Marantz Cinema 50 AVR Review
There's approaching zero chance that any differences in any receivers with the same high-level features will be audible. Buy based on the features you need and yes, spend the rest elsewhere (or save it!).
guys fully confused between 40 vs 50. I'm not in a position to demo. this will be a direct order.
disregard features, disregard cost.
just on basis of sound.
has anyone been able to demo the 40 vs. 50 back to back ? How much better is the 50 over 40 sonically?
thanks.
If you are any way going to use an external amplifier for the front Left and right speakers, then Cinema 50 , as you can save some penny for the external amp.
If you don't plan to use an external amp for fronts, then Cinema 40, as you will gain some power.
I have cinema 50.
DAC wise both are same as per the specs.
They are not the same hardware, despite the fact that many people think this way and suggest that a $1K difference can be spent elsewhere.
They're the same. If needing IR in/out is a deal-breaker, then the C40 is out of the picture:
thanks.
Any special reason you have switched to the Marantz versions of the Denon models? Do you prefer the look better?
Otherwise, the Cinema 40 is same as the Denon 4800 and the Cinema 50 is just the Denon 3800 (paying a lot more for nicer packaging).
I had previously Denon 3800 and now Marantz cinema 50. Two reasons i preferred Marantz is 5 year warrranty+marantz musical sound. Price wise approx. 400 Euro diff here in Europe. I didn't purchased Marantz due to its looks.
I bet they are, as they did in the prior year models such as up until the Denon 3000/4000 and SR6000/7000 series. Even for the 3800/4800 vs C40/50, if you go by the info from the Masimo videos, they do look pretty much the same. Marantz use the slow roll off dac filter, and have HDAMs, except for the slimline series.
There has been at lest one Youtube video in which the presenter seemed to want to debunk the belief that the D and the M models share much or the internal parts. Unfortunately, he was spreading misinformation, though I trust it was unintended and was done inadvertently, as he obviously simply regurgitate what he was told. Also, iirc, he was using the AV10 vs the A1H as example, not realizing the differences between those two don't really represent what's happening on the AVR side.
As mentioned many times, in Europe and Asia, Marantz costs just a little more. I have seen differences in prices between the C40/4800, C50/3800 as little as 200 Euro based on forum posts and internet seller websites. In North America the difference in list price is typically from $1,000 and up between the equivalent models.
so you do confirm that the x3800 and the c50 sound different from each other with distinctive respective brand house sound for movies and music....?
no not for looks.
that's what I'm trying to say.... both the brands have a unique and different sound signature from each other as likely confirmed by jiji who's has the opportunity to own both the x3800 and C50.
The only plausible reason can be deliberate roll off of highs on marantz (someone commented on their dac filter earlier). If that's the case, better to have the denon with accurate sound and adjust it with eq to your taste.
The only plausible reason can be deliberate roll off of highs on marantz (someone coentwd on their dac filter earlier). If that's the case, better to have the denon with accurate sound and adjust it with eq to your taste.
Agreed, I feel sorry for those who insist on going by ears. Going by specs and measurements make it much easier to decide on which avr to purchase. Otherwise, one has to do a lot of ab listening, or worse, have to ask others who have done the ab, and then wonder who to believe.
Correct. You can buy the cheaper Denon and manually do the high frequency roll-off (~15kHz?) and, voila, you get the famous "Marantz" sound!
I can do the same on my 3800 and make it a Cinema 50! LOL!
I have been hearing a lot from different forums including this, like equing them to sound similar. I tried atleast 4 different speakers , 4 different receiver brands and some separates in my last 10 years journey.
My listening experience(subjective) is that equing helps room modes , but not the sound signature of the respective devices(Speakers & Receivers/Amps).
For example Marantz sound signature(may be bit coloured,especially in music) i'm not able to get in denon and Yamaha sound signature(sound neutral) is different compared to both. All have equalisation options and i have checked them in same room and with basic sound absorption/reflection kit (first reflection protection).
My Kef LS50 , ELAC , Yamaha and now KEF R3 meta speakers, they all have some differences in sound signature(different vocals, different soundstage, different phantom center) , even i have equied for room modes. For example LS50 holographic presentation is present in all cases weather you equ or not.
In my perspective , if we can equ and get the same response /sonic character , then why to buy high priced gears of same configurations ? I'm not saying day and night differences here, but in some magnitude.
I have used DIRAC, Audessy, YAPO and each has its strength and no all in one solution in my case. I found audessy best for movies compared to DIRAC, DIRAC best for music compared to Audessy and YAPO a kind of both mixed. So i use Audessy for movies all time and DIRAC for music with recievers.
Normally i hear music untouched with any equing ( Streamer/DAC to XLR input of my dedicated music amp) most of the time, and some times with DIRAC. So depends on my mood i will change and it is really good.
I know most will disagree on this, but i learned this on my journey slowly.
