- Joined
- Jan 23, 2020
- Messages
- 4,336
- Likes
- 6,705
Thanks for taking this step. Hope this can be included in all speaker measurements.
This is very different from the predicted Klippel in-room response and what people interpreted based on that and the subjective interpretation. You have to look at it with a filter of room modes especially with a single location measurement. It can be very, very different a few inches away. This is why either a multi-position or RTA sweep (as I had suggested) is necessary for any meaningful room correction. You can do this with REW on a PC with no additional set up necessary. Less than a minute for RTA waving your arms about like a music conductor!
First of all there is no 300hz exaggerated response (this should raise eye-brows about interpreting based on Klippel measurement). Note that some of the interpretation was based on this fall off from 300hz implicitly or explicitly.
The bass extension target is influenced by the deep nulls at 100hz and at 40hz. These are room mode characteristics. If you used this target for REW it would justifiably complain that too much of the area is below the target (primarily because of the below 1khz fit). The target could be quite different if the 100hz null didn't exist.
If I were to equalize this as-is I would pick a +75db flat line for the region below 1khz and ignore any corrections for the nulls or below 60hz. And use a shelf filter to lower the entire tweeter range by about 5db to get a better balance if it could not be achieved by changing the attenuators. The localized nulls would have some effect on clarity and fidelity of lower bass but not necessarily tonal balance.
If I were to evaluate this graph on its own to optimize it, I would say the tweeter range seems to be elevated relative to the low/mid range. This can provide a perception of lower bass content. One can justifiably knock the LRS for this tweeter vs low/mid ribbon balance if it wasn't related to room modes. Or one of the the supplied attenuators might balance it better. With this as is, it would sound too bright and thin.
I would then experiment with both distance from the back wall and the toe-in to affect the null. This is where some of the well-deserved "reputation" for Maggies to be picky about placement comes in.
I don't think it's really fair to say "the target could be quite different if the 100Hz null didn't exist". While true, you could also say "the target could be quite different if the 70Hz peak didn't exist. It would be much lower". The 70Hz peak is as much of a room node as the 100Hz null. I think Amir did a good job of drawing an average line through both the peaks and nulls. This is also why I like the PIR approach of drawing an "average", though in this case it does seem like the PIR calculation doesn't work all that well for panels. It looks to be about 100Hz off(300Hz vs 200Hz) in where the roll off begins.
I agree with your idea of shelving everything down 5db or so. That does cut into the already limited headroom, but it gives you enough extension to reasonably cross to subs(imo).
