jmz
Did anyone here investigated the problem?
Marantz PM6006 UK (and other models) buzzing noise digital inputs. This is also happening with PM6006 and PM6007.
Some amplifiers are more affected and some less.
My PM6006 UK Edition have the problem but... I can hear this buzzing noise on any digital input only when volume is set above 9 hour position. Is easier to spot it when using headphones. But is hard to hear it when using speakers.
I got second PM6006 UK today from ebay and this one is much worse regarding this problem. The buzzing is easy to hear even if volume is set to ZERO level and is very loud when using headphones.
I can also hear it when using speakers.
Some links for people who didn't know about the problem
tdcat.com
forums.whathifi.com
Marantz PM6006 - Digital Input Noise — tdcat.com
My reasons for returning the Marantz PM6006 twice.
Marantz PM6006 DAC noise using TosLink / digital / optical
Hello, I've just bought a Marantz PM6006 integrated amp and a pair of B&W 685 s2. Today, I noticed there is a buzzing noise when using the optical connections (to my computer). Here's the situation: 1. This buzzing noise is exactly like that emitted by fluorescent lights. It's not the white...
Buzz/Humm through optical port
Hi Guys, i have a Chinese android box (Wechip) that i was using to cast music to via airplay to my Marantz PM6006 via optical out. When the audio is off and you turn it up a bit there is a slight humming/buzzing noise along with the standard speaker hiss that is normal for the speakers and amp...
audiokarma.org
