Harman Kardon
It's a legitimate beef. Tests should be blind to eliminate bias.
Isn't Harman Kardon is a different division of Harman? Did they really use employees from the Harman Kardon division?
(My previous post was tongue-in-cheek pointing out the all-too-common misuse of HK when referring to Harman.)
Yes of course spin isn't everything. I'm just saying that all this nice "stuff" doesn't mean anything if it doesn't actually improve sound objectively, regardless of what that objective measure is.Spinorama is not the end-all.
The Spinorama doesn’t show you anything about nonlinear distortion, which is a significant part of the overall SQ (what happens when SPL increases, etc.). The same speaker in MDF enclosure would sound completely different than if it was made out of fiberglass or aluminum, yet it would look the same on the Spinorama. And, yes, it is objective, you can measure it, if you only choose to.
sounds somewhat puzzling given all praises and recent f226be review/test from Erin. I only have f208 and have had no chance to audition neither BE version nor any Magico so cannot compare unfortunatelyThe Revel also sound more strained and grainy as SPL increases
When you say "biased", do you mean that because the subjects have been trained to prefer neutrality, they will be biased against a speaker like the A3 that has a less-neutral presentation? This seems a fair criticism IMO.
Harman Kardon
Yeh, I also would have expected the 228 to be more preferred. I don't see much of a difference in DI around the midrange though, maybe just a slight difference around 200-400Hz...? My guess is that it has more to do with bass extension.
It is possible that a lot of Revel employees are able to recognize their own product in a blind test. Which defeats the purpose of a blind test.
Here is a similar case where they even graded their own product worse at a sighted test http://seanolive.blogspot.com/2009/04/dishonesty-of-sighted-audio-product.htmlNot really, from what I've read. I mean, Im sure it happens occasionally, but once three speakers are in the mix, things get more complicated. I'm pretty sure I've heard about about Harman engineers picking bookshelf speakers over their more expensive towers sometimes too and swearing it was a tower they were listening to.
And then there is sample selectivity. Testing such a very specific subgroup is probably not very informative for predicting general population preferences (whether or not that is the right target for high-end speakers is another question).
Stereophile's measurements of the F228Be and Salon2 make it very easy to the Salon2 would appear to have a significantly louder and, probably, more precise-sounding soundstage.
That's because it's a--let's say exaggerated--statement. Either he is listening to them at above 110 SPL at 5 meters or more (in which case a PA system is more suitable--or maybe it's his ears giving out at such a high output) or it's a declaration that he has "magico" ears.
Is it really so inconceivable that he prefers the Magicos partly/mostly because of how they sound? I agree that psychology could be - must be - playing some role here (it always does), but it also seems, based on the measurements we have, that the Magicos have a more laid-back presentation with a slightly recessed upper-midrange/low-treble (@HenryB, we await your measurements!). And perhaps they have better bass extension and/or their sealed bass alignment better complements Henry's room. It's not as though there appears to be anything drastically wrong with them.
I just don't find it so inconceivable that someone couldn't possibly favour this kind of a tonal balance. And I also think it might explain why the speakers seem easier to listen to at high SPLs.
No, not at all. It doesn't matter that he likes it more. Who cares. But I was very precise about what I found troubling. Please re-read the post.
Indeed possible, but I believe it is its more then that. Distortion measurements could have settle that. I am surprised a capable compony like Revel does not go there.
Indeed possible, but I believe it is it's more than that. Distortion measurements could have settled that. I am surprised a capable compony like Revel does not go there. Also, I will add that I don't necessarily "prefer" the sound of the A3, I am well aware of the somewhat laid back presentation, and indeed wish it will have more presence, but without the strain that comes with it.
Very helpful. One has to hope the listeners weren't all already very familiar with how the revels sounded in that room.perhaps MAGICO A3 VS. REVEL 228 BE conducted by harman where "All listeners rated Magico as their least favorite choice"
You are not their target market thenI'm looking at houses that don't cost that much!
