Magnepan LRS Speaker Review
BYRTT
Denmark (Jutland)
Anyone having bass light speaker system and no tone controls to dial on we learned in past at ASR site that there is a alternative if one fire up the temperature like hell in the listening room, below was Amir's Klippel analyze of KH 80 out in the garage in winter time verse summer time :D..
tomtoo
Germany
At least this speaker should not react so heavy on temperatur in the bass department like the kh80. *rofl* Hope someone understands the joke. ;)
BYRTT
Denmark (Jutland)
Another solution for bass light dipole users is to listen to their speakers placed on the ground instead on top of a 4-foot elevated platform.
Allow me give a note here, yourself probably already know and understand it right but there was some misunderstandings down thread where some thought LRS was measured non anechoic then it looked some thought the anechoic measurement had floor boundary gain included below the 4-5 foot elevated Klippel platform.
For Amir's published objective data there is no boundary's included so forget the elevated platform height, data is pure anechoic and that Klippel wonder machine can calgulate and extract what is floor/cieling/wall reflections in the garage so spinorama data is a pure anechoic presentation.
For Amir's listening test there is also no elevated platform height or at least he would probably tell it then, listening tests are normal done upfloor in his lab and for LRS it was standing on the floor.
CDMC
Perhaps because it's all wheel drive with automatic tranny? Cars I've dynoed over the years were all stick shift performance cars and typically had about 15% losses.
This was an entertaining diversion, but it's time to get back on topic...
Automatic, full time 4wd, big off road tires. But to keep this on point, you tell me another vehicle that has the room to set up a pair of LRSs in the rear. :)
NTK
US East
Well well, NFS needs a multiplexer for tall speakers/line arrays with multiple/tall drivers having same band... I have mentioned this before, but Amir responded that it applies for PA tower. Who is right here I'm left unanswered!
https://www.klippel.de/products/rd-system/modules/nfs-near-field-scanner.html
The sound pressure output of loudspeaker systems with multiple transducers (line sources, sound bars, 3-way systems, etc.) can be determined by measuring each transducer separately using a multiplexer. After the holographic processing the sound pressure of the individual source can be superimposed to determine the total sound pressure output of the audio device.
Measuring drivers individually is mostly for measurement efficiency and practicality. But when a certain point of complexity is reached (e.g. CBT's with a couple of dozen drivers) it will probably become a necessity. For large panels, I don't know if there are solutions other than lots and lots of measurement points.
http://www.klippel.de/fileadmin/kli...Notes/AN_70_Directivity_of_Speaker_Arrays.pdf
[Edit] For large (and mostly flat) panel speaker, planar NAH may be more suitable than spherical NAH, but I am pretty certain the Klippel NFS doesn't do planar NAH.
KaiserSoze
Oh, come on. You are playing semantics by conflating "actual" to mean both direct and indirect measurements. The latter differentiation is common and people colloquially use actual synonymous with direct as opposed to indirect.
When you take indirect measurements, whether they correspond to the same measurements if it were to be measured directly depends (not on math as you erroneously say) but on the computation/formula used to arrive at the direct measurement. In some cases, the formula is exact (V = IR, for example, where you can measure any two directly to get the third indirectly) which is where you seem to be stuck at or it is an approximation from a model because the direct measurement is often impractical to do but the indirect measurement may be good enough for the purpose. But the latter requires separate validation that it is indeed a good representation of the direct measurements if it were possible. This is not an issue of math but the accuracy and precision of modeling that enables indirect measurement to imply a value for direct measurement. Climate change, astronomy. acoustics, quantum mechanics, all involve inexact models to infer a value that cannot be directly measured.
There is no problem in doing so as long as people don't assume the model is necessarily exact and are open to the idea of models being wrong or requiring refinement as one gathers evidence. That is the way most of science works. Not by bringing in metaphysical concepts of what is "actual" to obfuscate the issue.
No, I am not playing with semantics at all. Not in the least. Nor am I "stuck", nor did I "erroneously" say something referring to math instead of to the use of formulae, or whatever it is exactly that you mean there. You clearly have made the assumption that your understanding of this stuff is perfect and that I am just being silly. I implore you to be less hasty with your assumptions and conclusions.
