Yes i have DIRAC Live now along with Audessy . Please check my comments in another forum.Has anyone moved to Dirac Live yet? Wondering how you found the difference to Audyssey?
I haven't tried my 2 subs with Dirac live directly, instead used minidsp HD to make it a s a single sub. I guess DLBM is still missing and hence it wont perform multisub corrections now. It might perform some gain level adjustments, but not time alignment between subs(this is my guess).also wondering how it behaves when one has multiple subs, is it worth now to buy the license or is this a step back (in comparison to audyssey, which supports on the cinema 50 4 subs)
I tried with Audessy and it did a decent job but in crossover regions i had big problems, but minidsp was better in that case.
To my understanding in cinema series , minidsp is the way if we want a good alignement between subs for now.
Don't know audessy will improve on that, but DIRAC DLBM will be on Q2 2024 which might help.
Do you know which version of Dirac Live are they using (2 or 3)? Does it have bass control?Yes i have DIRAC Live now along with Audessy . Please check my comments in another forum.
Dirac Live 3. No it dont have bass control in cinema 50.Do you know which version of Dirac Live are they using (2 or 3)? Does it have bass control?
I tried and it didnt helped. Please see some plots in another forum.With Audyssey, I found that you have to try different crossover for the smoothing response at below 100 Hz. In my case, 80 and 90 Hz crossover works much better than 60 and 70 Hz, no comparison. Found the same even with DLBC, have to change crossover from it's default 70 Hz to 85 or 90 Hz to avoid a major suck out. minidsp works but I have not try different mic position, though in theory it would work well at the mmp but could be worse than Audyssey/Dirac if you move your head even just a few inches.
I posted the DLBC vs no DLBC graphs but only with two subs acting as one. Given what I have, it is not possible to do it with .2 subs, not without more work that I don't want to do.It would be super interesting to add DLBC to check how the subwoofer integration works compared to Audyssey, but alas, we´ll have to wait for that.
Peng´s results perhaps can explain why many users say that they get a better detail as all the response looks a lot more even.
So given the choice, would you rather go Dirac than Audyssey? I´m not considering the ART upgrade because that is quite limited as of now, but if future upgradeable, that would seem to make a no brainer.
I posted the following elsewhere, you can clearly see the effects of DLBC. I am sure that suck out can be improved if I spend more time adjusting the crossover. Based on the default crossover, while it still improved the suck out but probably not as good as Audyssey but I can't be sure because as at the moment it would not be an apples to apples comparison for reason I mentioned earlier.It would be super interesting to add DLBC to check how the subwoofer integration works compared to Audyssey, but alas, we´ll have to wait for that.
I'd stick with Audyssey for now. DLBC is not available in Sound United brands until 2024 and will be priced at $500 for multisubs plus the cost of a Umik mic at a minimum. XT32 is free and at least has some sort of sub correction for up to 2 subs (although far from ideal) besides massively customizable with just a $20 app.So given the choice, would you rather go Dirac than Audyssey? I´m not considering the ART upgrade because that is quite limited as of now, but if future upgradeable, that would seem to make a no brainer.
However, in the future when DLBC for multisubs is introduced into the lines and if you have 4 subs, this will be quite a sonic difference. Still, nothing you cannot manage with a miniDSP unit and a Umik with lots of manual labour.
Am I understanding correctly that the DLBC is using one sub instead of 2 independent subs and Audyssey is using 2 independent subs in the comparison above?I posted the following elsewhere, you can clearly see the effects of DLBC. I am sure that suck out can be improved if I spend more time adjusting the crossover. Based on the default crossover, while it still improved the suck out but probably not as good as Audyssey but I can't be sure because as at the moment it would not be an apples to apples comparison for reason I mentioned earlier.
Thanks.Exactly my point about not being able to compare the two in apples to apples. Those graphs are for DL disabled versus DL without no BC versus DLBC, but because in my setup I cannot have my DLBC mapped to the AVM70 in .2 (two independent sub feeds), so the two subs were operating as one., still two subs but both got the same signal.
Audyssey's is not shown in that comparison graph but you can see the one in post#328, those two (green for Audyssey) are still not apples to apples because a) Audyssey's were .2 and b) Dirac's were the base version so no BC at all, and therefore it was basically hybrid, FL/FR corrected by Dirac while Sub1/Sub2 corrected by Audyssey.
For owners of the X4800H, they can easily use REW to compare the two on apples to apples basis, and Audyssey would have the edge in the case of multiple subs, at least in theory. I suspect Dirac, without BC, will still sound better overall, especially for music listening.
