At the end of the day, everyone has their own approach and priorities when dialing in a system. My initial point in all of this was simply to highlight under what real-world conditions the C70S pre-out delivers clean, great-sounding stereo music playback. We've dragged this discussion out quite a bit, so I won't be posting further on this topic, but I appreciate your time and the mathematical insights. Cheers!
On my part, I just want to make clear that you may not have anything to worry about your Cinema 70S doesn't have enough output for your amps including the Aiyima amp that has lower gain than the Fosi amp. So, with due respect, I simply responded to your concerns that seems misguided, not "dragged... out the discussion" as such.
Regardless, thank you for reconfirming the speakers you are using for you setup, I just want to be sure before I do my calculations to see whether the Cinema 70S and the Fosi or Aiyima amp have the voltage and power outputs. Without knowing your seating position, I am going assume 3 meters, that I think has a good chance to be at least in the ball park based on the fact that they are relatively small bookshelf type and your listening levels are in the master volume 50-65 range.
Below are the calculated/estimated result based on the info you provided and assumed distance of 3 meters from you seat:
| Speakers | sensitivity | Distance | Impedance | Recommended amp power |
| Front | Q Acoustic 3030C | 86.5 | 3 m | 6 | 90 |
| Center | Q Acoustic 3090C | 91.8 | unknown | 6 | 150 |
| Surround | Q Acoustic 3010 | 85 | unknown | 6 | 85 |
Calculated results for the C70S pre out voltage:
From Amir tests, we know the pre-out voltage is 2 V with master volume at 82.5, that means at 65, the voltage will be just under 0.25 V, and with trim at +7, the actual pre out voltage would be just over 0.56 Vrms
This shows your front speakers can in fact be driven to their limits and the Cinema 70S has plenty of headroom even if you crank it up to 82.5.
Calculated results for the power amplifiers outputs:
With pre out = 0.56 V, the Aiyima A20 amp will output about 27 W, the Fosi ZA3 would output about 39 W because of its higher gain.
Amir's test results also show that the Aiyima A20 output about 180 W, 4 ohms, at 1% THD, at that output level, the C70S output would need to be about 1.45 V, and that's indeed would put the C70S in its optimal range, with SINAD slightly better than a whopping 97 dB.
That shows you absolutely have no need to be concerned about not getting "clean" output from the AVR based on your master volume 65 listening level.
So, to conclude this lengthy discussion, the +7 dB trim you ended up with, when using the Aiyima amp is not because of the C70S pre out voltage limit, not because of the Aiyima's relatively low gain, actually only relative to the Fosi ZA3, because with the selector set to +3, the A20's gain is a little higher than 27 dB, that is not low at all, the popular Hypex based amps have gains in the range of 25 to 16 dB typically. The reason for the +7 is mainly due to the relatively (relative to the Center speaker, the 3090D low sensitivity of the Q Acoustics 3030C.
Even if we assume the 3030C and the 3030C are equidistance to your seat, there is a significant difference of 5.3 dB in their sensitivity specs, so if the trim for the center channel is 0, it would be +5.3 for the front channels, again that's only based on equidistance and no room gain, so in reality, the +7 difference would seem highly realistic.
Last point, or just friendly reminder, have you checked and make your Aiyima amp's high pass filter is/was set to
OFF? From the website pictures, it seems that the amp might come with the filter set to 80 Hz, that would be at least partly the reason for the seemingly higher trim set by the AVR.
I understood you wouldn't post further on this topic, but just would like you to know you are welcome to question any of my calculated/estimated results and I'd try my best to explain how they were done.
And, if you are interested, for those who don't know the formula involved, one does not need to be an EE, because the following website has just about all the necessary formula, even some calculators:
dB calculate dB calculator decibel calculator voltage power ratio reference voltage power level matching dBA dB SPL sound pressure intensity ratios converter thd percent % audio engineering impedance matching bridging - Eberhard Sengpiel sengpielaudio.com
sengpielaudio.com
