Plus if you are simmering with low levels of volume, SPL together with very undynamic music you don't need that much power.You only need a moderate amount of power to get adequate loudness. You need a ton of power to get really loud!Get as much power as you can. If the speaker can't handle it, it will tell you (severe distortion).
It probably won't be a particularly enjoyable music experience, but only a small Hifi wallet is needed then. That's probably the only advantage.
AND , I almost forgot, it promotes good neighborly relations if you live in an apartment complex.
(solution if thats the case and when you want to go all out loud - headphones)
