Marantz CD67 mk2 SE - IR receiver
rob-t
Hi,
My Marantz CD 67 mk2 SE does not respond to remote control anymore. I test the remote control using my camera, and i can see led flashing. I assume it works fine, and the problem is with the IR receiver.
I removed the front panel and noticed the IR modul (ZY01 on service manual) has signs of repair (it has non-factory soldering). that was a surprise as I bought it from a legitimate shop 20 years ago. Anyway.
I cannot tell from service manual i found what kind of IR receiver is used. I wonder if I can replace it with most common 2-pin ir receiver on the market.. Any advice?
Thanks,
Rob
