend a lot of time using the $20 app and learn how to use it to get the best possible results, or use the $200 app to achieve the same but takes much less time and easier learning curve. To me, it is not worth spending $200 on the MultEQ X app. As to ARC, I have yet to see objective measurements to prove it is as effective as Audyssey, in my experience, it may be able to achieve as good result as using Audyssey without using the app to tweak, and I am being generous. AARC fans can say whatever they want/believe, it is subjective so......., to me, it does no harm and is included but for good objective results, stick with Audyssey and/or OCA's freeware.
I would suggest you try OCA's. Audyssey is fine imo, but if you really want to see pretty REW curves you have spent a lot of time using the $20 app and learn how to use it to get the best possible results, or use the $200 app to achieve the same but takes much less time and easier learning curve.
The $20 Editor app is worth it's cost for the one click switch to toggle off the Midrange Compensation dip alone. If you want to do some serious eq curve tweaking there can be a bit of a learning but combined with the free REW app and a Umik it is capable of excellent results at a low cost.
OTH OCA can supply a very easily learned app also suppling excellent results.
The REW app + the $100 Umik are mostly required for best results. ;)
