Marantz Cinema 70s AVR Review
Rate this AVR:
    Votes: 190 60.1%
    Votes: 88 27.8%
    Votes: 22 7.0%
    Votes: 16 5.1%
For 5 ft distance it should be fine in such applications but the C70’s amp section was not that great based on the measurements.
Thanks...meaning it might struggle with these speakers? I was really hoping to go with a slim receiver in this small room and I'm not thrilled with all I've read about the new JBL line up. I contacted Crutchfield and they said if I order the C70s and I don't like it for any reason just return it. I will probably go this route. If I don't like it then I'll be faced with the decision of adding a multi channel amp or choosing a different receiver. Time will tell. I do wish it had the better room correction.
It has more than enough power, but distortions and noise are much higher than many other AVRs measured.
You may not mind the resulting sound quality as it is still low enough for a lot of people, but only you can tell. It is a known fact that many people may actually prefer certain distortions up to a point, that they find pleasing.
Room correction isn’t too bad if you use it for the 20-200 Hz range that MultEQ can di reasonably well. The $20 app can let you limit the “corrected” range.
Yes, if I end up with Marantz (or Denon) I'll definitely get the app. I have no idea if my 66 year old ears could hear that distortion or not. :rolleyes:
I realize that the Marantz Cinema 70 is not the best A/V unit out there but money is a definite consideration in my case. I originally purchased an Emotivo xmc 1 and their 5 channel 1000 watt amplifier at $599 and $999. The amplifier is still operational but the XMC 1 died about 3 years ago and I have not been able to use my sound system since. They now have their Emotiva
Basx Mc1 13.2 Channel Dolby Atmos® & Dts:x™ Cinema Processor on sale for 20% off for a price in the $900's, I am not really an audiophile just like my music and movies loud and I have Polk Audio towers, Center, Surround and Sub that require big power to drive. I have always considered Marantz to be a well respected name for audio products. A little dissolutioned by the fact that my Emotiva XMC1 died within 5 years of ownership but I liked the fact that it was only a processor as my amp took care of powering my speakers.
Both units the Marantz Cinema 70 and the Emotiva MC1 received poor scores on this website but I am not gifted enough in these sound tests to make a good decision on which would be a better choice knowing that neither will be that great in the first place but adequate for my needs. Would it be possible for someone more knowledgable than myself to guide me with your opinions on which unit to purchase? I believe that the Emotiva is the same no amp processor as my XMC1 and might this be a benifit of something less to go wrong with the processor. Both of these units are within $100 of each other. Any support will be appreciated
An RZ50 or 3800 could easily be had in your price range and you could make use of the pre-outs to your external amp! No need to buy an actual processor as really good ones fall out of your price range anyway!
I was thinking of getting this for my office setup (PC) for gaming.
My PC just has onboard audio (Realtek® ALC1220-VB CODEC) and then my video is from an AMD 7900xt through displayport to an Alienware 34" monitor )Gigabyte B650 Aorus Pro AX motherboard if that matters.
Would I be best to just run optical out from my PC to the Marantz 70s if I just want 5.1 audio? I am happy with how the video is connected from my GPU.
My speakers are Elac Carina BS and a C speaker.
I think you'd need HDMI for 5.1. Toslink only supports 5.1 if DD/DTS encoded.
This is a review and detailed measurements of the Marantz Cinema 70s home theater Audio/Video Receiver (AVR). It was kindly drop shipped by a member and costs US $1,200.
The 70s sports the new industrial design of Marantz AV products which I very much like. It looks even more attractive in this slim package. The display is not very informative but I can see it fitting the style now better than it ever did. Back panel shows a simpler layout which again, I prefer:
Many of us want a compact setup to go with our flat panel TVs or alternatively serve as our main music and TV/video sound and this is all we need really.
I updated the 70s to latest firmware which took about 10 minutes but otherwise was effortless.
Marantz Cinema 70s DAC/Pre-out Measurements
As usual we start with pre-out to determine the fidelity of digital to analog conversion. Per testing of prior Denon/Marantz products I set the volume to 82.5 and managed to nicely get the 2 volt output using HDMI as a source: (all testing with the output set to "Pre-out")
I was really hoping to see noise+distortion as expressed in SINAD to be north of 100 dB but it was not meant to be. I did try Toslink to see if that is any better:
The "grass" in the FFT noise floor improves but SINAD remains the same. Going with what we have, the 70s lands in not so good ranking:
Sweeping the input levels shows that optimal performance is at lower voltage although you don't gain much:
Multitone is at lower level so benefits from above factor:
IMD sweep though shows that more optimizations should have been done in noise and distortion front:
For comparisons to measurements elsewhere, here is 50 Hz response:
There is no filter selection so I was worried that we would see the very slow one from previous generation Marantz products. Fortunately they have adopted a more proper one:
Out of band attenuation is very modest though which will cause pain in the wideband THD+N measurements below. Frequency response shows the appropriateness of the filter in that domain:
Here is what I talked about:
Analyzing the spectrum of a 1 kHz tone shows that the ultrasonic energy is indeed the problem:
The unit is susceptible to audio samples when it comes to jitter:
Linearity is not great although better than some other AV products:
Not a lot to celebrate here although if you look at the review of Marantz NR1510, you will see that it has much rougher results even though top numbers are close.