I respect measurements since I do for all my tuning and verification.
My subjective opinion is based on my learning curve and i admire others opinion as well and that's why these forums are great..
coming to the point, in my subjective listening , Denon 3800 & cinema 50 is not same sonic behavior and i believe it might be due to HDAM implementation..
I don't have the Denon anymore.
I agree that can be done, not necessarily 100%, but should get people there better than 50% for sure if they know how to do it, and are willing to spend time on it. The AV10 actually sort of give their users the option to choose the non-Marantz standard DAC filter that will kill the 10-20 kHz roll off.
Probably not, but keep in mind, distortions and frequency response characteristics are really the main causes for different "sound signatures", all else being equal (e.g. spl, cross talk, dsp functions etc.). In that sense, with the help of the powerful Audyssey MultEQ X, or Diract Live's highly customizable target curve, you should be able to shape the overall sound signature to your liking, if you are willing to spend time on it and use something like REW to guide you. I have done it, and have multiple filters created so I can slowly but eventually find the one I like best. What else you do think are the causes for the two near identical (audio circuitry wise) C40 and AVR-X4800H could sound so audibly different to some people, and not to others, say in pure direct mode? I ask only as a mater of curiosity.
Sounds reasonable overall. The key point of your whole rationale is, as you said "My subjective opinion.."! Because it is subjective, and especially if (only if, not saying it happened to you) the idea is already planted in your mind, you cannot get rid of it. It started many years ago when electronic circuitry, parts and components could result in those kind of sound signatures often enough, that people noted, actually heard such differences between brands and models of even devices with seemingly low distortions. Such resulting talks then naturally got circulated via electronics magazines such as Stereo Times, Stereophile, Sound and Vision, WhatHifi etc., and began to influence hobbyists and audiophiles. Because of the internet, such talks(myths in many cases) could spread much faster and wider within the audio community. So, people read a lot of such opinions on the internet, forums etc., plus marketing teams of manufacturers such as Marantz smartly reinforce such beliefs/myths by inserting the almost redundant buffer stage aka HDAM in ways that almost make no sense in their AVR line; and use a slow roll off filter in the digital circuitry, thereby giving the somewhat technical knowledgeable reviewers something to go with, and spin, and spin.. With all such forum hearsay and marketing strategy, those who believe in the so called sound brand sound signatures are already biased, before they actually sit down and do their own AB. Now if they were to do such ABs following controlled tests, preferably SBT or DBT, such preconceived, seeded, biased opinions would likely not been effective, but 99.99% of such AB done in dealers or homes are going to be sighted, and often not even level matched to within 0.5 dB and in pure direct mode etc., you can imagine who so many who have done such AB comparisons could form their opinions of "sound signatures" between brand.
The example you cited on HDAM is a great point, if it was done like the way Marantz did in their integrated amps, there would have been a good technical argument, or merit except one can still argue whether the minute difference resulted in things like THD and FR (mostly) or even slew rate, could have audible effects, but there could easily be at least measurable differences due to the HDAM buffer, or amp stage (if used that way). The fact is, (yes it is factual as you can see in Marantz own published block diagrams), in their AVRs, they placed that extra buffer stage right at the end of the preamp/dac signal path. So you don't have to be knowledgeable in electronics circuitry to understand that such an extra buffer stage, i.e. the HDAM stage, even if it is perfect in terms of slew rate (Marantz main claim of benefit in their marketing info) would has no effects on the final outcome because it is going to be bottlenecked by other parts such as the volume control, dac, and opamp chips up and downstream the audio signal chain.
Just take a look of the following block diagram from the Masimo video:
You can see that the HDAM module is positioned at the end of the volume control block, and ahead of that block is the DAC (if digital inputs such as HDMI are used). Actually, as bigguyca pointed out before, since around 2019, or 2010 don't remember for sure, D+M also added another opamp at the end of the pre out signal path so as I mentioned before, you don't need to know anything about EE, just have to think logically, that the claimed benefits of the HDAM in terms of low impedance and high slew rate due to the fact that it is basically a discrete opamp buffer with unity gain (that is no gain) cannot be realized because the weakest link, whether it is the DAC, E. Vol, or opamps in the signal path.
For example, the slew rate of the opamp amps, in this case the NJM8080G's slew rate is 5 V/us typ., according to the downloadable datasheet. Such slew rate for an opamp is not SOTA, but is more than sufficient for transparency for the audio band that is only up to 20,000 Hz. That is not really the point though, the real point is, if the opamp in the signal path is limited to 5 V/us, it does not matter if any opamp, such as the discrete HDAM downstream has slew rate of 50 V/us of higher because the pre out signal is still going to be limited to 5 V/us. The important thing is for the HDAM to not drag down the opamp IC's performance.
