Such speculation sounded convincing, but apparently has just been shot down by Marantz themselves, perhaps inadvertently, now that we know the SR8015 is capable of near 100 dB SINAD too, whatever they might have done to the 2020 HDAMs. Last time they revised HDAMs was when they launched the AV8802A, SR7009 so that was about 6 years ago. Regardless, if distortion is so low, lower than 0.001% in total, then where are the magical warm sounding harmonics? Nothing apparent in the FFTs either if you compared models prior to 2020. In fact, if anything, the often referred to as warm sounding 2nd harmonics was a little higher in proportion as shown in Denon's FFT!!
Again, all that shouldn't matter at such low level of "total" harmonic distortions. And as I mentioned before, if they had found the HDAM magic, then why not include them n the slimline series? If cost is the reason, then they should have made it clear that the so called "better for music" deal would apply to the non slimline series only.. Bottom line, what they said in that video, if true, would defy logic..
Sound United SR8015 Measurements
There is no obvious indication of how Marantz made the measurements of the SR8015. It is also not clear if the measured unit is representative of production units. It is also not clear which channel was used for measurement. Based on the SR88012 the DA-height channels likely would provide the best measurements. Use of balanced AC power would also likely help reduce the noise levels . Based on the X6700H; don't trust and verify.
Unfortunately we will still likely be
blessed with the non-standard reconstruction filter with no other choices.
Hopefully Marantz used the same measurement setup that Amir uses and the SR8015 will measure similarly when Amir has one inhouse. The ultimate Denon measurements have been good news. It would also be good news if the AV7706 shows better performance since it would provide a higher performing unit with balanced outputs.
HDAM's
The HDAM's in the AV8801, AV8802 and AV8805 are the same. The HDAM's in these units are four transistor circuits with two resistor current sources and +/-12V power supplies.
The preamp outputs of the various units are:
AV8801: opamp,
HDAM, bi-polar transistor common emitter voltage gain stage, opamp, opamp. An additional opamp implements the other half of the XLR output.
AV8802(a) and AV8805:
HDAM, common emitter voltage gain stage,
HDAM. An addition circuit with
HDAM, common emitter gain stage,
HDAM,
HDAM is used to implement the other half of the XLR output with what appears to be voltage and not current feedback.
Marantz has used higher performance HDAM's with transistor-based current sources in other products, but the lowest level HDAM circuits used in the AV880X series has not changed over the years.
HDAM circuits in the Marantz AVR's have been the same as in the AVP's for the SE output, except that +/- 7V power supplies have been used. These lower voltages in turn provide worse resistor-based current sources. The lower power supply voltage also doesn't allow headroom for the modest, first-order RC filter used in the AVP units The power supplies for the HDAM's are also less robust in these units.
Here is the (+) HDAM-based output stage of the AV8805 that was previously posted on AVS:
Note the four transistor HDAM circuit, then the two CE transistor stages and then another four transistor HDAM circuit. Resistors R4005, R4006. R4017 and 4018 are the resistor-based current sources.
Here are three alternative HDAM designs. The left design has transistor-based current sources, for example, Q5 plus associated diodes and a resistor form a current source. Naming of HDAM's is not consistent. At times the HDAM's in the AV-8805 have been called SA's. Clearly the HDAM's in the AV-8805 are not the same as the SA HDAM below.