One of the fundamental difficulties with dialogs of this nature, concerning philosophy-science, is that most people simply don't have any appreciation for the degree of linguistic precision that is needed with dialogs of this nature, in order for them to be truly meaningful. It is necessary to abide a high degree of linguistic precision, such that ambiguity is fully avoided. The importance of this cannot be overstated.
You have provided a clarification of what you (or maybe someone else, it doesn't matter) meant by "actual". This was good. You assert (strongly in bold) that people colloquially use "actual" synonymous with "direct" as distinct from "indirect". Okay, but it matters nought whether this is or isn't a colloquial practice.
To make clearer what is meant by "actually" in this context, you now talk about "indirect measurements" vs. "direct measurements". I am expected to know precisely how you define the two, such that I would know with absolutely certainty which measurements you would deem "direct" and which measurements you would deem "indirect". I am afraid that I fall short of this expectation. I think I might have a fuzzy idea what you might mean by this, but we would both be fools were we to permit this dialog to go further without first making entirely certain that what you mean is entirely clear to both of us. It is absolutely essential for you to state the necessary and sufficient conditions by which some particular measurement would be deemed an "actual" measurement.
Once you have made it entirely clear what the distinction is, between a direct measurement and an indirect measurement, the next step is to inquire into whether the measurement of torque taken on some class of dynamometer meets the necessary and sufficient conditions such that it would be deemed a "direct" measurement. You are most likely thinking at this point that the distinction between a direct and an indirect measurement is self-evident and that it is silly for me to ask you to define this distinction. But as soon as you start to think about this question seriously, you will mostly likely change your mind. Or at least I hope that you will.
I want to suggest a few questions that you may find relevant, as you ponder the question of how to define the distinction between direct and indirect measurements. How exactly is the measure of torque obtained? Does it involve taking a measure of force and multiplying it by a predetermined distance? If so, how is the measure of force obtained? Does it involve a strain gauge? If so, is force inferred from a reading of voltage? If so, is the voltage measured by way of comparison to calibrated voltage sources and using calibrated resistors? What is involved in the calibration of the calibrated voltage sources? Are they calibrated by way of comparison with other voltage sources, or how exactly?
If you want the easy way out, all you need to say is something along the lines of, "A direct measurement is a measurement that is directly taken."
Joppe Peelen
Den Haag , Netherlands
any idea what kind of differences one might expect between the 2 ?
Vasr
Works for me and for anybody that isn't into pedantic/philosophical nitpicking. ;)
Joppe Peelen
Yep!
Nope! I can't spit that out in a few minutes ;)
But of course you can quickly try out what happens if for example the backside sound radiation is damped a little bit and additionally a first order lowpass is realized from 500Hz - so the dipole is not ideal anymore.
Then the free field result (4m distance) is much better (red curve is SUM):
i understand !! i dont expect you to spit them out :) i just wondered.
mine might look a bit different because of it (although mine is not gated anyway , so mine are influenced by my room to) so who knows :)
anyhow thanks for the sim !
Francis Vaughan
Adelaide Australia
in conjunction with a compatible interpretation of quantum mechanics such as the many-worlds interpretation
Well yeah. Assuming that compatible model. My point is that that is a philosophical question that is still totally open. It gets near religious talking about which if any of those models to use. Personally I think many worlds is a very weak model to choose. But I can accept that many others find it the most appealing of what is a pretty poor set of choices. Decoherence is a key part of the puzzle, but IMHO alone insufficient to close the problem. It shifts the goalposts more than answers the question.
BillG
Auckland, New Zealand
But I've never heard anything like these Maggies.
When I reconnected my previous B&W box speakers and listened all I could hear was a box. Surprising to me since I never heard the box before. Clearly, for me,in my room, there's something going on with the LRS that the measurements aren't ,or can't, measure.
I can make eliminate the boxiness of a pair of box speakers by aiming one of them at a wall angled in a way so that a lot of the sound is scattered with a good portion bounced to my listening position and leaving the other aimed at directly at me. The result is something akin to an all encompassing sound field and quite marvelous to behold. In terms of the physics, I can't say since I've never bothered to research it. However, all of this - the time delay between the two sources, frequency response, and phasing - can be measured.
rmsanger
I own the Maggie LRS and love them for me they are perfection! Driving them with a Hegel H160 integrate + Sumiko S.9 sub... All in I got it for $2500 and am very happy for the money invested. Yes they are finnicky for placement and require a significant space from the back wall (e.g. 3ft min). I keep them against the wall when not listening and then move them out when I'm using it. There is a very defined sweet spot based upon the twitter ribbon positioning. They are also very finnicky with their amplification but the Hegel pairing is quite great.
