Random listening comparison test of LRS and Emotiva B1+ speakers: (& Dirac on two separate speakers)
Since I still only have one Magnepan LRS panel, I hooked it up right after this review up curious to listen to stuff in mono without room correction to see if perhaps I was nuts thinking that I was wrong about the magnepans?
Didn't get it set up exactly figuring it wouldn't matter much in Mono. Not going to lie: it sounded pretty bad! So bad that I bought some Emotiva B1+ speakers thinking maybe I'd replace the LRS's with them and save some money
The Emotivas came in the mail and they feel quite heavy duty ... nicer quality build than the JBL 306mkii's I had! Hooked them up and since they are passive ... no hiss! So I ran Dirac + hooked them up to my dual subs. I noticed instantly with or without dirac that I'd have problems trying to mix vocal range material on them as the midrange was sort of there but not easy to discern. I had the same problem with Adam A7x's in the past to be honest though which is why I quit using them.
I hooked up one B1+ on my left and my single Magnepan LRS on the right. (Using a Purifi Amp) (Each with their own separate subwoofer as I'd always use subs anyways)
#1 : I didn't angle the Magnepans properly the first time ... just a couple of inches off made the treble go way down! So yes: they are really sensitive to angles!
#2 : Without any room correction or using subs: the Emotiva's sound
much better! I can actually hear the bass parts! The Magnepan sounds 'taller' though as it's essentially sound coming at me from 2' below and 2' above my ears but it has barely any low end and lacks the bright highs of the Emotiva. I can barely hear any bass or kicks. It's pretty boring/bland. Voices do sound closer to what someone speaking to you normally would sound like though vs the Emotiva where it sounds like it's a voice coming from a speaker/tiny if that makes sense.
#3 With Dirac & Two Subwoofers:
I ran Dirac unsure of how it would handle two completely different types of speakers: It actually worked pretty well! I have them on each side of my 4' wide desk as nearfield mixing speakers about 4-5' from my head. For general listening it's not too bad with the two completely different types of speakers but obviously I wouldn't trust mixing on them. The strange thing is adding the LRS sounded better than having two matched Emotiva speakers ... I didn't expect that.
So with them both calibrated with a SPL meter equal distance to my ears and using keyboard shortcuts to switch from speaker to speaker it's pretty easy to tell the difference.
The Emotiva sounds like ... a small speaker. If you shut your eyes you know it's coming from a speaker and you'd be able to guess it's coming from a small speaker: even with the sub. The Magnepan + the subwoofer sounds like a wall of awesome sound at my nearfield distance.
The bass is actually better on the LRS now. The Emotiva will distort or just get more compressed sounding in the midrange/bass at louder volumes but the LRS stays clear. Voices and Midrange are much better on the LRS side also. Admittedly there are some things the Emotiva does that the LRS doesn't. The Emotiva does have a bit more in the super high frequencies though. (Though I suppose with the more expensive Magnepans they have real ribbon tweeters ... for example the Mini Magnepans I once had definitely had way better highs than the LRS)
It's like some things do sound a bit clearer on the Emotiva's due to the high end ... but it's mostly things that probably get fatiguing after a while anyways like the top end of a cymbal crash or things that many people can't actually hear above 16khz.
One thing that is important for me is the midrange for mixing. One example is on a certain song ... on the Emotiva's things sort of blur together - a chorus sounds like one voice coming from a small speaker. The LRS's on the other hand, the voice not only sounds more natural but I can tell that there's 4 actual vocal tracks that add up to one single chorus line.
I then used Equilibrium and EQ'd full tracks as if I was mastering a song & I do it on one speaker and then the other to see if I'd do it the same. For the most part it's pretty close: essentially showing that even with the different presentation of either speaker: I'd still make pretty close to the same EQ decisions which is good.
If you have no subs and no Dirac: don't get the LRS! As far as the Emotiva ... I'd personally probably rather get another pair of JBL's in the future if going that route ... at least as someone who mixes. If just listening for fun the Emotiva's are fine for the price. I have mixed on NS10's and Genelecs in the past at other studios long ago and personally never liked them. ProAc and big PMC mastering speakers weren't really my thing either. I do prefer mixing on full range Electrostatic speakers more than Magnepans though. I also like B&W 802d's whenever I've heard them. - so take that into consideration for my tastes.
