Vasr
- Joined
- Jun 27, 2020
- Messages
- 1,409
- Likes
- 1,926
No problem. You have been great help. While you are at it, having the files at twice the length would be useful. They are too short at 5 seconds.
Ok second attempt. Problem was in exporting it with default signed 16 bit pcm encoding rather than with 32 bit float. I have verified the noise floor. The 1khz tone in L and R falls off to -120db or less on both sides full spectrum. The silent channels will have no detectable noise (i.e., instrumentation floor).
I have also included both Dolby Digital (ac3) encoding at 448kbps and DTS encoding at 1411kbps for 5.1 with 4 channels silent. It is a lossy encoding so there will be some artifacts but should be minimal for measuring relative results between the two speaker settings.
Have also doubled the size to roughly 11 sec total.
