I measured my AC line a few years back. The result:
Interesting. In Finland we only have small contacts on the meters and contactors are installed in the panels. If you know what is inside the panel then I guess it might really be the surge protector.There are no relays in the panel. The meter itself has a contactor built in to handle the load.
In my past life (40 years ago), I did a fair amount of electrical work - I don't do any these days, as I've not kept up with the regulations.
I watched the electrician install the panel - I know exactly what has gone into it.
I was trying to build up some sort of preliminary case before involving our DNO (district network operator) as I do wonder if it's grid related.When working as an electrician years ago we sometimes were able to loan analyzer from the network company if we suspected problems in the grid, might be worth checking if they would be willing to help?
Gosh that's pretty grim! Worse than mine!I measured my AC line a few years back. The result:
Is it? I mean if we wanted to listen to that sweet sweet 50/60Hz hum with high fidelity then that would be awful, sure. But it seems pretty normal for an electrical grid and I don't think the low SINAD will have any detrimental effect on most electrical or electronic devices.Gosh that's pretty grim! Worse than mine!
Yes, the point I was trying to convey is that while it looks bad to the eye there isn't any reason to think that the noise/distortion on the mains would be causing an issue with electronics or electrical devices that might explain your clicking issue.@sergeauckland @kyuu as I stated in my OP, this has nothing to do with audio quality etc. etc. I know that the PSU in any gear will filter out mains distortion etc., but that is not the issue here.
As I also previously stated, this is about a clicking noise from my mains board / consumer unit (call it what you will) which I believe is originating from the surge protector.
Understood. My thoughts were that there may be some spikes which may not be enough to trigger the surge protector, but may cause some other odd side effect. Sometimes it's such a sharp click, it almost sounds like a sort arc.Yes, the point I was trying to convey is that while it looks bad to the eye there isn't any reason to think that the noise/distortion on the mains would be causing an issue with electronics or electrical devices that might explain your clicking issue.
The soundstage is not to be believed!Looks musical![]()
What method did you use to measure yours? I'm just using a basic step down transformer into a sound card (with some attenuation of course).
THD of 3% or -30dB is normal for mains, at least around here, and it's of no consequence. Harmonics are massively created by mains rectifiers, and filtered out by the power supply. The higher the harmonic number, the easier it is removed. There's no requirement or benefit to low distortion mains.
S
Just for grins, can you post that with a linear instead of log scale for amplitude?
I wonder if that increased THD allowance in the US is due to all the invertors plugged into the grid now. Switching frequency and quality are all over the place.
Here's mine with both log and linear scales.Just for grins, can you post that with a linear instead of log scale for amplitude?
