MAG Theatron M12-C Speaker Review
Rate this speaker:
    Votes: 115 65.7%
    Votes: 52 29.7%
    Votes: 5 2.9%
    Votes: 3 1.7%
This is a review, listening tests, EQ and detailed measurements of the MAG Theatron M12-C center speaker. It was kindly drop shipped to me by a member and costs US $2,299.
As you probably can tell, this is a very large speaker. I can imagine it has to be mounted behind a projection screen. The woofer is inset, likely as an attempt to "time align" it with the very deep tweeter (or is it to control its directivity?). Oddly the speaker terminals are on top and are the screw kind. Don't usually see that for speakers aimed for home applications.
Here are the specs:
MAG Theatron M12-C Speaker Measurements
Let's start with our anechoic measurements performed using Klippel Near-field Scanner:
MAG Theatron M12-C Center Home Theater Horn Surround anechoic frequency response measurement.png
We see a rather rough response from the woofer and wavy one from tweeter. This is also a large discontinuity in the directivity around 700 Hz. We can get clues as to source of these problems by measuring each driver near-field:
MAG Theatron M12-C Center Home Theater Horn Surround driver frequency response measurement.png
Is that edge diffraction starting at 800 Hz and going past 1 kHz? Tweeter response is uneven as we have seen in our anechoic far field measurements. And ends in sharp resonance. Put another way, simple, non-anechoic measurements would have shown the issues here and clearly so in just a couple of minutes.
Back to the anechoic measurements, we see very high sensitivity of 95 dB.
Despite deploying 12 inch woofer in a rather large enclosure, bass extension is rather poor. Response starts to drop off 120 Hz with 50 Hz for F10. This is kind of bookshelf speaker response.
Early window response is some of the worst I have seen:
MAG Theatron M12-C Center Home Theater Horn Surround early window frequency response measurement.png
But do note that flush mounting changes this some. Predicted in-room response, non-flush mount naturally doesn't look good:
MAG Theatron M12-C Center Home Theater Horn Surround predicted in-room frequency response meas...png
I was surprised at the very narrow directivity for a center speaker:
MAG Theatron M12-C Center Home Theater Horn Surround beam width horizontal measurement.png
MAG Theatron M12-C Center Home Theater Horn Surround directivity horizontal measurement.png
You better sit pretty far if you want to have sofa-wide even response. We also see what could be diffraction around 700 Hz yet again.
Vertical dispersion is usually not good in 2-way speakers and here, it is worse due to narrowing directivity:
MAG Theatron M12-C Center Home Theater Horn Surround directivity vertical measurement.png
The 12 inch driver allows quite high SPL levels. I only started to detect audible distortion at 106 dBSPL during sweeps (with hearing protection). Linearity is lost though pretty early on:
MAG Theatron M12-C Center Home Theater Horn Surround distortion vs level SPL comparison measur...png
In an ideal speaker, distortion would remain constant and all the lines would be on top of each other. While we could tolerate fair bit of distortion in bass, this speaker brings plenty of it from 700 Hz on.
MAG Theatron M12-C Center Home Theater Horn Surround distortion relative THD comparison measur...png
MAG Theatron M12-C Center Home Theater Horn Surround distortion THD comparison measurement.png
MAG Theatron M12-C Listening Tests and Equalization
Initial impression was that of upper bass warmth. But as soon as the first female vocal arrived, the sound was just odd to me. So decided to create some filters and boy was this a long journey:
The response is quite rough in bass so I focused only on larger variations in treble. Once there, overall response was more open without being too sharp. But lacked bass. With or without EQ, my deep bass tracks barely produced anything. And what it did produce was distorted to some extent. So I bumped up the response with that 80 Hz filter. That nicely evened out the response with EQ sounding quite a bit better than without.
Speaker was indeed sensitive. It delivered 10 dB better response than equiv. testing on other speakers with my amp. I still cranked it up. :) And then would be startled with some dynamics in the music. So the benefit of high sensitivity is there.
I tested the directivity at near field. Response does drop off rapidly with horizontal angle.
From my vantage point, this is a PA speaker with its proper application being larger spaces, no home listening spaces. Narrow directivity points to that as does high sensitivity. As with many PA devices, sensitivity is everything. Refinement only has to be adequate. We maybe have that. If this speaker was $800, we could stop here and say job is done but the price is home speaker category. Here, we expect at least some attention paid to obvious sources of distortion and acoustic faults. Thank heavens we have EQ so we can correct for half the problem.
I can't recommend the MAG Theatron M12-C center speaker. It is just too compromised as a design and especially for the price.
"rough and uneven" - sometimes the looks match the performance :)
It was mentioned the speaker was drop-shipped. Was this from the manufacturer?
I spotted some other defects in the finish.
I agree with Amir. PA speaker performance and looks/build, priced for home market. The only saving grace here is the sensitivity. Matched with large subwoofers you could build a very dynamic, large home cinema with them.
Good eye! I had not noticed that. Fortunately, pretty tight so don't think it impacted the measurements.
Who knows? Normally you don't give a horn with compression drivers its own chamber, so such a leak caused in this way could be problematic.
I also find the environment around the woofer problematic: numerous sources of reflections and edge diffraction. :facepalm:
That indeed is the source of many problems.
From what I recall, they don't say this is a compression driver. So I assume it has its own chamber with a traditional tweeter and waveguide. Otherwise, I agree it could have caused some problems.
Many thumbs up for testing a large speaker Amir. :D That in itself is the best thing about this test. This time a rather bad speaker but next time maybe you test a good large speaker. :)
The only good thing about the MAG Theatron M12-C is the high sensitivity. With the sacrifice that it does not go so far down in frequency to reach the high sensitivity. On the other hand, what does it matter when the speaker is otherwise not very good?
I have asked the question before - mostly out of curiosity - how many good full-range speakers (30Hz-F3, even FR, low distortion) with sensitivity above let's say 92 dB are there on the Hifi market? A handful?
One can conclude from Hofmann's Iron Law that such a loudspeaker would have to be huge, far too big and therefore too heavy for us to expect Amir to lift it onto the test platform. :eek:
You showed this at the beginning of the test report:
The company could just as easily have written "compression driver" there. :)
Probably so. Compromise then, let's say a speaker that goes down into the bass range like the MAG Theatron M12-C with the same sensitivity but with good FR. Also, as Amir wrote: Response starts to drop off 120 Hz with 50 Hz for F10,... is it really necessary to have such a large speaker as the MAG Theatron M12-C to achieve that with a sensitivity of 95 dB?
Edit:
By the way. Now I remember, a few days ago, there was a discussion, in the thread below, about the sensitivity aspect, with a manufacturer who really cares about making good speakers (with good FR among other things), #237-#238:
Wonder how it would measure in a baffle wall.
Treble would still be offcourse.
??? That reads just like a standard tweeter.
According to "1-inch (1,75 inch voice coil)" as mentioned in the data sheet, I can hardly come to any other conclusion than that compression is involved, can I? It would perhaps be something else if we were talking about a 1 inch voice coil.
In addition I would find a "normal" dome tweeter at least unusual for a speaker of this design.
I hope your back didn't give way, @amirm . Many thanks for the schlepp and the test. Too big for my living room anyway (and far too expensive).
:) It was just manageable with my lift to get it on and off Klippel. Being wide, it was pretty stable when using the dolly to move it.
It will be "fun" packing it back up!
I think it is unusual to NOT call it a compression driver if it indeed is one.
