Vuki
HiFi is for one person at a time. Everything else is compromise.Yes it looks as for head phonesthat magic sweet spot is not for more that one person at a time..
Congrats! Longest sentence on the forum... Okay opinion and experience for whatever systems youself had been through, myself had down the road reach some other experiences but have to rebuild system to get rid of the last bit of small discovered distortions before will feel for document such stuff for example via some in room recordings playing normal track material, that said had to admit system is not real time in it takes time to repair for time distortions
If i need to make any measurements of a big planar to proof or disprove a point, just tell me what to measure from what distance etc. i can whip out a quick one. (only in room responses, not feeling like going outside, or 3ms gates ones)
So measuring mic at listening position where the audio recorder is sitting in the video ? since that will bring out the room modes allotMake one REW measurement sweep with both speakers active exactly at your listening position (my mic is between where my ears would be) save the measurement (that's a .mdat file), zip compress the file, and you can post it right here if less than 2 meg (if that restriction is still in effect).
I measure with the mic pointing at the phantom center.
(looked at the beginning of the file above - setup looks appropriate)
Quick RTA from your video:
Choir around 5min
Strings around 6 min
Guitar Singer around 9min
Seems to have a little lift in the 6-12kHz range...
Strings fill the midrange, pretty flat response there...
Maybe not much below 50Hz, but don't know if the content had it. Maybe not.
Sounds good to me, though.
Room might be a little bit "live", but, so what.
PS: Oh... Not using a "measurement" microphone.
My handheld recorder is not very "accurate". Yours, ???
but ok both active on my sofa? eq disabled ? (only used eq for room nodes 100 hz and down)
I measure where I listen.
I measure how I listen.
Sometimes EQ, No EQ comparison, but always centered* at the listening position unless there is some unusual experiment to be performed.
I'm not designing speakers - you are - so measure as necessary to meet your goals.
For "listening measurement", I use "listening position".
Too logical, huh.
*centered - that's within a couple of millimeters of center - REW can pin it down very precisely using Acoustic Timing Reference and comparing the arrival time of the direct sound from the left and right speakers.
Usually measure left, and right, and both speakers, if being picky about something. The combination is sometimes different than the individuals. I have a hole at 48Hz when both speakers play, due to phase cancellation in my asymmetrical room, for example. Here, left, right, and both:
Too logical, huh.
*centered - that's within a couple of millimeters of the acoustic center - REW can pin it down very precisely using Acoustic Timing Reference and comparing the arrival time of the direct sound from the left and right speakers.
dont know what kind of room you have but that looks scary flat... i dare to say ...... you room corrected the shit out of it ?
Uncorrected added above.
Yes, I'm using a miniDSP OpenDRC-DI and AcourateDRC, with "flat" selected as a target.
My "goal" is to reproduce the electrical signal on the recording acoustically at the listening position. I get close. Compare the combined raw signal from the source with the response seen by the measurement mic of the EQ'd speakers at the listening position.
I don't get any complaints about the sound when it is heard, only about my method when it is explained.
by the way weird that you have a rising top end ?
A little there, not much. Maybe a sagging midrange would be a better description.
Why do you EQ your speakers to flat at the listening position? Wouldn't that make the sound unnatural? You're basically forcing the speaker to output boosted frequencies from the source material in order to make it flat at your listening position. That wouldn't be how sound normally travels to you from a source? I imagine your setup sounds very bright at the listening position.I measure where I listen.
Usually measure left, and right, and both speakers, if being picky about something. The combination is sometimes different than the individuals. I have a hole at 48Hz when both speakers play, due to phase cancellation in my asymmetrical room, for example. Here, left, right, and both, with, and without EQ:
View attachment 85737 View attachment 85738
Too logical, huh.
No you didn't ask that.Why do you EQ your speakers to flat at the listening position? Wouldn't that make the sound unnatural? You're basically forcing the speaker to output boosted frequencies from the source material in order to make it flat at your listening position. That wouldn't be how sound normally travels to you from a source?
Okay, maybe I wasn't supposed to ask! But it does go against all the science regarding loudspeakers on this Audio Science forum, so I thought it was pertinent.No you didn't ask that.
Ray has described before how he shoots for flat despite everyone saying measured flat in room is too bright. It suits him, and he also admits some high frequency hearing loss.
Maybe we could ask Sal for an independent appraisal as he has heard Ray's system. Or probably we shouldn't.
Not trying to speak for Ray, but I know his approach has been discussed a few times before.
I was just funning with you a bit. You are correct it goes against what we know, but Ray knows that and prefers it the way it is.Okay, maybe I wasn't supposed to ask! But it does go against all the science regarding loudspeakers on this Audio Science forum, so I thought it was pertinent.
