Other than stated by several posters I do think that
@amirm has done enough measurements to describe the behaviour of the LRS in anechoic conditions. Even enough to somehow find the cause of the 'magic' sound. We just don't have enough knowledge (or done enough work) yet how to correctly interpret the results into how the LRS sounds in a room where it is optimal positioned. Clearly neither the Klippel's on axis FR nor
@John Atkinson 's FR show directly what one would expect to hear in an optimal room, especially below Schröder.
Where the LRS is different compared to a conventional box speaker:
- Almost no dispersion at +/- 90 degree
- At 180 degree same dispersion as at 0 degree but with 180 degree phase shift
Surely this kind of dispersion leads to a very different in room response compared to a conventional box speaker. IMV this is not a flaw but a characteristic feature. No side reflections should lead to
less room influence, OTOH throwing the same sound at 180 degree phase shift leads to more
room influence above Schröder. While I had MG 1.6 I did not treat the room but I can imagine that treating the front wall to dampen reflections above Schröder may reduce room influence. Less room influence is good for lively rooms or when one wants to hear what's on the record.
- Tweeter and woofer side by side with too large distance.
This is a major flaw and leads to a bad horizontal dispersion. It could be improved by using a DSP crossover with very steep flanks (48 dB/octave) to minimize the region where the flaw is audible.
- It looks like a line source but it isn't. It neither goes down to the bottom nor to the top of the panel. Nor is it shaped as a vertical curve which improves the sound field over distance (see @Floyd Toole's book where different line sources are compared).
I consider this to be a major flaw as well because there are only disadvantages (extremely narrow vertical sweet spot due to the vertical size of the tweeter) but not the (desired) behaviour of a true line source. Still a narrow vertical dispersion reduces room influence and may have a positive effect in very lively rooms.
- Large moving area means for the same SPL excursion of the foil is lower compared to a conventional box speaker.
This should lead to low distortion since distortion increases with excursion. However with magnets on one side of the foil the membrane does not move in a constant magnetic field which increases distortion - at least in the low frequencies where excursion is high. I have no clue which effect is stronger.
- Acoustic shortcut in the bass
This is a flaw, but one which cannot be circumvented. Some posters claim that placing the LRS on the floor dramaticely improves bass compared to the measurements taken off the floor. This cannot be true. Most of the bass gets lost via the short side. There will be an improvement but only a minor one. To get better bass you must place the LRS at such a distance to the front wall that the wave leaving the back of the panel reflects such at the front wall that it sums up with the wave leaving the front of the panel at a frequency where the shortcut has damped the far field SPL by 6 dB.
- Very low sensitivity (~78 dB when one ignores the unwanted hump at 250 to 900 Hz)
This is not a flaw per se but buying a cheap speaker which then requires tons of stable power at 4 Ohm is not very economical. We have seen that investing most of the budget into the speaker is the best approach to good sound for less money. The hump though
is a major flaw.
My story:
As I wrote elsewhere I owned MG 1.6 for 13 years and then switched to active 3 way studio monitors (later accompanied by a sub). As far as I remember the sound of the MG 1.6, driven by the mighty Denon POA6600 monoblocks, was:
- muddy mid bass
- no deep bass (which I did not miss because I had never had speakers before which were able to deliver deep bass)
- big soundstage but very fuzzy
- bad dynamics
- very smooth upper mids
- very forgiving with bad recordings
- nice for classical and jazz
- people who had a listen usually liked them, some a lot
The switch to a studio monitor happened when a colleague asked me for help choosing good speakers. He liked the MG1.6 but did not want panels due to optics. We went through a lot of hifi shops and finally into one which had a pair of the biggest Gaithain's playing. That was the best sound I've ever heard, but far out of financial reach. SInce these were studio montiors we visited the local musicians store and there he finally decided to get the K&H O300D.
I liked them as well and when some 6 months later I saw a very good offer on Ebay I could no longer resist and bought them on the spot. The first thought which entered my mind when I listened to them in my room was:
"I did not know the Maggies were sooo bad!"
Thats a nice write up !!! read it a few times ! although i dont agree on maggies being bad. Gaithain'? never heard of them since called monitors i thought some , studio monitors... but
they are not. they are coaxial, i do agree very pleasing , fullranges or coax every now and then, they can sound really nice. never heard this pair though
If i may add some of what i think.
- Distance tweeter woofer. is 7 mm, and crossover is half that of any monitor, should not be any problem. the fact the tweeter is rather wide compared to a dome might be a problem ! and beams
- The fact it does not look like a line source, and maybe you meant that is it should go to the ceiling. and it does not.
- Acoustic shortcut is just how open baffles work just like the dispersion being almost 0 @ 90 degrees. its the same problem.. although i dont see them as a problem. an open baffle might not PUMP as hard as a closed speaker, allot of people like them, and weirdly enough this is how many of the beloved drum solos are recorded with the most wanted mic... neuman U87 , mostly used as a dipole..
cool you mentioned the hump
, also to make use of the back wave, you would have to need more then 3.5 meter behind the speaker
hihi thats allot for a small speaker.
- Distortion.
Finally someone that understands it
go big or....... have more distortion
- Low sens
Very true, glad you dont see that as a downside, im not doing marketing for magenpan
but i am always wondering why people want high sens... since if you do go active.... nothing matters. and if not if you manage to make a complete set with low sens... well.
Everyone can afford a powerfull amp nowadays with class d
4 ohm is not weird, and especially in class D they like 4 ohms
so even 100 euro class D modules will make them sing loud enough. i even used the 15 euro boards on a ESL63 no difference in measurements either.
By the way being a cheap speaker does not change a thing. even the more expensive ones are 4 ohms. (and same efficiency according to them 87dB
at 500 of course, 2.85 volt into 4 ohm so 2 watt not 1) so you still might need to use the same amp, since they are not much more efficient. maybe they can handle a bit more power though. in the end they all have the same Xmax (at east all the maggies i've seen) so what they could have done is doing the base in parallel.... and gain 3 db.. but then again the tweeter cant match
so they did not and chose for more power handling. in the end the x max stands for a max SPL no matter how you reach it, if they would be more efficient they would stay play as loud at max volume as they would with ****** efficiency. except they are a bit more rugged
and the tweeter matches up without to or even any padding
I have both studio monitors and planars, and occasionally ESL's and although i love them i would not mix on them. mainly because i know how they sound compared to other speakers. and either bad or good. i make somethign to be used for well.... the other kind of speakers. besides that, doing editing i prefer doing it near field. and not on dipoles
love them... but not for work ! kind of have to hearing what they are hearing unfortunately.
