Marantz Cinema 70s AVR Review
Rate this AVR:
    Votes: 190 59.7%
    Votes: 88 27.7%
    Votes: 23 7.2%
    Votes: 17 5.3%
Hi,
I have a Marantz Cinema 70s 7.2. It was damaged during transport, and the main board of the analog inputs in the phono section was damaged. Four SMD components broke off the PCB. I have a request: if you could provide me with the values of those SMD capacitors and resistors, I would be very grateful.
Sorry for what happened to your AVR. I see there one capacitor and three resistors, I'll see what time I'll have this weekend and I will get back to you. I understand that you are willing to use the Phono input, right?
Yes, I'd like to use the phono input. The Marantz was damaged during shipping. Three other SMD components were also damaged, which I'd like to identify. I've already straightened the chassis, and I still need to repair the RCA phono inputs and those few SMD components, as well as repair the PCB traces. Only the section of the analog input PCB at the very corner was damaged: the phono input, FM, and AM radio modules.
The X2800H can drive those 6 ohm satellites better for sure, but if you use the Cinema 70 as preamp/processor, it is, imo a better choice. The X1800H, if you can get it for less, may be a good option too because for some reasons, it has pre outs for the front left/right so you can use a low cost external amps such as the buckeye amps for the two Focal Evo fronts. I have no idea why the Denon wouldn't offer pre outs on the 2800, except for the Z2, that's very strange.
The X1800h only has pre out on main pair for USA market
Yes, as I said, pre outs for the front right, and front left. I used it for my 2 channel stereo, driving a 2 channel NC502MP by buckeyeamp, with great results despite the NC502MP's relatively low gain. The X2800H can't do that because it has no pre outs at for any channels.
EU and UK versions dont have that feature either
Yep and I did says/stress that too in some of my previous posts. I had that thing for a few months, can confirm that it can sound very well, though I used it with Dirac Live most of the time. The PC standalone version, so ymmv.
I had the X1800H and had nothing but problems mainly the user interface was terrible slow often didn't work or let you transit thru menu, It also struggled to drive my main pair of speakers, i did use the bi-amp feature and it did help a little, but in al fairness they do drop below 3 ohms in the Bass and i know thats an are these AVRs dont like. I gave it away 3 months old. prior to that i had an S760HGB that had some sort of amplifier failure after 6 months so under warranty returned and paid a bit more for the X1800H
I replaced it with an AVR that has pre outs so i could utilise the Pre in AVR bypass on my stereo side.
I did find those 2 Demons had a rather harsh/bright sound but now using Marantz AVR that is a lovely warmer sound on the center and rears and my Roksan K3 integrated with K3 Power amps for mains is wonderfull
I didn't have that sort of experience you had, really strange..... I have had Marantz and still have a few, never found such so called warm sound compared to Denon or other amps that I have, so to me its also strange, could even be people's imagination though I am sure there are other reasons.;) I prefer the Cinema 70, but it has only one subout (discrete) and the very basic Audyssey, so I went with the X1800H, at least it costs less, but sold it mainly because I really needed two subouts for my left/right subwoofers for my 2ch stereo use, otherwise I would have kept it because that thing sound really good, none of the harsh/bright sound you were having.
This is a myth. Please look at the measurements of either, and tell us where this brightness can be seen.
Denon and Marantz come from the same company. They are the same on the inside. Please look at the pictures in the first post here:
We can never convince them, Placebo, expectation bias are very powerful thing, studies after studies proved it, but people like to believe what they want to believe, smart marketing teams just have to give them a few reasons. For Marantz, one of the reasons they cited often in recent years is the use of discrete opamps known as HDAM, yet their slim line models including the Cinema 70 don't even have HDAMs onboard, making them virtually the same (I have seen the schematics) as Denon's equivalent models, go figure..
You don't mention your speakers, which will have the sound qualities you're describing. How does an amp with a flat frequency response sound bright?
The C70’s preamp/dac is not bad, but the power amp section is the weal link. He probably has easy speaker loads.
It has probably been asked a few times however, how's the Cinema 70 as a processor? I currently run a AVC 11Sr in the cinema room. Which its still going strong as has giving me no signs of failure anytime soon. However, as were completely redoing the room Atmos will be added. Which obviously can't be processed by the dinosaur.
To add a discrete processor or replace the amp for the current high end model, are out of budget to be frank.
So will the Cinema 70 be my ticket to ride? Considering it's still not a inexpensive bit of kit, lacks a second HDMI out, only has 7 channels of processing.
For me, it's been great. Paired with my Anthem 525, it really kicks ass.
The convenience of Qobuz connect and ability to add 3rd party music services to the HEOS app cannot be overestimated.
Warning though: I just got an LG 65C5, and the e/ARC refuses to work with it. I had the LG techs out yesterday, and they confirmed that they are seeing compatibility issues with Denon, Marantz, and Yamaha appliances.
It has also been said a few time that it is good as a preamp/dac if 7.1 is all you need. As a processor, if it has the limited featues (vs the Cinema 50) then it is good too, as long as you don't mind the very basic Audyssey it offers.
It probably won't cost much if you go for the AVR-X3800H that is currently on sale, and sell the Cinema 70 because those who believe the so called Marantz sound (not me) seems willing to pay premium for the brand. Keep in mind the Cinema 70 appears to be the only low profile/slim line 7.1 preamp/processor currently available so if you need the low profile feature it might be the only option.
Keep in mind that 7.1 is not Atmos. You can't add height channels to the Cinema 70 and the decoder is only going to give you the DD+/TrueHD core bed layer. If you want heights, you'll need a 9+ channel unit.
If you're on a budget, you'll get a lot more value from a Denon.
Hi, I have a request. Can you help me identify these SMD components? My Marantz 70s 7.2 was damaged during shipping and lost several SMD components. Now I'm trying to save it so it's complete and fully functional.
