Fairly sure it does not!Fairly sure this has the TPA3255 inside, like the WiiM, quite good specs.
Right, I see multiple references to AX5689. It is bridged design, corresponding to the 4 big coils, two for each channel.Fairly sure it does not!
“The amp is a marriage of Axign's AX5689 digital Class D amplifier controller with the power stage from Texas Instruments' DRV8932 quad half-bridge driver chip.”
Marantz Model M1
With HEOS built-in, and support for numerous streaming services, Marantz's bijou Model M1 network-attached amplifier pulls off a blend of minimalism with supreme flexibility To some readers, the Model M1 might appear an unusual product to carry the Marantz moniker. After all, for the last few...hifinews.com
The Jbl is awful. The Matantz is getting good reviews. I'd be shocked. if it sounds 600 dollar better than the Wiim pro. However, I would love a more powerful wiim. It lacks just a little punch.I find it a bit strange that an expensive amplifier from such a powerful brand doesn't have features that allow us to better adjust the sound, like a room correction system and parametric equalizers. JBL released a 5.1 receiver for $599 that has room correction via a mobile app
In Brazil, I can have a M1 but can’t have a Wiim. They doesn’t sell here or Paraguay.The Jbl is awful. The Matantz is getting good reviews. I'd be shocked. if it sounds 600 dollar better than the Wiim pro. However, I would love a more powerful wiim. It lacks just a little punch.
Yes, the HEOS app is second rate. BubbleUPnP is versatile, it is third party which has some advantages, and the developer is very good at keeping it up to date and chasing down any bug. It is almost freee. It is not as pretty on your Android screen as other control apps, and some parts of its functionality do require you walk up a learning curve.The HEOS app is better than I remembered, but I still think that WiiM has the best app at the moment.
What you're describing actually sounds like a high noise floor in the DAC.I finally got a WiiM Amp Pro and a Marantz M1. I must say that I definitely prefer the M1’s sound to the Amp Pro’s sound. That being said, I do have an issue with the M1. When at low volume, I get a swirly hiss emitting from my speakers. The hiss is not audible at higher volumes, but I do find it to be a bit annoying at low volumes. The HEOS app is better than I remembered, but I still think that WiiM has the best app at the moment.
Another source of hiss is the connections. I had a hiss problem with a coaxial cable connection; it went away when I used the optical Toslink alternative to make the connection.What you're describing actually sounds like a high noise floor in the DAC.
Thanks for the info. I’ll have to look into this more.What you're describing actually sounds like a high noise floor in the DAC.
I have ruled out all cables as possible sources of the hiss.Another source of hiss is the connections. I had a hiss problem with a coaxial cable connection; it went away when I used the optical Toslink alternative to make the connection.
How is the Dolby Plus mode on the M1 with two speakers and movie's?I finally got a WiiM Amp Pro and a Marantz M1. I must say that I definitely prefer the M1’s sound to the Amp Pro’s sound. That being said, I do have an issue with the M1. When at low volume, I get a swirly hiss emitting from my speakers. The hiss is not audible at higher volumes, but I do find it to be a bit annoying at low volumes. The HEOS app is better than I remembered, but I still think that WiiM has the best app at the moment.
I very rarely watch movies, so I can’t comment on that. However, I am on my second M1, and I am still having issues with static, hiss, and intermittent pulsing. I have moved everything to different locations in my house and have tried different cables, speakers, and an AC filter. Unfortunately, nothing has helped. The WiiM, on the other hand, is working great. I am about ready to give up on the M1.How is the Dolby Plus mode on the M1 with two speakers and movie's?
I have the Denon Home Amp rather than the Marantz M1 (and no hiss). One thing to note about Dolby Digital Plus is that the LFE channel is not played through the subwoofer. Using any of the numerous videos that test Dolby Atmos/Digital produces silence with the LFE channel.How is the Dolby Plus mode on the M1 with two speakers and movie's?
Thats too bad. I am currently looking for an minimalistic alternative to a normal AVR, since the price of AVR's are still psychotic here in europe, so taking something like the M1 and giving me a "phantom" -like surround, might meet my needs since I am a movie fan.I very rarely watch movies, so I can’t comment on that. However, I am on my second M1, and I am still having issues with static, hiss, and intermittent pulsing. I have moved everything to different locations in my house and have tried different cables, speakers, and an AC filter. Unfortunately, nothing has helped. The WiiM, on the other hand, is working great. I am about ready to give up on the M1.
Ooo I have not heard about this one. How is the Digital Plus in movies? Do you get some kind of "surround effect"? When you say LFE, you mean Left channel and you don't get any Sub effects, correct?I have the Denon Home Amp rather than the Marantz M1 (and no hiss). One thing to note about Dolby Digital Plus is that the LFE channel is not played through the subwoofer. Using any of the numerous videos that test Dolby Atmos/Digital produces silence with the LFE channel.
There is a virtual mode that provides a surround effect.Ooo I have not heard about this one. How is the Digital Plus in movies? Do you get some kind of "surround effect"? When you say LFE, you mean Left channel and you don't get any Sub effects, correct?
Ok, understood. Thats too bad.There is a virtual mode that provides a surround effect.
LFE= low frequency effect (.1) channel. The LFE channel is not present on the amp, but the subwoofer plays the bass from the main channels below 80Hz or whatever the LPF setting. Confirmed by Denon support 'it does not support the LFE'. In that case, support for Dolby Digital Plus seems like a waste of time.
