exm
- Joined
- Sep 21, 2021
- Messages
- 323
- Likes
- 282
Because a full Dirac license is 4 X the cost.
People buying a $7,000 processor are concerned about this? I mean, I guess.
It would be interesting to understand in what ways Audy has more adjustment than Dirac. There is plenty of tweaking possible in both products.Because it is not set in stone which one will work better in your room and with your system. If you are looking for auto calibration run, with potentially minor adjustments, then Dirac with DLBC will most likely be better out of the box. But with Audy you will actually have much more room to tweak albeit there are some limitations that one would need to understand. Distance with D&M Dirac is 17m vs only 6m with Audy. 6m is sometimes too short if DSP on sub is heavily used or subs are far away (which it should not be as SPL loss is staggering). There are some workarounds, but they are not very elegant.
It's unfortunately all really complicated once you enter the rabbit hole. The only way you will know is have both in your system, make sure you have done most you can to optimise/tweak calibrations, measure, listen and then make the call which one is the keeper.
The most obvious one is Audyssey Dynamic Volume.It would be interesting to understand in what ways Audy has more adjustment than Dirac. There is plenty of tweaking possible in both products.
Pretty sure the $20 app uses the device (phone or tablet) to do the calculation, not just sending the curve.The amount of taps is set in hardware. Systems that can do correction at >48 kHz for example utilize more taps to make that correction. In the case of StormAudio, they use two processors but restrict the correction to 48 kHz, resulting in twice the taps available.
That said, if you think about PEQ, there are a bunch of different ways to achieve the same curve (think about REW’s auto EQ). That optimization may be better with MultEQ-X as compared to the iOS app. My understanding is that the iOS app just sends a curve to the processor to do the calculation whereas MultEQ-X actually uses your laptop/desktop CPU to generate the filters when transmitting the data.
That would give better tracking of the target curve without needing more hardware.
Absolutely right - you should do it and figure out for yourself. Good luck with it as not that straight forward. I am not going to teach Audy vs. Dirac calibration class yet again. There are many posts and threads in this forum to that extent so if interested, then look them up. And not really sure what tweaking of base setup differences you are looking for?It would be interesting to understand in what ways Audy has more adjustment than Dirac. There is plenty of tweaking possible in both products.
It's the only RoomEQ that offers Impulse time alignment, etc. You get what you pay forI completely agree but didn't mention it for fear of getting lynched by the Dirac crowd here. LOL
The MultiEQ-X app should offer 90% of what a full Dirac package should cost at a fraction of the cost..
YMMV
What is, Dirac?It's the only RoomEQ that offers Impulse time alignment, etc.
Actually you can do all this with REW and cheaper DSP, which also might support MSO that will work even better, or you can do it manually on Audy MultiEQ-X with REW. Best waterfall charts are done with MSO, not Dirac or Audy.It's the only RoomEQ that offers Impulse time alignment, etc. You get what you pay for
I've been using Marantz multiple channel AV amp MM 7055Improve as in better sound quality?
The older Marantz AV's definitely had some measurable issues with their internal DACs and other design issues. Then there is the fact the both unit's offer better versions of Audyssey and Dirac is also an option. So yes, I believe the upgrade to an AV10 offers some definite path improvements to better sound quality.
You didn't mention what your current power amps are so impossible to say if there's any room for improvement there. No doubt the new Toppings and many other modern power amps offer improved measured performance. But whether they can offer any improvement in sound quality is highly debatable. What ya got now?
to drive my surrounds, mid and another Marantz MM7025 to drive my fronts.
While watching movies has been OK but listening to music is too much for my ears
I plan to separate a dedicated music listening by connecting my DMP A8 to either my old shelved Red Rose Affirmation to a pair of small Leema Xero
Or if price is right to get at least a pair of Topping B200s
And you can try to find the gene from audioholics interview with the main guy from Audy who explains with Crystal clarity why the $20 app is is crap and why the $200 app is actually doing the real deal. I've posted it before but I can try to find it.Because a full Dirac license is 4 X the cost.
Find the video with Gene audioholics and Audy. Audy clearly confirms the differences.Than the $20 app built by D&M that is a huge step up from the built in solutions, but well shy of the MultiEQ-X. It is easy to see from the interfaces of both apps that MultiEQ-X has so many more options and adjustments can be much more precise.
Just a speculation on my part (as neither D&M or Audy wanted to confirm other differences), but MultiEQ-X probably has significantly more taps to deploy, thus advantage of being able to track the curve more accurately. Never spend time trying to prove this, so just a gut feel based on comparing the sound - not worth much. I would not be surprised though as apparently Storm claims that their implementation of Dirac has more taps than the competition.
I know this is old but you are spot on with your post. I still use a windows pc for my movies and music. It's amazing how far ahead of the curve the free programming community was. I am so grateful to the developers of the free use codecs and media players. The industry has always been greedy with thier drm and fair use.I think the problem is multi-fold. When it comes to mainstream sources of content today
1) 4K UHD discs never succeeded on the PC. There was a very small window of time where you could buy a UHD BD drive, Cyberlink PowerDVD, and playback UHD discs. This required fancy Intel integrated graphics with a secure content pathway to reduce the chance of casual copying/pirating. Since you couldn't use AMD/NVIDIA GPUs and Intel removed that feature in later CPUs, it became a dead end.
2) 4K streaming sources like Disney+, Vudu, Netflix, Paramount+ and Amazon Prime restrict video to 1080p on PCs so you're not getting the best performance.
3) As headphones have gotten more and more popular, this is a large market of PC users.
So you can imagine that if the codec gatekeepers cut the licensing fees in half, they'd have to sell 2X as many licenses to end up in the same place. If they only cut the price a little, it's not clear that they would make "a lot more money."
We have well documented science that listening in stereo masks frequency response issues that you can pick up in mono. Listening to movies in surround sound goes even further. I honestly think that high SINAD high transparency electronics is fun for us hobbyists, but entry level Atmos through something like Sony STR-DH790 for $350 is going to sound great for those on a budget regardless of what the DAC SINAD actually measures.
Any updates on Dirac ART? I may sell my JBL SDP-55 and pick up a used AV10 if it's confirmed to get Dirac ART. I don't see any recent news so far, only the old European leak.
