Canton smart connect 5.1 might be a better buy for the same money. If the digital filter used has better attenuation.
As you know, Swedish soundtechnical society has shown that a good attenuation of the digital filtering is the most crucial thing in a dac for being without coloration in the listening tests. More important than high SINAD numbers.
That may be true, and let's assume it is true but it begs the following simple questions:
1) Is this attenuation of the digital filtering a current issue with even the mid range dac chips such as the ES9010K2M, ES9026Pro?
2) Even if it is, and is detectable in those listening tests, how would they quantify the audibility levels between this factor and SINAD, say in the range of 91 (that is about the worst you can get to 120 dB (about the best you can get from the current best chips such as ESS, PCM, AKM, Cirrus Logic's?
3) So okay if their finding is 100% valid, still, does high SINAD hurt anything, if not, what's wrong with aiming for high SINAD, that at least serve to minimize noise that is always going to be audible in a quiet room, if below a certain point, say 96 dB SNR?
4) Most importantly, are they just doing such study because they found some of the popular DACs color the sound that are audible to their study group? If not, what is their goal, conclusions?
It just find it a little silly to imply (not you, some people tend to do...) that why chase high SINAD when there are other factors that matter too, or even matter more. The thing is, knowing there are other factors that need to be solved, it should be more important to at least do the best on factors that can be improved to the point where we can say it is solved.
