Here are the steps:
1. With speaker delays, speaker gain trims, sub gain, sub polarity and crossover at 80hz in CamillaDSP, proceed to determine sub delay.
2. In REW, set acoustic timing reference to timing reference speaker
(the speaker physically closest to the MLP, example Surround Right).
Decide which front speaker to use to time align with sub, the one that
is closer to the sub is a good choice. Let's assume that is the R speaker.
3. Measure R front (sub turned off, XO active), L front (sub turned off, XO active) and LFE (XO active) using:
- Sweep: 40-120Hz, 512k length (I saw advice calling for 2million but it seemed risky for speakers based on REW documentation)
- Level: -9dBFS
- AVR: -9dB
- Single sweep mode (required when using acoustic timing reference)
4. For each measurement, IR Windows, apply FDW (Frequency Dependent Windowing)
of 6 cycles, and apply to all SPL selections.
5. Go to overlay and choose phase. Under actions, Unwrap phase for both measurements.
6. In the phase overlay view, find the sub delay such that the phase of R and LFE are equivalent at 80hz. (sub_delay6_7.5ms.jpg; L blue, R red, LFE with no delay light green, LFE with 7.5ms delay dark green). Here a sub delay of 7.5ms got the phase of LFE and R roughly equivalent at 80hz.
Some questions for discussion:
1 Should I determine sub delay with 80hz crossover active? I saw conflicting advice on this. It made sense to me that I should do it with crossover active because that is the state in which the sub delay will be used when listening to music and I think the 4th order Linkwitz Riley filter used for crossover may affect the phase (also I noticed that if the LPF for LFE on the Denon AVR is set to 120hz as is common practice, that also affects the phase, so I leave it at 250hz). However, I have some doubt about this. Post 1 here from QMuse measured without crossover but later posts in this thread indicated to perform measurements with crossover active.
2 The sub delay determination must be done after the sub polarity is already set, correct (because the polarity will affect the phase)?
3 Notice in figure that L and R speakers, although previously matched for gain and delay (at a higher frequency than sub range) are still not completely in phase with each other. How to deal with that? To keep it simple, I chose to set sub delay such that the phase curves of R and LFE overlap at the 80hz (crossover point). But what about instead simply setting the sub delay to zero given that the LFE phase sits roughly at the midpoint between L and R at 80hz? Or should I work to get L and R in phase so they are overlapping at 80hz, but if I do that that will throw off the speaker delays (that were determined using a higher frequency sweep)?
Thanks for considering.
