livinon2wheels
- Joined
- May 3, 2024
- Messages
- 218
- Likes
- 143
well, allegedly....Well sort of. Car guys in the states are Pickup Truck crazy.
The bigger the truck, the bigger your package, right.
. Carbon package that cost $15k, $7k set of wheels, $5k seat upgrade, and things like that...You just have to spend it wisely for both, build muscle systems. Big Horsepower engines and Amp/Speaker size should be at the top of the list.Well if there is a worse way to spend money than audio, then it's definitively expensive cars and trucks. Carbon package that cost $15k, $7k set of wheels, $5k seat upgrade, and things like that...
It literally gives a SINAD number at 2Vrms...You don't "supplied" voltage to RCA pre-outs as they are outputs so I am not sure what your question really is.
So why does the JBL or Marantz appeal to you over the Denon particularly? Why not speakers instead if looking for some sort of significant change?Hi everyone I'm looking for a new receiver the JBL MA9100HP or the Marantz - Cinema 40, i have the Atmos 5.2.4 setup and my old receiver is the Denon AVR-x4300H and the speakers are the JBL Studio 590 x2, JBL Studio 580 x2 and JBL Studio 520C and 4 ceiling speakers
Might want to wait for the AV30 if you only need 9 channels.Should we expect the AV20 to perform similarly?
My system is 5.2.4 so I don't need the extra channels.
The AV20 supposedly should measure similarly to the AV10. However, it offers fewer channels (13.4 vs 15.4) and a simpler mainboard.Should we expect the AV20 to perform similarly?
I do agree on expected performance of the 3 units. Personally I was holding off a bit waiting on the release of the AV30 but the differentI do think the AV30 is probably going to be in a sweet spot for price/performance, and I would've purchased an AV30 if it were available at the time.
DAC application of the AV10/20 and the 30 just kept nagging at my brain. Will there be an audible difference, not in the rational mind I would believe.
OTOH, once you know, you know and the the doubt and sighted bias issues start to nag at ya.
I any case I've very pleased with my new AV20 so far.![]()
The AV30 is 11.4 channel so it fits neatly into 2x9017Swhere as the AV30 will likely do it like the Cinema30 (hopefully not), that is to use a different IC for at least one of the subwoofer channels, because the ES2017 is an 8 channel dac so 2X8=16, just 1 channel short, ouch.
Sounds good, but that's surprising, that it would offer few channels than the AVR-X6800H and Cinema 30.The AV30 is 11.4 channel so it fits neatly into 2x9017S
https://www.audiosciencereview.com/...3-4-channel-avp-discussion.62688/post-2312765
I suspect few setups go beyond 7.4.4, and they already have the AV20 and AV30 for those who do.Sounds good, but that's surprising, that it would offer few channels than the AVR-X6800H and Cinema 30.
13.4 channel processing, 11 channel amplification With external two-channel amplification that can be assigned to either Front Left and Right, or a pair of height channels, you can setup a 13 channel speaker configuration such as 7.1.6 or 9.1.4, allowing you even more flexibility and elevated immersive audio experience
I have a Denon now that's acting up and wanted to replace it. Old receiver is the Denon AVR-x4300HSo why does the JBL or Marantz appeal to you over the Denon particularly? Why not speakers instead if looking for some sort of significant change?
Same here, my Denon X4700H started acting up so I sent it off for repair less than 1 week before the 3 year warranty expiredI have a Denon now that's acting up and wanted to replace it. Old receiver is the Denon AVR-x4300H
Just curious what your experiences are. I have a 3808 and 4520 and 4700....all work fine altho I did scare myself with the 4520 at one point (turned out to be the power outlet). Last Marantz I got was a 2270 in 72 or 73 or so, when it died in early 80s I went separates. The 2270 also had issues, kinda put me off the brand. Didn't know about Denon for quite a while afterwards but had friends with them and they had a nice feature set. Also weird how they market the Marantz at a higher price in the US for basically same componentry/features.Same here, my Denon X4700H started acting up so I sent it off for repair less than 1 week before the 3 year warranty expired
I knew I'd never be comfortable with it after a repair. Just got it back 3 days after my AV20 arrived and I havn't even opened the box yet.
In any case, I'm a Marantz guy, they've been at the front of my Hi-Fi rig since around 1974 so ---
Being honest I don't find it weird. Yes I'm American and would rather see the name of an old line US product on the front of my gear than a Japanese one, no matter what todays realities are. I'll only buy American cars too.Also weird how they market the Marantz at a higher price in the US for basically same componentry/features.
Mine had some input bleed issues (could hear fm sometimes on other inputs). It failed but that may have been party influencedMy first really good Hi Fi was also a Marantz 2270. It operated flawlessly till my first wife took the whole system in the divorce.
I also then went to separates going thru lots of gear in the 2 channel and surround systems. Most very reliable except Adcom 80s-90s multich processors, just junk.
Since retirement to FL a Marantz 7701 Pre-Pro ran flawlessly till I sold it to another member here, Last I knew he was still running it.
I upgraded to a Atmos capable 7703 which was great till a massive lightning strike killed it and a bunch of other gear one night..
Replaced with the Denon X4700H which was fine till it died.
YMMV
