I’m building new home theater, beginning to think a Sonos Arc system is way to go then a nice dedicated 2.1 for music. Not sure I want to chase multichannel perfection.
Well not being able to use a complex AV system with its 5 or 6 different remotes is just not manly. It’s like a fella not knowing how to change a tire on his own car. Pretty wimpy.A buddy of mine went the separates way many years ago (at my insistence, as he was building a new house and wanted the best of everything), hated the system because he couldn't turn it on or do anything easily so boxed it all up and has had sound bars ever since. Last year he bought the best Sonos Arc soundbar, the sub and I gave him 2 wireless Sonos satellites for surround back duties and he loves it-he turns it on and it works. I have to admit it sounds pretty good for a sound bar + sub + 2 satellites.
I seriously doubt that ≈30 dB lower THD of the analogue amp that you see at 5W is due to model differences. The analogue amp output THD of Amirs result follow the pre out results. The THD I see from pre out is lower than -90 dB. Both your and my result points towards ≈30 dB lower THD than what Amir measures.@amirm, it’s a big regression in performance from the NR1608 that I measured a while back. I don't see my DAC measurements, but at least these are the analog amplifier measurements.
Note the frequency of the THD+N going from 20 to 88.2 kHz not your usual 20 kHz.
This is a Google Search for the internals of a NR1608. The brown capacitor on the left next to the power supply is bigger than the one on the NR1510. The WiFi module on the older unit is at the upper right on the NR1608 as opposed to the center on the NR1510. May being further away from the amplification circuitry helps. The wires coming off the power supply are twisted on the NR1608 but not on the NR1510. I wonder if those small changes makes a difference or if there is something else. I would have expected the DAC performance to drop, but not the amplification portion!
VS
But then the counter to this.Nothing like having to now pay $800 for a $200 AVR. And I love the out of the box thinking of literally slapping an HDMI cable inside the unit to use as a board-to-board interconnect. And that nice twist ensures that the board connector will randomly pop off at some point for added good measure after you move it one day. Classy...
But, I think they are missing a business opportunity given it has literally as much distortion as a lot of tube amps. Just slap some cheap Chinese tubes with orange LEDs under them on top of the cabinet and it can be sold as the "audiophile" version for about $40,000.
I suspect that the licenses and associated legal costs for producing a modern AVR with the facilities of this one would result in a price over $200 US on their own.Nothing like having to now pay $800 for a $200 AVR. And I love the out of the box thinking of literally slapping an HDMI cable inside the unit to use as a board-to-board interconnect. And that nice twist ensures that the board connector will randomly pop off at some point for added good measure after you move it one day. Classy...
So I still think there is something wrong in Amirs measurements or that the unit is faulty. The resemblance of these slim line models are too high to give such large differences in distortion.
NR1510 is from 2019We have seen regression on the X3800H but this seems to be a pretty big drop.
NR1510 is from 2019
If CEC works well, it is one of the most convenient and easy to use interfaces.Well not being able to use a complex AV system with its 5 or 6 different remotes is just not manly. It’s like a fella not knowing how to change a tire on his own car. Pretty wimpy.
Seriously though there are other family members who don’t see AV as a hobby and just want the convenience of an appliance for their AV systems.
Seems boring to me but hey I had to write an instruction sheet for my ex just to use the TV or watch Netflix. I get it but I don’t respect it. Hahaha!
The new DAC seems perform worse and there seems to be a noise increase in the -5 to 0 dBfs as Amir measured. So there are issues but I still wonder about the THD.It’s possible. The 5 dB discrepancy between channels might reflect a broken unit. Still, if you look at something like the Anthem MRX520 or Arcam AVR10, it’s not completely out of the realm of possibility. Maybe the volume IC is part of the supply chain shortage? Alternatively, looking at the restored JBL SA-600, shipping damage could be an issue as well if the internal grounding had a failure. I missed your measurements — but until someone retests the NR1510, it will be hard to know.
@amirm, did Sound United/Masimo review these numbers or make any comment? We have seen regression on the X3800H but this seems to be a pretty big drop.
Obviously I was being a bit hyperbolic, but this is just a 5.1 system. In their desire to save money and slum it with a linear amp that still runs reasonably cool it has such bad performance that it might even be subjectively audible and produce more distortion than the speakers hooked to it at some frequencies. Even a lot of tube amps will have less distortion, and the DAC part alone would be marginal for a speaker amp. It’s not so much the $800 price tag, but the $800 price tag with the thing being built way down to a cost to pinch pennies. Granted we also have inflation, but at least it could have mediocre performance so it wont have the possibility of degrading the audio.But then the counter to this.
We test DACs and other stand alone items here that cost $200.00 and do just one thing.
So are you expecting one device to do 10 things (DACs, Room correction, Tuner, Remote control, Several amp channels etc) and cost what exactly?
Since it’s so marginal its possible the performance can be worse since here the amp is only being asked to drive a resistive load on the two front channels. With all the channels driven there will be more ripple as well as the complex and varying impedance of loudspeakers. Conceivably this could make the distortion numbers worse. It’s probably not audible, but it’s not leaving much margin with a broad spray of harmonics at relatively high levels. I’m not particularly picky about numbers but I do at least want some confidence it won’t have a possibility of being audible.Is it “subjectively audible” or not? If not, you can’t crticise the NR1510, other than for the numbers measured which are of questionable use if there is no perceptible degradation in sound quality.
I reason this way: the designers of the cd thought 96db signal would be sufficient. To play a file cleanly -as it is, without alteration- you need a greater sinad than the source material that it plays. Iirc that takes around 10 db headroom to have a drop of 0.5db sinad that you can measure at the output. So 106db sinad would be a minimum if it is your desire to transport the signal cleanly. I think that's where the ' high bar' of 115db sinad comes from. Then you'll know for sure the signal is unaltered.Is it “subjectively audible” or not? If not, you can’t crticise the NR1510, other than for the numbers measured which are of questionable use if there is no perceptible degradation in sound quality.
The audibility of noise is very dependent of how you design the test and type of music. The HF drop in level may be more of a concern as well as the THD. I know Amir sets the bar high, because there is no reason to set it low with the technology today.I reason this way: the designers of the cd thought 96db signal would be sufficient. To play a file cleanly -as it is, without alteration- you need a greater sinad than the source material that it plays. Iirc that takes around 10 db headroom to have a drop of 0.5db sinad that you can measure at the output. So 106db sinad would be a minimum if it is your desire to transport the signal cleanly. I think that's where the ' high bar' of 115db sinad comes from. Then you'll know for sure the signal is unaltered.
If this is audible or not very much depends on:
- the listener (how old is he/she, what is the state of his/her hearing)
- the speakers (the highest sources of distortion; for example are you playing through genelec 8351's or average hifi speakers costing a few hundred dollars ?)
- the room (high ceiling, width room, seating position closer to the speakers than back wall, speakers 0.5 to 1m free from the back wall)
So I would say, yes, for me this level of performance is very much a concern.
You must decide for yourself, but as a general recommendation this kind of performance will just not do.
If I interpret this graph correctly, it says: you cannot play cd sources cleanly, let alone blu-ray, because the signal to noise and distortion is lower than 13 bits (77 db), while cd requires 16 bits and blu-ray would ideally get 24 bits (iirc 140db). Still, as anything higher than 115db sinad is beyond our hearing, 115db would be the level to aim for.