RayDunzl
Central Scrutinizer
Riverview FL
You love them, or you love them not...
anmpr1
I believe that amirm's excellent measurements and expert criticisms of the LRS are all correct. So why do they sound so good to me in my room? I've owned lots of dynamic box speakers in my 50 years as an audiophile. Some of them very good. But I've never heard anything like these Maggies. When I reconnected my previous B&W box speakers and listened all I could hear was a box.
The boxy thing is something I have thought about a lot over the years. I know a couple of dyed in the wool dipole enthusiasts, and the whole boxy sound comes up a lot. So, my personal take on it is that indeed, some boxes have enough internal resonant modes that are not well managed that they colour the sound.
No matter how much designers brace, damp, partition, or otherwise attempt to 'de-box' the enclosure, there will always be a box, and it will always 'color' (or otherwise artificialize) the sound. Then there are baffles.
In the forties and fifties, very efficient and very large boxes and horns were an attempt to debox. All with varying degrees of success. Edgar Villchur made the box small, domestically unobtrusive, and relatively inexpensive. Since then small boxes claimed dominance, and since then manufacturers have been working ways to get rid of the very box. Siegfried Linkwitz spent his life attempting to debox (and debaffle) in order to rid himself of the effect.
Negative (or at least questioning) comments about dipoles are valid, and well noted. Panels have their own peculiarities--often times disqualifying (depending upon one's choice of the varying loudspeaker trade-offs). But boxiness is not one of them.
Francis Vaughan
Adelaide Australia
Maybe. One thing I notice constantly is that what actually is the nature of "boxy sound" is not clealry described. It is quite easy to remove all internal resonance from a box. Similarly make the construction of the box resonant free. It isn't exactly rocket science. Whether this removes the boxy sound is another matter. But killing off those particular issues isn't hard.
The trouble we have is that all loudspeaker reproduction is inherently flawed. This also isn't exactly rocket science. We know a-priori that it is intrinsically impossible to reproduce the original event. Everything is a compromise and the trick is is picking your battles. Dipole speakers pick one specific battle - that of trying to generate an enveloping sound in the room that seeks to emulate the spaciousness found in a performance venue in a space that intrinsically is not able to support such a sound. So it is an illusion. Linkwitz theorises about making life easy for the ear-brain system to build a new illusion of a spacious immersive experience from a simple limited two channel recording. He is quite clear about it being an illusion. There is no pretense that it somehow magically recreates the real sound present during the recording. Just a pleasing illusion. It is artificialising the sound just as much as reproducing the sound out of a boxed speaker might. Just in a different manner, but arguably in a more heavy handed manner.
IMHO there are some important things going on here that are worthy of deeper work. What seems to get in the way of this are the polarised viewpoints from each side, expressed here just as badly as anywhere else.
Newman
....It's true that the orientation relative to a room-mode null matters, but in practice, dipole woofers have smoother in-room response -- this is apparent both in emulation and real-world measurements and likely a major factor in their more natural sound. A speaker designer I know tried some experiments and found that he could equal the quality of two dipole subwoofers but that he needed a swarm of four dynamic subwoofers to do so. On the other hand, Siegfried Linkwitz believed that the steady-state frequency response was not the differentiator:
"I have investigated possible reasons for the qualitative difference between monopole and dipole bass reproduction by in-situ measurements and scale model experiments. I am convinced that the steady-state low frequency response is a poor indicator of the quality of bass reproduction, other than to point to the one or two modes that need to be equalized. The strongest correlation between measured data and subjective impression appears to come from a modulation-transfer-function measurement which is analyzed in the time domain. For example, when a short length of a 100% amplitude modulated signal with a carrier to modulation frequency ratio of 10:1 is used as stimulus, then the room response reduces the depth of modulation and increases the burst duration for different frequencies and room locations. A pattern seems to appear whereby the modulation envelope is subjectively preserved more frequently with a dipole than a monopole. This correlates strongly with the impression that bass reproduced by a pair of dipole woofers is more articulate and thus more realistic of the recorded source."
Interesting, no?
Actually Linkwitz recanted the above early thoughts in later life, and agreed with Toole's position.
Sorry for late replies, I am just catching up on this thread.
