Making further progress, TOPPING’s new flagship amplifier will be launched in late May!
B200
200W @ 4ohm, and 200W @ 8ohm (@ same THD) - does it sound all right or remotely possible?
Limited both by current and voltage
TPA3255? I think FOSI is more cost-effective and has more stable quality.
200wpc @8ohm seems a total stretch for tpa3255, unless its those type of advertisements (like Aiyima, Fosi etc).
Reactions: MCH
Anyone got anymore info?
these were off to released in May itself!
These look very similar to E50 DAC!
Google translate says:
From May 31st to June 3rd, the 2024 Beijing International Audio Exhibition will be grandly opened! Tuopin will bring heavyweight products such as B100, B200, DX9, etc. Welcome everyone to Beijing #会拓品# !
[Event Information]
Date: May 31 - June 3, 2024
Venue: Beijing Music Industry Park
Address: No. 8 Heizhuanghu Road, Chaoyang District, Beijing
Booth: Hall 11-17
[Introduction to Key Products]
[B100 mono power amplifier]
● Adopting the world's leading low-distortion technology, designed for audio enthusiasts and professional users
● Self-developed Tanggula module and three-stage feedback circuit technology effectively reduce noise and high-frequency distortion, and improve dynamic range (DNR) and signal-to-noise ratio (SNR) to 151dB
● Ultra-low distortion performance (THD+N < 0.00008%) is unprecedented, ensuring high-level accurate restoration of audio details, comparable to flagship DAC
● Wide load-low distortion working range, three-speed gain adjustment
● Supports use with E70 decoder, can be used to build a stereo system
[B200 mono power amplifier]
● A mono power amplifier designed for music lovers, with the advantages of high power and low noise
● NFCA discrete power amplifier breaks through traditional performance limitations and significantly improves noise control and restoration capabilities.
Up to 200W of powerful output power is suitable for all types of large speakers, and two-speed gain options are provided to flexibly match different needs.
Dynamic range (DNR) and signal-to-noise ratio (SNR) both reach 145dB, THD+N < 0.000075% @4 Ω 5W
Very interesting!
Have they developed their own class D amplification module, like hypex or purify, or used any other vendor chip based design like TPA3255?
Probably LA90D v2!
So they have now fixed the LA90(D) is too weak claim, now this is clean power for sure
Edit: Well, you could mono them previously as well, so price determines if they are something to get..
Very interesting!
Probably LA90D v2!
There some info available on module (from A70 pro details):
Price wise, there isn’t much reason to think it would be around LA90’s price, if not less.
So, probably 1200-1400$ for 2 x mono B200 units takes it to near some of Hypex/Purify stereo modules. If so, a hard pass contender!!!
So are all of these amps rating power at 1khz only like cheap car audio amps of the 80's & 90's? What do they do with full bandwidth? A 1/4 of rated or less?
So, probably 1200-1400$ for 2 x mono units takes it to near some of Hypex/Purify stereo modules. If so, a hard pass contender!!!
B100 x2 supposedly cheaper than LA90. But sure, Fosi mono V3 seems to be the budget king
I thought B100 is likely to be next of PA5/7, and B200 to be next of LA90D.
For price - 2 x B200 vs Hypex/Purify Stereo?
PA5 and 7 are stronger than B100 right?
The specs suggest more focus on it being ultra clean rather than power.
B200 users should get the power as well.
PA5 II has advertised power as 100 @ 4ohm, same as B100.
Like other many topping products, Amir might have one for review to be available around its release time!
