Thks for this interesting reply.Yes and no: Marantz usually give only the continuous power and in the marketing material they state it over 8ohm. So they are leaving something like 6db of crest. It is still possible that, esp. at 2ohm, they are power supply limited.
Apparently the best is Purifi in module amplification then hypex and ice(a bit harsh). Do you agree?
By the way by MA we have apparently a serious
manufacturer. He uses for the 1et9040ba with no usual hypex Alan March Says:![]()
P801 Mono-Block Power Amplifier – March Audio
The P801 is March Audios new flagship mono block power amplifier. Based on the new Purifi 1ET9040BA module, this simply elegant product is milled from solid aluminium with a tough anodized treatment. Exceptional fit, finish and build quality. Class leading technical and subjective audio...marchaudio.com
the power supply is a new design that has 2 quadrant operation and active synchronous rectification. This means the output voltage stays much more stable and won’t suffer from bus pumping. The PSU can also output more than 1500 watts which means it will power the Purifi 9040 to its full 2 ohm load capability.
Other manufacturers still use the outdated Hypex supplies which will only drive the Purifi 9040 module to around 1100 watts short term.
Is AM right?
You're talking about the latest Hypex PSUs Ncore X or NILAI? I suppose they are great yes. I've heard the elder Hypex nCore module in AVM monoblocs the great German Hifi company. Very pleasant. Dynamic great controlled.You're welcome.
I do not agree that the Hypex PSUs are outdated. But clearly they cannot provide the 9040 the juice it needs, because the 3K, for instance, has 63V or 85V outputs and that's too much for the 9040. Since the 9040 is full bridge it should not cause bus pumping in the PSU, hence active synchronous rectification is not needed. But it is nice to have.
The Link 10n looks beautiful but for a $12K preamp with subwoofer out, I am surprised it doesn’t have XLR out for the sub.I was able to listen to the Model 10 today and it's finally a Marantz to my taste. The new Link 10n will probably get Dirac Live and other devices with Purifi are also being planned.
I have not been able to find a better photo of the PCB, but these are probably the two SHARC DSPs:The new Link 10n will probably get Dirac Live
You don't know that and neither do I. Nothing has been tested yet and I cannot locate an SM-1000 review to compare. Maybe you can?
Purchasers of the Model 10 won't really care about the internal amplifier "modules" in isolation, they care about the rated performance of the entire product- from input to output.
Marantz is selling an integrated amplifier here. "Integrated" means input selection, control, volume, preamplification, power amplification and output switching. A Purifi module is NOT that. It is merely a component. A bit like comparing the specs of a D/A chip with the advertised specs of the completed product.
The fact being Marantz themselves don't seem to know the difference when they advertise it as the most powerful highest performing amplifier they've ever made...
Their claim:
It may well turn out to be extremely powerful. It will no doubt exceed its rated specifications. But will it be the most powerful Marantz ever? Consider the SM-1000 ran +/-100V main rails and had 16 output devices per channel, twin 800VA transformers (1 for each channel) and 4 x 20,000UF 125V main caps. The Purfi can swing a maximum of 90V. The maximum module voltage is supposedly +/-48V. Do the maths on peak power and tell me which one wins- the SM-1000 by a mile. It all comes down to regulation and device losses. The Purifi wins on losses, but loses on available swing in the first place.
Purifi's own spec sheet says the 9040 will do 750W@4R@1% which is ~55VRMS (+/-77.8Vpk). It hits the wall hard at 400W@8R. Maybe throw a few more volts at it for the Marantz Model 10 SMPS, I dunno- maybe they did.
I don't have an SM-1000 (wish I did) but bear in mind it's conservatively rated at 400wpc@8R. Into 4R it will be close and the 9040 would win with 2R. The new Model 10 will likely outperform the SM-1000 example I used with inherent THD.
Oops, big mistake, I mixed up with Marantz M1, which has tpa3255. Not sure what happened here, was I too drunk, or too sober ;-)
To my ears it was very very clean, absolutely zero noise or audible distortion. But some reason it left me completely cold. its hard to explain but like the resolution was too high and it did not benefit the mixes of tracks I know so very well. There was too much separation between different elements to the point where it affected the flow of the music. As I said, its hard to explain but maybe someone can catch the drift. This is all personal experience and don't take my word for it. Probably way too good for my taste.
www.audiosciencereview.com
What do you mean by too transparent? I can't imagine there is a way for something to be too transparent.
I think its pretty hard to fairly evaluate an amp when you are listening through speakers like those B+W:Went to listen to one today, was hooked to BW 803D4 and the new marantz streamer. Quite famieliar with the speakers as I run a pair of 804D4. I don't have much experience with thehigher end of D class amps, this was my first experience with such.To my ears it was very very clean, absolutely zero noise or audible distortion. But some reason it left me completely cold. its hard to explain but like the resolution was too high and it did not benefit the mixes of tracks I know so very well. There was too much separation between different elements to the point where it affected the flow of the music. As I said, its hard to explain but maybe someone can catch the drift. This is all personal experience and don't take my word for it. Probably way too good for my taste.
Who is going to pay $15,000 for an amplifier!!