Marantz Cinema 70s Amplifier Measurements
When I test an amplifier, I first let it warm up at 5 watts into 2 channels of a 4 ohm load. I show this at the end usually since it usually is not eventful. That was not the case here:
I left the amp running for a bit and was very surprised when I looked and saw that jump in distortion around 2 minutes. It also has this odd behavior in that every time you send it audio, distortion is higher and then settles down after about 7 seconds. While the amp was warm I don't expect the amplifier to go into any kind of mode to protect itself with just 10 watts of output. Note that I had ECO mode turned off (double checked). Performance before this effect clicked in was already poor. Giving up another 10 dB is just a sin. Here is the same issue in the dashboard:
After a minute or two you get this:
As noted, once the AVR goes into this mode, you can't get out of it unless you power cycle the amp. Simply turned down the volume, stopping the source, etc. won't make a difference. I almost stopped here as this is just unacceptable. As a minimum it should be documented. But then I considered that the company doesn't seem to be making claims about 4 ohm ability (lowest power rating is at 6 ohm) so I decided to continue and used the better SINAD value in the rankings:
If I use the lower number, it would literally fall of the right side of the chart!
Here is an FFT of before and after warm up:
FYI I could not replicate the issue at 1 and 2 watts.
Back to the dashboard, I also tested with analog input:
Performance is essentially the same so I continued testing with that as that makes comparison to stand-alone amplifiers easier. But I did confirm that in Pure Direct mode, the input is NOT digitized:
I set the crossover to 80 Hz and there, if you don't go to Pure Direct, you not only get that crossover, but output gets limited to which indicates it is going through an ADC. Nice to see even in that condition the bandwidth is large seeing how you have output to almost 48 kHz making me think sampling rate of the ADC is 88/96 kHz.
Noise performance is not great at 5 watts but improves at full power:
Note that you lose some of this with EQ so we really need better performance.
Multiutone shows the busy grass indicating a lot of intermodulation distortion:
Same with 19+20 kHz tones:
Crosstalk could definitely be better:
We see the distortion kink in the power measurements:
Good headroom though since I am only testing two channels and there is power supply capacity for more:
Here is the 8 ohm sweep:
We beat the spec by 15%.
Sweeping frequencies doesn't impact the overall response but the "hump" behavior changes:
FYI sweeping at higher levels caused the AVR to go into protection and would not recover on its own, requiring power cycle. Gave me a scare thinking it was damaged for good!
On the heels of the Marantz AV10 processor review, I had my hopes high for excellent performance but that was dashed with the Cinema 70s. While there seems to be some improvement compared to prior generation, the overall picture doesn't change. DAC performance is just "OK" and amplifier rather poor. Once price goes north of $1,000 I expect better performance. The good looks are there but sadly, the rest is not.
I can't recommend the Marantz Cinema 70s. Company can and should do better.
Thank you for your rewiev.
I was about to buy the unit, to use it as a processor. That will not be the case now. It`s a blow for Marantz to deliver something so out of class, and it does not matter that it looks nice. I use a Marantz NR1606, with a NAD C296 as power and with 6 ohm speakers. It sounds beautiful. Sadly the 1606 lack pre-outs for other than the front speakers. So I guess I`ll wait and see. I will also try a external DAC, to use it together with the 1606 in Pure Direct mode
Thx.
Thx.
Not sure what you expect from a bottom of the line $1200 AVR?
For use as a processor and with a 94db SINAD it such supply very respectable performance.
There are a whole bunch of more expensive stuff listed that offer much less.
Just sayin,
My lowly 1510 makes me happy every day. The noise floor of my house envelops any noise my system makes. I used to chase SPL. This forum almost made me chase SINAD. Glad I don't give too much of a crap. As long as it is clean above -80db and lives longer than 5 years I'm good.
Seems fine as a processor/pre-amplifier (and HEOS streamer). You do not have to use the amplifiers!