Note: Regardless, I do recognize that without looking into the details, the Marantz website and the Masimo videos do look convincing as they cited the reasons why Marantz as a distinct sound signature than Denon's, and they also tell you each team has their own "Soundmaster" who ensure the target "sound" is achieved. All that despite no bench test measurements manage to show any the audible effects they identified, not even in their own bench measurement results. They failed to convince me, but I can understand why they must have convinced many, if not most potential customers. :) The only exception is the rolled off high frequency that would start from about 10 kHz, that applies only to digital contents with sampling frequency of 44.1 kHz.
Here's the 4800's block diagram, again the opamp ICs are not shown, but the prior year models has the NJM8080G as well, as shown in service manuals such as that of the 4500, or SR6014, or AV8805.
The signal flow, as shown in the block diagrams are the same, the ICs used for the ADC, DSP, DAC, Selector, Vol. are the same, except Marantz C60, 50, 40, all have the extra discrete HDAM buffer amp, that invariable would add distortions and noise, however minor (that was the suspected reason for Marantz lower SINAD as found on Amir's test bench).
Lastly, if you look at the at least 4 Marantz AVPs/AVRs and Denon AVRs reviewed and measured by Amir, you cannot find any evidence to support any Marantz sound signature than Denon's except they had a little lower SINAD, but the minute difference at the below 1.5 V pre out voltage did not point to audible differences between their corresponding models.
Back on the subjective side, I have owned quite a few Marantz AVP, preamp, and power amps as well as a few Denon AVRs and can happily live with any of them. Only once I thought I heard a difference (the my first Marantz AV had a "warm sound" lol, but quickly realized the real reason for the perceived difference. Other than that, they are all transparent enough to me without DSP engaged, with DSP and Room EQ/correction, it is hard to say which one sounded better to me overall.
If you think you can consistently identify different sound signatures between say, the Cinema 40 and AVR-X4800H, it would be a good idea to go with the one that sounded more pleasing to you, even if the perceived difference were not due to something else other than DSP related (hence as you alluded to, cannot be fixed via DL or Audyssey). That's not because I think what you heard would not be there in a DBT, but because if you don't go with your ears/brains, you may end up with what they called buyers remorse. It is better to error the side of caution/safety.:)
By the way, as I posted before about the one obvious difference between the two brands design/implementation of the DAC is that Marant uses the slow roll off filter. Most dac ICs have provisions for the user to choose different filters, the Marantz team obviously prefer the slow roll off type and Denon prefers the standard type. Using the slow roll off filter would result in a slight roll off of the high frequency range. Amir's measurements show it would start to roll off at about 10 kHz and dropped by about 2.5 dB at 20 kHz. Most over 40 will likely have enough HF hearing loss to notice the drop of 2.5 dB at 20 kHz but some may so that could at least explain why Marantz may sound less bright for some individuals. That, however, will not affect analog inputs performance because then the DAC is not even involved, let alone the output filter. Even when the dac is involved, the roll off should mainly have audible effects only for contents at the lower sampling frequencies such as 44.1 or may be even 48 kHz, based on theories related to the well-known Nyquist frequency.
Just got my Cinema 50 delivered yesterday, but been busy with work and I haven't set it up. That'll be this weekend. Does anyone know whether the Dirac Live full license that I purchased with my NAD is transferable to my Marantz?
Not transferable.
Can you please describe the musical difference?
Exactly my point about not being able to compare the two in apples to apples. Those graphs are for DL disabled versus DL without no BC versus DLBC, but because in my setup I cannot have my DLBC mapped to the AVM70 in .2 (two independent sub feeds), so the two subs were operating as one., still two subs but both got the same signal.
Audyssey's is not shown in that comparison graph but you can see the one in post#328, those two (green for Audyssey) are still not apples to apples because a) Audyssey's were .2 and b) Dirac's were the base version so no BC at all, and therefore it was basically hybrid, FL/FR corrected by Dirac while Sub1/Sub2 corrected by Audyssey.
For owners of the X4800H, they can easily use REW to compare the two on apples to apples basis, and Audyssey would have the edge in the case of multiple subs, at least in theory. I suspect Dirac, without BC, will still sound better overall, especially for music listening.
Thank you. I want to upgrade to a Sound United avr with Dirac for music. This was very,very helpful.
I have both DIRAC and Audessy in my Marantz cinema 50.
My recommendation would be , if you don't have separate stereo for listening music , then upgrade to DIRAC in your AVR.
I definitely don't like DIRAC for Movie(very dull and not detailed surrounds) compared to Audessy which is damn good for movies.
For music DIRAC is bit better compared to Audessy. Its bit laid back, clear bass presentation and decent soundstage. Audessy in music , the bass seems to be bit extra boomy and voice is bit not clear. (may be this is me?)
I switch DIRAC(for youtube music videos) , Audessy for Movies strictly and Direct pure audio(without any processing like room correction software's) to my dedicated stereo amp for music. That being said I have basic reflection(first reflection) corrected in my room.
