It appears you agree with all of what Rich says based on your free use of his name with no supporting analysis. That is a mistake.
I mentioned his name when I quoted him, that's just out of respect. I thought it is common courtesy to not just quote but also provide a link to the source. I would do the same if I have something to say about something in your post I would quote what you wrote too, in this case I have to copy/paste because of the way you place the "QUOTE" sign, perhaps you can edit it. I am not sure if I agree with "all" of what he said either.
Just in the AV8805 review and the associated discussion of NJR and Rohm volume controls:.
Rich says the D to A, L and R channels go directly to the NRJ volume control. This isn't true, first the the L&R go through an NJR CMOS switch. In addition after the NJR volume control the L&R and all other channels go through another NJR switch. Rich seems unable to understand the analog audio diagram in the service manual that he says is in his possession, and is widely available, but he wants to keep it a secret. Use of a switch/volume control combination appears to add significant distortion vs. the volume control alone. Rich appears to not understand this situation.
First of all, he did not say that in the review article of the AV8805. Now that you mentioned it, I clicked on the link he provided in the review to another article (AVR build quality Part V) and found a block diagram and
he said "As can be see from the above figure, the switch in the volume chip (NJU72343) brings the DAC in direct. "
Is that what you referred to? If it is, I think he wasn't talking about the circuitry of the AV8805, he seemed to be suggesting one way of routing the signal. In that beginning of that paragraph he said
"If you want to build a 7.1 AVR you need just two of the New Japan Radio chips. It is medium-scale integration (MSI) that makes this possible. Just as the name sounds, an MSI chip has more transistors than an SSI chip but a lot less than an LSI chip which in turn has a tiny amount of transistors compared to today’s VLSI (Very Large Scale Integrated circuit) chips."
Link to that article:
https://hometheaterhifi.com/technic...vr-audio-video-reciever-build-quality-part-v/
Rich says the HDAM's may be responsible for the increased distortion seen in the AV8805 measurement when the output is increased from 2V to 4V, implying nothing else has changed. The HDAM's may contribute to added distortion, however the output increase is implemented by increasing the gain of the volume control in the measurements in the article.
Regarding his comments on the ... 2V to 4V ..., my interpretation is that he wanted to make the point that the distortion increase was not from the DAC. He never said the volume IC was not responsible for the THD increase and he was just making another point that the volume IC used in the 8805 compared to the LSI chip (he referred to as the AVR LSI chip Renesas LSI chips (R2A15220FP) used in the AV8801 and AV8802 pointed to 50% reduction in distortion. I could not fact check on this point as I don't have the datasheet of the R2A15220FP.
Evidently Rich believes the volume control contributes nothing to distortion.
He never said that in that review, if you saw something I didn't, I would appreciate a direct quote and link. All I could see in that review was that he tried to make the point that the DAC was not the source of added distortion, and that he expected a reduction in distortion from the new volume IC, that was not there based on the test measurements. So he suspect may be the HDAM is somehow the reason why the expected reduction of distortion was not seen, but then again he never said the HDAM was the source, he said "It is possible ...." He said that in the linked review below, in the paragraph near the end but before the conclusions.
https://hometheaterhifi.com/reviews/receiver-processor/processors/marantz-av8805-processor-review/
Even with a PHD, Rich evidently didn't learn that it is best to vary only one item at a time in a experiment. Rich posted the volume control/switch distortion vs. output characteristics in the associated volume control article (without crediting the source, poor form for a PHD...), but evidently didn't understand what he was posting, or ignored it, or who knows what. Changing the volume control out from 1V output to 2V output, appears to definitely increase distortion, increasing the gain can only add to this increase in distortion.
I don't doubt Dr. Rich's credential, no reason to, but I also have no doubt he can be wrong too, don't we all? As to increasing volume control to output from 1 V to 2 V, of course he knows distortion would increase, but it
seems you missed the point that he was comparing the new MSI volume control IC to the Renesas LSI IC used in the AV8802. I suggest you re-read the review before making judgment.
Again, you again nothing at best, by giving Rich as a source. It is best to critically analyze whatever he writes, as with about anything else on the Internet.
How do you know I have not done so? That's beside the point though, how many and how often forum members do such a thing and I don't think ASR members are expected to do critical analysis on things they quote though again I do agree it is good practice to include links to the sources. I did read about the author's audio electronics background, before I have ever quotes or link his articles. If anyone is interested, please follow the link.
https://hometheaterhifi.com/author/drich/
I like the fact that you get into the technical details but in this case I think you might have misunderstood certain things Dr. Rich wrote in his review on the AV8805. I tried my best to list my own interpretation above, but as they say ymmv.
By the way, on another topic, I asked you more than once about how we should interpret the tolerance specs of the THD of the Rohm chip, or the NJU volume control chip and provided links to the data sheet before.
The partial table below is from the Rohm BD34703 KS2 datasheet
Source:
https://www.datasheets360.com/pdf/-5225953889880620514
My main question is, THD from Typ 0.0004 to Max 0.02% 400-30 kHz, so does it mean one could
(probability could be very low, I assume) end up with an AVR that would have a chip with as much as 0.02% THD, that would be -74 dB and if for example, ASR happened to measure this AVR, say the RX-A3070, there would be uproar on the SINAD results. I am pretty sure I misunderstood the spec but please enlighten me.
I ask for your comments, or expert opinion, because I have the impression that you are very knowledgeable in this field. I did try to get an answer from manufacturer's customer service and received no response whatsoever.
If you don't want to answer my question or offer your opinion on this for whatever reasons, I would obviously have to respect that and would not bother you again on the same.
Thank you.
