Magnetic materials in TRS to XLR cables
AUDACC
Dallas Metroplex
Magnetic materials in the audio signal path can generate measurable distortion increases in the signal delivered to the speakers. An example is here in the ASR review of a Purifi based amplifier.
https://www.audiosciencereview.com/...ds/buckeye-3-channel-purifi-amp-review.40293/
Investigation revealed that the abnormal rise in SINAD beginning at about the 10 watt output level was coming from a steel tab on the speaker connector .
https://www.audiosciencereview.com/...-purifi-amp-review.40293/page-16#post-1478290
The issue was quickly addressed and the distortion rise was eliminated by replacing the tab with non-magnetic material.
https://www.audiosciencereview.com/...-3-channel-purifi-amplifier-review-2nd.43834/
The distortion effects of the magnetic materiel in the signal path seemed to rise roughly proportional to the signal current.
I have a pair of Monoprice TRS (balanced) to XLR cables to connect my topping D50 to the Buckeye amp I have on order. A quick inspection with a magnet reveals that there are magnetic materials in both connectors. Will the current in low level signal cables be high enough to cause detectable distortion generated by the magnetic materials?
Have there been any ASR reviews of cables that found this to be an issue?
Almost certainly inaudible (and probably unmeasurable) at line level voltages and currents.
There you have it. 10W upwards means large current, like 1A or more. That generates a significant magnetic field, and interacts with magnetic materials, creating that measurable distortion.
Now, the average line connection is, say, 1V into 10kOhm, makes 100 microampere. That's zero for practical purposes, regarding magnetics. I doubt it's possible to measure even, outside a laboratory worth millions. It must be way below the inherent distortion and noise of even the best available audio equipment.
Zero concern.
