The Denon AVR 4800 amplifiers measure better and is cheaper!
I am not sure, so I did a side by side using a spreadsheet:
Based on this comparison, I would say this is the first time we can really say the two are technical identical twins, made in the same production facility in Japan too. There are very minor differences in a couple tests that show the Cinema 40 did may be up to a couple dB better at lower output levels but I believe such minor differences mean very little unless Amir did both at the same time/day, side by side under the exact wiring layout and conditions including humidity and temperature lol.. but not when at times he mentioned ground loop issues that he reduced/eliminate but not sure if he re-did those test (not exactly his words, I am just using examples to say that when you do such lab work on different day, and unless you repeat those test a few time, there are bound to be variance. Anyone who has run Audyssey, Dirac or whatever, even just do a REW sweep, you don't get the same results every time even if you never move the mic...
So, I have to conclude that (okay just my opinion), if Europe, such as France, Germany, UK, and you like Marantz look, go for the C40, but in Canada and the US, definitely take the AVR-X4800H and spend the $800-$1,00 saved on high quality contents, or on subscriptions such as Qobuz etc., or just use it on DLBC, ART.
| Tests | Cinema40 | AVR-X4800H |
| HDMI | 90.364 | 94.068 |
| TOSLINK | 97.229 | 94.265 |
| SNR | 108.047 | 107.719 |
| IMD | ABOUT 2 dB BETTER AT -20 TO -15 level | 3 TO 5 dB BETTER FROM -5 TO 0 dB level |
| 32 tone input | about 17 dB distortion free range | almost 18 bits distortion free range |
| Linearity | about the same as the Denon | about the same as the Marantz |
| Jitter | had 6 kHz sideband, HDMI worse | no sideband, HDMI same as Toslink |
| Frequency response | Nice and flat, same as the Denon | Nice and flat, same as the Marantz |
| 5 W output, analog input | 86.666 dB | 87.229 dB |
| 5 W output, digital input | 84.698 dB | 86.035 dB |
| Cross talk | Almost identical to the Denon's | Amost identical to the Marantz's |
| Power output at 1% THD | 212.8 W | 208.2 W |
| Power output vs THD+N | Looks the same as Denon's up to 10 kHz | Looks the same as Marantz's but better at 15 kHz |
