Pardon me for bending the direction of this thread a tiny bit to pose a question.If I had to pick I'd pick the blue trace, but overall the advice in this thread so far is good.
Your speakers are either too close or too far from the wall, depending on how you're able to place them:
This is an illustration for genelecs but the principle applies to any speaker equally. You should ideally get them a good deal closer to the wall, or more than ~90 inches from the wall.
As others have mentioned a lot of the unwanted variation in your bass is due to the room - placement can help, room treatment can help, EQ can clean up whatever those efforts don't fix, at least in terms of FR.
The speaker placement diagram kemmler3D posted got me thinking. For many of us, placing the speaker flush against the wall or > 2M into the room is not practical, particularly the latter. Unfortunately, I don't have the math or the well schooled intuition to answer the question that the diagram raised for me.
What would be the effect on frequency response if a curved object (like a GIK Polycylindral Diffuser) were placed between the wall and the speaker - the diffuser securely attached to the wall and the speaker back almost touching the diffuser (closer than 1cm)?
I don't suppose this would be a magic bullet, but mighten such an arrangement broaden and reduce the depths of the notches, and thus make DSP solutions more achievable?