Marantz Cinema 70s is not worse than the top-of-the-line Marantz PM8006— in some aspects, it's even superior.
Sounds wrong? Let me explain.
Today, I compared two Marantz models: Cinema 70s and PM8006. My setup: Wiim > Optical/Toslink > Aune X8 (SS306) - Fixed Output. Speakers: Focal Aria 906. Volume: low to medium.
Preamps:
The difference between the two is subtle. The PM8006, due to its slight V-shaped tuning, appears to have a bit more treble energy, creating the illusion of higher resolution (partly true). But honestly, you have to really focus to notice any difference.
Power Amp Section:
Using the Cinema 70s as a preamp, I compared both power amplifiers. To my surprise, the PM8006 sounded thinner, less holographic, and overall less engaging.
NB!
If you're using different speakers, less sensitive ones, or listen at higher volumes, my impressions may not be entirely objective—at higher output levels, the PM8006 will likely be superior.
Internal DAC Comparison:
Without an external DAC (Aune X8), there’s no competition—the Cinema 70s sounds like it has a pillow over its ears.
I don’t know how much sound quality matters for movies—you forget about it after a minute. But for music? Just get a proper DAC, and you'll find HiFi happiness. He he.
For music this marantz 70c performs excellently as a Preamp. I use it as a preamp in combination with the Emotiva bassX300 amplifier and I am very satisfied. The Marantz HiFi signature is present:
1 does not aggressively emphasize high frequencies
2 contributes to an almost holographic sound stage image. This is for me one of the most important features in a HiFi device and this "preamp" has it in abundance
Preamps:
Power Amp Section:
NB!
I need to correct my previous statement about the sound without an external DAC. It turns out I had Audyssey Reference enabled, which made both music sound bad and movie dialogues hard to distinguish (center: Focal Aria CC 900). I disabled Audyssey, which I consider garbage, and everything improved significantly.
However, the Aune DAC delivers a cleaner sound—not as holographic, but in my experience, holography is more common in cheaper stereo amplifiers.
Only Aune can create a centered sound image—meaning that when listening, it feels like the singer is in the center while everything else is spread to the sides (Cinema 70 cannot achieve this in any mode).
However, I also enjoy the Cinema 70s Music mode at low volume, as it is more dynamic than Pure. However, at medium volume, it loses its richness and becomes fatiguing.
To shine this Marantz Cinema 70 it should be only used as a preout + separate amp, because its amplification section is not so brilliant.
I'm also considering getting one purely as a pre/pro, but can it stream Qobuz either directly or via Roon?
After much deliberation, I decided to not invest in a 'reference' AVR but to rather go with separates, especially seeing that I already have a very good power amp.
I couldn't find any in my price range, but then happened across Andrew Robinson's review of the Cinema 70s, and I was intrigued. After much further digging, it turns out that this would fit my needs perfectly. Well, almost, as it doesn't do Qobuz Connect, nor Dirac. But at R22k, you can't expect everything and the kitchen sink.
I ordered on Wednesday morning, and it arrived just after lunch today. And so the fun begins!
The unit is very well packed, with a separate box for the remote, antennas, etc., and it also includes a carboard cutout that you assemble into a mic stand for the Audyssey setup. The build is excellent, and the top & bottom grills are almost completely perforated for cooling.
Setup was quick via the built-in wizard, and I was up and running in a matter of minutes, after waiting the obligatory half-hour for the various software updates to complete.
Out of the box, with no Audyssey calibration, the sound from various sources is crisp, if not a touch bassy. I played a couple of SACDs via my Oppo and the sound is excellent, again, maybe a touch bassy - Audyssey should help temper things. Movie/Series playback is trouble-free, with the surround being way more detailed than I ever experienced with the T778.
I'm loving the Direct & Pure Direct modes, haven't quite figured out the difference though. What is also very handy is the built-in 'Preamplifier' mode in the settings, which switches off the amplification, and reduces power consumption & heat.
The CEC works beautifully with everything, although the eARC did not - a quick relocation of my Chromecast from the TV to the 70s, and everything works perfectly in sync.
The HEOS app is quite blah when compared to the Bluesound one, but still getting used to its quirks.
Due to the lack of Qobuz Connect, I have to keep using Roon or Chromecast for music. I think a re-evaluation of Tidal is required, as it has Tidal Connect built in, and I don't feel like paying for Roon any longer.
I will keep updating as I find my way around this new ecosystem.
View attachment 439855I've had the same experience after my nad T778 had been repaired twice! This 70s made me reevaluate some things as I sold my eversolo and transformed 70s into procesor only and I'm satisfied.
