Make your own Speaker wire and or cables RCA / TRS / XLR
Status
Not open for further replies.
You wouldn't like your first finger segments amputated either.
I would not survive as an indoor cat, either!
You pull a cat from the pound and from getting gas-chamber'd.
You also don't want them outside to protect them (cars/coyotes/bugs/?) and give them a happy home with great music piping everywhere.
All you ask them in return is to NOT damage the goods and to not spray the joint!
Sixteen years of long, happy life in exchange for declawed front paws.
Win-Win!
How hard is it for you so twist on a 24 gauge wire to the speaker wire your already using and see for yourself :D
I already stated what I used to know the difference. No measurements with man made devices that all have some kind of short coming in one way or another...
Data measurements are needed when buying Audio gear no doubt about that it`s been a proven and I`ve actually listened to gear and heard the differences the measurements state.
That said those tools are no the end all of every scenario as I have also experienced..
24 gauge wire is cheap, try it if your interested then go after the measurements to find out why.
LOL man made devices. Why 24g wire instead of 22 or 18 or ? What length are talking about here? What differences in measurements are you hearing particularly with what particular gear? It seems maybe too much wax in the ears and an active imagination is more likely than a lot of your claims.
Reactions: MAB
Move your head one inch, that makes a bigger difference than any cable possibly can, especially hilarious constructs like this. :p
I think DIY is popular here, we have members who post tremendous DIY.
On this site it is yes. My reply though was stating that DIY is not very popular in the UK for some reason. I suspect it's because there is so much cheap used gear available over here.
I have often browsed the US Ebay site to find Chinese kits etc. which are not advertised on UK Ebay.
How do you know the low frequencies travel in the thick wire and the high frequencies in the thin wire? Have you tried a third medium wire for the mid frequencies?
Thank you for the insight and apologies for the last reply forums are full of insults and side tracking so I just want to get the point across for the sake of others who might come across this post before the haters clutter it.
I did consider trying a 3rd different sized gauge wire but the upgrade from just 2 different sized wires is so pure I`m assuming it`s all there...?
I have no instruments or know how to take readings or I would dive further into it.
The only issues I was hearing is the loss of the more delicate blended frequencies when using only one thickness of wire.
And adding more wires to the RCA / TRS / XLR ends would be very tight but it`s possible.
That would be a brilliant measurement comparison to see if adding another size gauge between 24 and 16 does anything for purity of all the frequencies.
It would be very interesting to see some measurements I`m sure this is catching on I can`t be the only person in the world to have stumbled across this.
I had very large gauge wire for years might have been 12 gauge just stupid size for my application but the copper tarnished inside, after some researching that was totally not helpful at all I tried using only 24 gauge for all of my 5.1 surround speakers except the subwoofer, only later did I realize the sub cable wire was also about that size....
At 1st it was an improvement with the higher frequencies having more detail, I had a sub so I just left it for about 1 year.
My system was all digital sound then no analog pure direct mode being used.
Then I changed to 16 gauge and noticed the bass was much improved but the Higher frequencies lacked the detail.
I started using analog pure direct mode with a for me newly discovered DAC SMSL SU1. The dac added so much purity it made the listening tests a breeze.
After a while the thought just popped in my mind to try both 16 and 24 together to get the best of both.
So after twisting the 16 & 24 wires at one end I wired them to the amp the other end I left apart then wired the 16 to the bind posts of each speaker and touched the 24 gauge to the speaker binding posts and removed them more than a few times after hearing an obvious difference I added 24 gauge to the 16 gauge of the speakers and sat down continuing with more listen tests removing and adding the 24 gauge from the speakers.
After that I realized it`s time to break out the soldering station and upgrade my other connections. After some trials I decided to share my findings.
I now have an upgraded system thanks to this forum as Amirm`s reviews the data measures helped so much that without that insight I would have never tried anything new just to many liars in the audio sales arena it is very frustrating and most are clueless to the truths anyways...
It`s no help most people who wander in are just like I was 25 ish years ago and wind up buying without much extensive research they just want better audio than those TV speakers or something to listen to music with and have no knowledge of the finer details other than plug and play.
New system: D50 III Dac, L70 Analog volume pre amp with B100 mono block power amps, Wharfedale Aura 2 speakers piano black.
You don't need fancy equipment to detect differences between cables. The most important difference between cables only require TWO measurements, using easily available instruments:
and
That cables create audible differences has been thoroughly debunked here and here and here.
This is the wrong community for you.
View attachment 484124 and View attachment 484125
Do you seriously think that someone with a $710.49 mortgage payment (and a $18k/yr income) can afford a Stanley tape-measure?:eek:
All done soldering up the TRS to XLR wire upgrade so now with all my TRS cables from Dac to pre amp having the wire upgrade and now the newly finished TRS to XLR from Pre amp to Mono block amps I have to say it is undeniably such a great privilege to be your own Man and not a blind follower of the mainstream and there masses.
On a side note I can now push my B100`s further before they go into safety shut down. Of Course this in song dependent as some songs have a louder volume output than others Prior to this wire upgrade B100`s would shut down around -10 db on L70 volume control now I can be a -2db. I tried 1db but they shut down in about 5 seconds.
Make Us Stronger: Artist Ghost Rider. This song has a higher volume then most and is one example before the upgrade I was only able to be -10db now -2db....
This could be ohms resistance related as I have les resistance in my system know.
Keep your nasty replies inside nobody here is listening to you anymore it`s wasted time your only making others hate you not the forum................
Even weirder now.
After asking Amirm for his professional insight about my B100`s extended safety shut down with my wire upgrade I stripped the wires of the mainstream TRS cable wires and found they are all the same 22 gauge wires in RCA / TRS & XLR cables.
I have tested multiple brands of cables and wound up keeping only the higher quality ones so can`t say if even skimpier wire is used in other brands.
Going from a mainstream supplied wire gauge of 22 gauge to 16 Gauge with a second 24 Gauge wire could be the factor at play for ohms resistance.
As stated I`m no Audio engineer or scientist with delicate instruments for testing and use the old school tried and tested scientific approaches of Ears Brain Mind & Instincts so if it`s actual proof of measurements it will have to be someone with that gift to share there work...
Going from a mainstream supplied wire gauge of 22 gauge to 16 Gauge with a second 24 Gauge wire could be the factor at play, could is the key word see below.
Who supplies 22g speaker wire with what gear?
Question to ask is who doesn`t use 22 gauge wire in there cables ?
I've never used 22g in any system in the last 50 plus years myself (at least where it counts, i.e. speaker cables)
If ASR has shown one thing, than it is that this method is notoriously unreliable.
Cables can’t do that.
Well that warrants a....No shit sherlock!
This is just insanity. None of what you are reporting as happening can result from the changes you are making to cables. This is simply not how stuff works.
It is equivalent to me saying:
"I've just put square wheels on my car and now it can fly"
You might be surprised to see the size of the minuscule wire used in your Subwoofer cable, the lower frequencies are current hogs and I find in very concerning as far as audio performance and purity of the source making to the subwoofer.
um, no.
Hey did anyone notice that this is kinda like this thread that the same member started?
the flooby is strong in Mr. Earwax. (curious choice of name, too)
Status
