MAG Theatron S6 Surround Speaker Review
Rate this speaker:
    Votes: 87 75.0%
    Votes: 28 24.1%
    Votes: 1 0.9%
    Votes: 0 0.0%
This is a review and detailed measurements of the MAG Theatron S6 home theater surround speaker. It was kindly drop shipped by a member and costs US $944 each.
This is a very compact speaker with super solid enclosure. So much so that the company ships it (and the M-12C I tested) come with no packing material! Speaker's normal configuration is with the tweeter below woofer and that is how I measured it (forgot to take its picture the same way). The waveguide is supposed to be asymmetrical, biased lower, to eliminate the need to tilt the speaker down (which would be inconvenient in in-wall applications). Connectors are commercial types with phoenix connectors and such.
Let's put it on our Klippel Near-field Scanner (NFS) and see how it performs (in free standing form). FYI company provides measurements that correlate well with him.
MAG S-6 Surround Speaker Measurements
As usual, we start with our CTA-2034 anechoic series of speaker frequency response measurements:
Mag S6 Home Theater Surround speaker Anechoic CEA2034 Frequency Response.png
Story kind of starts OK in bass but roughness ensues followed by very uneven response from 1 to 3 kHz, followed by a large droop above 6 kHz. You don't need my expensive measurement system to see these as simple near-field measurements quickly show the same things:
Sensitivity is one of the marquee features of this speaker brand and it delivers to the tune of 93 to 94 dBSPL (average for speakers tested is around 86 dBSPL). This should reduce the need for amplification power although once you apply EQ to flatten the response, some of this advantage will be reduced.
As noted on the graph, directivity has problems which we see in early window response and later, in specific plots:
Mag S6 Home Theater Surround speaker early window reflections Anechoic CEA2034 Frequency Respo...png
Resulting in predicted in-room response which assuredly will be colored:
Mag S6 Home Theater Surround speaker predicted in-room CEA2034 Frequency Response.png
Beamwidth measurement shows clearly what we are facing as far as directivity:
One usually associates use of horn/waveguide as an attempt at controlled directivity but there is no hint of that here. What there is, above 5 kHz, is very narrow making it less of a fit for surround duty where the listener angle may be acute. Our heatmap tells the same story:
We see those whisps which tend to implicate diffraction issues due to many sharp corners around drivers and enclosure itself.
Vertical directivity is usually bad in 2-way speakers so we can't complain too much about this one:
I ran sweeps at a number of SPL levels and stopped when I could audibly hear the speaker complaining (101 dBSPL):
If distortion remained proportional to the SPL, the graphs would all be on top of each other. Non-linear nature of speaker distortion means that distortion rises faster than level as we get closer to its limits. This presentation is new so we need to build a library of them to have a reference. For now, I declare 91 dBSPL still good enough as the gap is small. It is bothersome to see the broad distortion across the full spectrum though. Here is a more detailed break down:
Mag S6 Home Theater Surround speaker THD Distortion percentage measurement.png
Be careful when interpreting absolute distortion levels as the frequency response is not flat:
Impedance is on the low side but not very problematic:
Waterfall shows a number of resonances:
Step response demonstrates one of the faults with this measurement as it is highly sensitive to high frequency energy which this speaker lacks:
I was originally going to listen to this speaker and create EQ. But then decided there is little point to that. We know that its response is poor and could highly benefit from being flattened. You don't need me to confirm that.
Two things rule in commercial sound: reliability and ability to play loud. Both are required for live events. Fidelity just needs to be good enough. MAG speakers completely fall inline with that, providing very high sensitivity and presumably good reliability. Refinement is not in the vocabulary of the design. While companies like JBL have done well in blending these two factors, such is not here at all, despite the brands' targeting of home theater. Seeing how these problems show up in company's own measurements, I am surprised they did not put more attention on fixing them. I mean what is the value of that treble shelf? Clearly a design flaw that wouldn't help anyone in any situation.
I should say I admire the company at least providing the measurements. Anyone schooled on my our speaker measurements, should be able to read them and realize that they are a poor choice for high fidelity applications.
EQ should help fix some of the issues here but not things like directivity. Company amplifiers have DSP and the manual provides a recording sheet to specify which is nice.
Overall, I can't recommend the MAG S-6 Surround Speaker. In our small spaces, we don't benefit much from high sensitivity. Nor is reliability that big of a factor as home theaters do not get many hours of use. We need a refined design where we put the finishing touches on with DSP. Not total redesign.
Reserved for @RickS to kindly post the specs.
Frequency response (±3 dB), Hz90 – 20000
Frequency range (-10 dB), Hz80 – 22000
Max continuous SPL**, dB115,5
Sensitivity (1W/1m, half-space)*, dB94
High-frequency driver0,75-inch (1,5-inch voice coil) titanium dome
Low/Mid-frequency woofer6-inch (1,75-inch voice coil)
Coverage60°-90° H / +5 -35° V coverage control HF horn vertical axis tilted 15° down
Nominal impedance, Ohm4 (versions available)
Power rating***, W150
MountingVESA 100 x 100, 4 x M5 side points for specially designed mounting, removable magnet grill
ConnectorsBanana terminals
Dimension (W x H x D), mm280 x 400 х 125 (w/ grill)
280 x 400 x 100 (w/o grill)
Net weight, kg6
Just get a Neumann KH120II or KH80 or even a Kali LP-6v2 and get better performance and looks all at a lower cost!
I think there is no reason ANYBODY should get one of these unless you were a time traveler going back to the 1980s.
Measured performance aside, these are home theater speakers that are intended to be concealed from view.
Matching sound power DI and early reflection DI should lend well to equalization in theory. The crux seems to be the distortion levels. I would expect a speaker of this category to make up for poor magnitude response with low distortion figures, but that’s not the case here.
It appears to blend the worst aspects of commercial and residential loudspeakers together.
Wow, still looking for an affordable 90db efficient bookshelf that measure well......for my car and parties.
For an home cinema speaker that is designed for high SPL and still does not reach reference level (105db at listening position) at reasonable distortion, a really bad speaker
I bet PT Barnum would happily sell these speakers if he were alive today,
I was initially thinking "Well, it's a surround, even if the response is jacked up, just means we won't be getting the highest fidelity on those 'spaceship flyovers' so no big deal." Then I saw the price was $944 each! Maybe if you are using them in a small commercial movie theater and need something bullet proof, maybe if you can't find anything cheaper with more fidelity, then maybe, just maybe, these are an acceptable ticket. But in a home theater? Playing 1-3 movies at most a week? In a smaller room for 5-10 people at most? Oh, hell no!
As always thanks for the very fine review, Amir.
I'm not sure, but I think I saw in a presentation from a distributor that the side surrounds are designed to be positioned higher on the side walls so that if there are several seats in a row, the middle seats still get enough direct sound. The vertical polar plot confirms that the listener is better positioned below the tweeter. The remaining measurement results are not very convincing considering the price, as was the case with the m12-c.
Back to the travel board.
Thanks for the review. First of all, I completely agree that this speaker has no place in a home environment.
I also hate the look and FR of this speaker, I would never buy it.
I just wonder what happens when you place several surround speakers in a row, like they do in a theater? There are at least 3, 4 or more surrounds per side. Do we want wide or narrow directivity then, for above 5 kHz?
There must be some logic to their design, right? Or no?
