Marantz Cinema 70s AVR Review
Rate this AVR:
    Votes: 191 59.9%
    Votes: 88 27.6%
    Votes: 23 7.2%
    Votes: 17 5.3%
Mostly a bit dissapointed by the very slow filter of previous versions. Was thinking of the 70S and now prices are falling. But if better DAC and Dirac of series 2 well perhaps that is the one for me. Expensive yes but there is no other small unit like this. Two small power amps for main speakers is on the way as well.
If the low profile thing is a must for you, there are no alternatives. It is just too bad Marantz wouldn't offer 2 discrete sub outs. I understand it would have jacked the price up but shouldn't be more than $20 as they already have the design from the regular AVR (Cinema 50) that they can borrow from.
Otherwise I think the Cinema 50 original series is going to be on discount soon, and for EU, it would become a good choice/value for sure.
@peng Exactly, it's time to enjoy the music! The only thing I'm disappointed about is that even the HPF introduces distortion, and you have to use Direct Mode exclusively to get the ideal sound. That said, the LPF on my Monitor Audio Radius 380 subwoofer, set to 60 Hz, integrates quite nicely. There's no boomy bass, and it sounds pretty good.
Subjectively, I would say the C70S sounds similar, in terms of sound quality, to the WiiM Amp Ultra/Pro units I've had in my room, of course, when paired with an external power amplifier, in my case, the Fosi ZA3. However, it still doesn't quite match the performance of my previous separate stereo system.
I've set up Smart Select 1 for movies, using the 5.1 mode, and Smart Select 2 with the C70S configured as a preamp, with only the front speakers and subwoofer active. Of course, in that case, it automatically switches to Direct Mode as well.
@Thomas_A With the Series 2, apart from Dirac, the DAC is also new. However, according to Andrew Robinson's review of the Cinema 50 S2, it sounds identical to the previous one, meaning he couldn't hear any noticable difference. Another new feature is the USB power output, which is great for connecting an external device when needed.
I typically would ignore Robinson review's subjective part but in this I believe him.;) I trust specs and measurements a lot more and based on those there's nothing that indicate the series 2 would sound different, let alone better. The Dirac option is a +, but apparently limited to just DL, no BC, no ART, understandably.
I am interested only in corrections below Schroeder so the simplest Dirac should work better than the Audyssey.
In my experience with XT32 vs Dirac Live, XT32 with the $20 app could get better results (even much better) than Dirac Live, but The Cinema 70S comes with the lowest level Audyssey, the MultEQ version so in this case you are 100% right, Dirac Live will work much better, no comparison at all.
A Denon AVR as old as the '2016' X-3300W comes with XT32 and is compatible with the $20 app.
Thank you for the reminder that select, used Denon AVR's may be a option for a lower-cost home theater system.
Another reminder is, XT32 SubEQ HT can time align multiple subwoofers though for the older 3000/4000 series that means time align 2 subs. Dirac Live does not do that without the Bass control license. On the down side (vs DL), the $20 app is notorious for those who want to customize the target curve, even with a touch pen, but the free ware such as Ratbuddyssey works fine, imo, better than Dirac's that depends on the user's mouse dragging skill.
Yes, I would believe so. There are two options; limited bandwidth 20-500 Hz and full bandwidth. In my use I would need 20-500 Hz. The MultEQ works ok to pull down room peaks for the subs <100 Hz, but it is quite poor doing anything above.
After a long time of listening and testing, the conclusion is unfortunately not a great one.
Everything mentioned above is present. Every effect increases the background noise, but the poor SINAD is also caused by the DSP. In Stereo mode, with all effects disabled, the background noise is good, but the sound starts clipping when the song is mastered close to 0 dBFS.
A few examples are:
  • Adele – Hello
  • Natalie Merchant – The Blind Men And The Elephant
So, basically, every song mastered close to 0 dBFS can cause this issue.
In Pure modes, there is no clipping.
The conclusion is that in every mode and with every input where DSP is involved, even if it is used only for the crossover, clipping can occur.
For music reproduction, the Pure modes are clearly the best sounding. The front speakers remain full range, but you still have the option to use a subwoofer with only the LPF applied, which is a great compromise.
I also tested several external amplifiers, including the Emotiva A2L+, WiiM Vibelink, Aiyima A20, and Fosi ZA3 with the TI OPA1656.
Every amplifier sounded better than the internal amplification. However, the Aiyima and Vibelink don't have suitable input sensitivity for proper integration. With the Aiyima, the front speakers need to be set to +7 dB, while with the Vibelink, even the maximum available level is not enough.
The Emotiva and Fosi both sound great, but I decided to keep the Fosi because of its smaller size.
With an external amplifier, the Marantz sounds great for both music and movies in this configuration.
I think that if someone measures all the different modes, they will find that every mode except the Pure modes has worse SINAD.
I have the Cinema 60 and for a HT its quite good although i do use the pre outs for front right and left to the AV Bypass on my Roksan amps. I found stereo on the cinema 60 poor in terms of sound Quality, massively improved when my main amps used for power amps but still let down by pre amp side of the cinema 60 even in direct mode.
Im not complaining as the Cinema 60 was bought purely for HT and im well happy at that, Also i do have my main music system at the side. Also my main system has superior streamer and separate DAC and Roksan K3 integrated and K3 power amp passively bi amping my main speakers, The Roksan amps alone cost 4 time the price of the cinema 60 so really unfair to compare.
That's just my opinion and im sure other folk may have different findings. But im happy with how all my gear sounds when used for what it was designed for.
Cinema 70s series 2 now SEK9900 ≈ $1000 in SE, thinking of pulling the trigger.
