Marantz CD-67 mk 2 , can you help me to fix the tray open /close?
Mantra
Europe
Hi
i bought when i was young a Marantz CD-67 mk2 never used for years in short never used
some month ago i wanted to use and play some music , but it had some problem , it can't read many cds
so i replaced the entire tray mechanics and the lens
it works , but the problem is the try open and close , when i press eject and the tray opens half an less 1 cm or so, then immediately closes.
and to let this tray open i have to try to open and close for many times , after i can open and load the cd
i have replaced more than once the entire mechanism (included the lens ) but the problem persist
can you give some advises please?
i like this cd player, should i lube ? the hardware is new
thanks
