In what program?Select->Color->Eraser ought to do the trick
There is the "remove formatting" in the editor here - don't know if that would do the job.
If there is, it escapes me. There is little that makes sense about that tweeter.There must be some logic to their design, right? Or no?
The directivity you want in that case is what the design angle calls for to get coverage on that wall. Controlled directivity would make the design simpler.I just wonder what happens when you place several surround speakers in a row, like they do in a theater? There are at least 3, 4 or more surrounds per side. Do we want wide or narrow directivity then, for above 5 kHz?
Thanks for the review Amir. That's got to be a "poor" hasn't it?Step response demonstrates one of the faults with this measurement as it is highly sensitive to high frequency energy which this speaker lacks:
Just the text tools in ASRIn what program?
Let's find out:There is the "remove formatting" in the editor here - don't know if that would do the job.
Reserved for @RickS to kindly post the specs.
Frequency response (±3 dB), Hz 90 – 20000 Frequency range (-10 dB), Hz 80 – 22000 Max continuous SPL**, dB 115,5 Sensitivity (1W/1m, half-space)*, dB 94 High-frequency driver 0,75-inch (1,5-inch voice coil) titanium dome Low/Mid-frequency woofer 6-inch (1,75-inch voice coil) Coverage 60°-90° H / +5 -35° V coverage control HF horn vertical axis tilted 15° down Nominal impedance, Ohm 4 (versions available) Power rating***, W 150 Mounting VESA 100 x 100, 4 x M5 side points for specially designed mounting, removable magnet grill Connectors Banana terminals Dimension (W x H x D), mm 280 x 400 х 125 (w/ grill)
280 x 400 x 100 (w/o grill)Net weight, kg 6
I think thats because of their costExpensive & generally under par, results in less than stellar vote, albeit surprised most people went straight to the worst possible vote.
Ar least they angle the tweeter. However the narrow dispersion is still bad for bigger home cinemas with multiple rows. For smaller home cinemas the high output is not really needed. Hm.If there is, it escapes me. There is little that makes sense about that tweeter.
LOL. Well, I imagine the people who buy these things aren't too concerned about high quality sound anyway; reflecting on measured performance and price. The manufacturer even provides measurements. These are, essentially, in-wall speakers. It's beyond me.From view and also from hearing?
The Step response is the integral of the impulse response and therefore emphasises low frequency energy. The LF response is rather hard to see on the IR since it has a low amplitude but extends for a very long time (depending on the bass corner frequency and sharpness). the step response makes it easier to see the LF. At least we can judge the phase response from it which is not possible from the 2034 graphs.Step response demonstrates one of the faults with this measurement as it is highly sensitive to high frequency energy which this speaker lacks:
??? I was making a point about high frequency response:The Step response is the integral of the impulse response and therefore emphasises low frequency energy. The LF response is rather hard to see on the IR since it has a low amplitude but extends for a very long time (depending on the bass corner frequency and sharpness). the step response makes it easier to see the LF. At least we can judge the phase response from it which is not possible from the 2034 graphs.
Research into phase distortion at best shows that it can be audible in certain situations. But no research exists to show any kind of preference. What I am doing here is writing a review to help people decide if they should or should not buy a speaker. That story is told instantly with frequency response measurements:I'd like to persuade you that step responses are valuable though. Erin, Stereophile and SoundandRecording reviews also do step responses, and I devour them all. The latter two also measure phase or group delay. Companies like Genelec and Neumann and many others are heeding research that shows our sensitivity to group delay, and make DSP active speakers with Extended Phase Linearity, Automatic Monitor Alignment, Compensated Phase Response and Phase Correction. The result is to improve phase linearity. When you have both linear amplitude-freq response and linear phase-freq response, you then get great step response, like the Neumann KH150 and many others.
I also have a hatchback and just used it this way to transport some huge PA speakers. How does a bookshelf make sense here if the tweeter is facing behind you?2 door Hatchback with folding seats to make a flat floor shelf.
Absolutely. I do think frequency response tells most of the story, but it doesn't tell all of it.Even if the speaker had perfect phase response, it would not matter in the face of above measurement.
Thank you. Please feel free to bombard away.As to others posting them, I could bombard you with countless graphs. Klippel generates them all by default.
It's for bumping 80s music in the neighborhood, its a classic car (1984 Toyota Supra). I also have front speakers.I also have a hatchback and just used it this way to transport some huge PA speakers. How does a bookshelf make sense here if the tweeter is facing behind you?
