@GXAlan Have you looked at the Denon one point Alpha demo disc tracks yourself on a range of players using a CRO/DSO?
I don't have an oscilloscope, and wouldn't be convinced that I am doing the assessment fairly. I'm relying on
@amirm's expertise.
I have looked at the demo tracks myself with digital audio software. The tracks match the description provided by Denon, so they aren't being fishy there. When I use software resampling, it doesn't look good.
This is Track #11 at 16/44.1 resampled to 32/176.4 kHz. It doesn't look like a sine wave.
While interesting, it really only tells you how that singe device works. There is no guarantee that the latest versions do the same.. or even anything at all.
Agree 100%. That's why I asked
@amirm to test the X3700 or X4700 as well to see if the latest versions still do the same thing (or anything at all). He does these tests out of interest, and he's very busy and secretive until test results are finished so I don’t know if he took the time to measure the Denon AVRs.
1 - If ALPHA doesn't work on the original designs, it's not worth wasting time on the AVRs.
2 - If ALPHA does work, then it is worth seeing if the latest "AL32" versions do the same or anything at all.
The original ALPHA makes sense because the PCM-63K and PCM-1702J are designed for external digital filter chips. The AKM DACs in AVRs are not designed this way, but potentially the algorithm can convert 16/44 to 24/88 or 24/172 intelligently.
