Marantz M1 Streaming Amplifier Review
Rate this streaming amplifier:
    Votes: 109 44.3%
    Votes: 108 43.9%
    Votes: 24 9.8%
    Votes: 5 2.0%
This is a review and detailed measurements of the Marantz M1 stereo streaming amplifier. It is on kind loan from a member and costs US $1000.
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital review.jpg
I used the Heos app to control the M1. It instantly recognized the unit and offered to upgrade it. But boy, did it take forever to do that with multiple reboots of the unit. On positive front, functionality is extensive which I won't cover here. Hardware connectivity is also quite rich:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital back pa...jpg
While I didn't play with it, you have nice features such as setting a high pass filter for the amplifier. There are also two filters available for the DAC but I could not find a description of which is which.
I forgot to check the unit last nigher after testing but this morning, while idle overnight, was warm.
Marantz M1 Amplifier Measurements
I started by setting the gain close to 25 dB with the volume control and then testing the RCA analog input:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio RCA measurement.png
This was very strange as the output would constantly vary as far as low frequency noise and the "grass" in higher frequencies, varrying the SINAD from 67 to 72! You could see the same during warm up:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio warm up measurement.png
First time I have seen this.
Fortunately, digital input in the form of either Toslink or network streaming eliminates this, turning in quite respective performance:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital measure...png
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio roon streaming measurem...png
All tests from here on are digital input.
Noise performance is good:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital SNR mea...png
As is Multitone results:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital Multito...png
19+20 kHz test though which shows ultrasonics, demonstrate massive noise shaping or some other source:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital 19 20 k...png
Frequency response is flat and good indicating likely class AB amplifier:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital frequen...png
It seems there is some kind of auto-scaling, causing more noise at very low output power:
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital Power 4...png
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital Max pea...png
Marantz M1 streaming amplifire DAC airplay roon DLNA Heos stereo audio Toslink digital Power 8...png
The aforementioned ultrasonic noise plays havoc with our wideband noise+distortion power measurements:
I performed another test with 22.4 kHz and it made things better but still fairly elevated noise floor.
The Marantz M1 gives me an impression of a product line which has emphasized functionality with constantly piling things into the box (hardware and software) resulting in what I consider bloated design. Hardware design has some bright spots but otherwise, shows fair amount of strange impairments. Shape as a cleaned up design could be quite nice. Then again the price is way up there relative to competition these days.
I marginally cannot recommend the Marantz M1.
Connections
Ethernet PortYes
USB-A Port1
USB-B PortNo
3.5mm InputNo
RCA InputYes
XLR InputNo
Phono InputNo
Optical Digital Input1
Coaxial Digital InputNo
HDMI InputeARC
Headphone JackNo
Subwoofer OutputMono-RCA
Wireless Features
BluetoothBuilt-in
Wi-Fi802.11ac
Wi-Fi Bands2.4, 5GHz
Audio Specs
Max. Digital Audio Bit Depth24-bit
Max. Digital Audio Sample Rate192 kHz
High-res Audio Playback
From NetworkYes
From USB Thumb Drive (USB-A)Yes
From Computer (USB-B)No
Ecosystems
Apple AirPlayYes
Apple AirPlay 2Yes
DTS Play-FiNo
Google Cast​
No
RoonReady
Sonos​
No
HEOSYes
MusicCastNo
SoundTouchNo
Bose Home SpeakerNo
WiSANo
BluOSNo
Music Services
Amazon MusicAmazon Music HD
Apple MusicNo
iHeart RadioYes
PandoraYes
QobuzConnect
SiriusXMYes
SpotifyConnect
TidalYes
TuneInYes
YouTube MusicNo
Control
Handheld RemoteNo
Control by appApple iOS, Android
Amazon AlexaOptional
Google AssistantOptional
Other Specs
Width (Inches)8.5625
Height (Inches)3.375
Depth (Inches)9.9375
Parts Warranty5 Years
Labor Warranty5 Years
Didn't the O-Noorus D3 Pro at $249 have a comparable feature set and do just about as well with the measurements as this guy? And take up less room as well?
As always, thanks for your fine review, Amir.
I was curious so I opened up the Wiim Amp Ultra review and scrolled through both reviews at the same time. At basically every stage, the Wiim was better, despite being half the price.
Unless I'm missing something, how can the M1 even survive (other than ignorance of Wiim's existence)?
Thanks for the review!
Wow, the Marantz M1 performs significantly worse than the SMSL VMV A2 (or Sabaj A30a) in terms of measurements and performance.
Considering the potential of the Axigns AX5689 chip, Marantz really messed up.
Thank You, @amirm,
How does a company that gave us the WXA-50 did not learn anything in the intervening years?
What a shame for Yamaha' namesake!:(
A shame, yes, but, it's a Marantz ;)
While there are certain parts of the performance that are very bad, there are actually many pleasant surprises to the performance too.
I'm impressed that this amp can do 100W at 8 ohm. It has no load dependency, and the distortion performance, especially in the HF, is much better than the TPA3255 amps even with PFFB. It performs like a class AB but I can't imagine a class AB amp that can do 100W in 8 ohm to be this small.
The streamer also decodes Dolby Digital Plus and supports Airplay 2, something that Wiim does not support (at least not in one product).
For $1000 it is certainly expensive, but not outrageous for a Marantz product. The RCA performance is unacceptable, but the rest is actually not bad at all.
Connections
Ethernet PortYes
USB-A Port1
USB-B PortNo
3.5mm InputNo
RCA InputYes
XLR InputNo
Phono InputNo
HDMI InputeARC
Headphone JackNo
Wireless Features
BluetoothBuilt-in
Wi-Fi802.11ac
Audio Specs
From NetworkYes
Ecosystems
Apple AirPlayYes
Apple AirPlay 2Yes
DTS Play-FiNo
Google Cast​
No
RoonReady
Sonos​
No
HEOSYes
MusicCastNo
SoundTouchNo
Bose Home SpeakerNo
WiSANo
BluOSNo
Music Services
Apple MusicNo
iHeart RadioYes
PandoraYes
QobuzConnect
SiriusXMYes
SpotifyConnect
TidalYes
TuneInYes
YouTube MusicNo
Control
Handheld RemoteNo
Other Specs
And no official SINAD/SNR figures, seemingly...
SOT: The specs sheet (#2) looks correct (white text) while writing a reply, but while reading #2, it is gray on gray, in dark mode.
That one doesn't have streaming which requires a processor and boatload of software. But does show that the subsystem for digital audio/amplifier can be quite cheap and high performance.
I wouldn't call the HF distortion much better. It is only slightly better between 10khz and 20khz where almost no content lives. From 100hz to 10khz the wiim is better.
100% agreement.
I have provided the link below to the Wiim Amp Ultra review so others can make the same comparison. The Marantz M1 doesn't come close, which shows how much this once great company has become irrelevant today.
