fabrizzio71
- Joined
- Oct 1, 2020
- Messages
- 11
- Likes
- 16
Hello Everyone,
I received my Magnepan LRS about 2 days ago. I was researching measurements because I was curious about measuring panel speakers. My previous setup was a pair of Audioengine A5+ paired with an SVS S2000 sub. My listening room is 19' 7" long, 11 ft. 6" wide with a large 4'9" x 6'8" opening into the rest of the house about 2/3 of the way back on the right side wall. Ceilings go from 8 ft to an 11 ft peak exactly in the center of the room and then back to 8 ft at the end of wall.
I am in no way an expert on measuring speakers. I did read through all the measurements and discussion from the original post here and thought maybe my contribution would be informative. I used REW to create a measurement with the Magnepans alone. My amp is a Parasound NewClassic 2125v.2 (About $600). It is brand new and I bought it specifically for these speakers. I think it outputs 225Watts into 4 ohms. However, there is a switch for 4-8 ohm load and 2-3 ohm load. I have it set to the 2-3 ohm load setting, as that is what Parasound recommends for anything that dips below 4 ohms and I know these dip to 3 ohms. I also have the switch on the Parasound set to only send 40hz and above to the speakers. The measurement mic is a Dayton Audio EMM-6. I have the speakers 4' 4" from the back wall and 2 ft. 5 " from the side walls, and I am sitting about 9 feet away. The mic was placed exactly in my listening position. I have not done too much playing with setup, but I did play with toe in and adjust the speakers forward some. Using a separate decibel meter, I did some experimenting with tone generation in REW gradually increasing and decreasing frequency. There were clearly nodes in which certain frequencies dipped. I also did some preliminary integration with the subwoofer, setting phase and cutoff frequency although I have not decided yet what cutoff to use. I still need to do more testing. I will say that I have never had bass sound this good. I had it paired with the audio-engine A5+ cut off at 80hz and I used the same integration process I am doing here, so I'm not sure why the bass sounds so much better and clearer with the the Maggies. I can also share some of my REW graphs with the sub if anyone is interested. It does affect the higher frequency dips some depending on what crossover frequency I set.
