Marantz CD-63 measurements
audio_tony
Here are some measurements of a Marantz CD-63.
NOTE: The HDAM modules have been removed from this player, so it's no longer standard. No other modifications or upgrades have been carried out.
The PSU appears to be a little noise (50Hz spike) however I've not looked into this.
Also, I seem to have some issue with the multitones - even if I load the multitone wav file* directly into REW it still reports 2.8 bits so no idea what's going on there...
*I have tried generating this from the Multitone apps as well as creating my own with Sox - no difference.
For the crosstalk measurements I have only shown the silent channel - all input levels for the crosstalk measurements were -1dB.
**if anyone can tell me how to get rid of the cursors in REW I'd be grateful. I can't seem to find a way to do so....
My test setup: Asus Xonar STX sound card with a self built buffer / gain box in front of that. Host PC is an Intel i7 running Windows 10 with 32G RAM and SSD - no mechanical disks or CDROM drive present.
I also use an Altor Audio Olivine-2 ADC, however the Asus Xonar was used these measurements.
Sound card input was set to 24bit/96kHz
REW was configured as per the recommendations in the post from @NTTY
Great effort. :)
Although "dBFS" is not a reference that has any real meaning to absolute levels, output or residual. And frequency response, what is that- a white noise integration?
What is the output of the player in VRMS at 1kHz, 0dB?
Great effort. :)
-0.1dbfs = 2.02 vRMS into my Asus sound card.
My measurement path is DUT -> buffer* box -> Asus sound card
*the buffer box has a gain adjustment but it's typically just buffering.
-0.1dBFS. Why?
There is no test for CD players since their introduction in 1982 that calls for a -0.1dB from full scale THD test. All its specs are with respect to full scale.
-0.1dBFS. Why?
When I generated the 0dB tone in sox, it warned that some samples were clipped, so I took the level back a bit.
It doesn't make any difference to the final measurement anyway.
Because RTA assumes you're measuring from the last generator setup.
Open the generator and select Multitone 1/10 test. No need to launch it. RTA will adjust the dashboard to that specific test. Example:
Thanks, I had no idea that different measurement modes were selected like that. I'll try that later.
