Mackie SRM450 v1 - No audio output
beavernuggetz
Hello everyone,
I'm troubleshooting a friend's speaker which no longer produces sound.
Already checked/confirmed/ruled out:
The speaker itself has been tested and works.
There are no shorts (that I could spot with a DMM & thermal camera) on the board.
Please see attached schematics for additional information. Specifically, the last page shows where to check voltages.
+45/-45 volts at D56 are present.
+15/-15 volts at Q34/Q35 are there too.
Anomalies:
+80/-80 at D55: reads as +96/-96 volts instead.
R254/R255 have +15/-15 across but are reaching +50 degrees Celsius when checked with a thermal camera (this could be normal, I suppose)
Any suggestions on what could be checked next would be greatly appreciated. I own the necessary equipment to troubleshoot, but simply lack in-depth knowledge on how to troubleshoot something like this.
Thanks again for any help.
PS: @AnalogSteph, if you are still around, thanks for helping me before and perhaps you'd be kind enough to take a look at this one too.
  • Mackie-SRM450 actspk.pdf
Hello everyone,
Anomalies:
I haven't found D55, but the V2 voltage is +/- 95V as shown in the power supply schematic.
Yep, these are 2W resistors for a reason.
Could be that both power amps are muted, for a reason. They have a mute input.
LTig, thank you for taking the time to go over the schematics and pointing me to the proper voltages.
Pardon my ignorance, had never heard about power amps and muting.
How would someone troubleshoot to confirm that to be the problem?
Looking at the board, I see 1 or maybe 2 components labelled: JRC4560 - Dual Operational Amplifier
I presume this is the part in question here.
Again, than you for your input and time.
What type of DMM do you have? What are the specs regarding AC voltage measuring?
Good one. You can feed a sinus test signal like 500 Hz (there are apps which generate test signals) to the input and follow it through the different stages with the Fluke. DISCONNECT THE DRIVERS BEFOREHAND!
Appreciate the suggestion. To be honest, that's where I run into trouble due to lack of proper knowledge.
I understand the hot/cold side of the PCB; no problem.
The issue for me is not knowing much about the different stages which you mentioned as well as which components to probe and where.
Can an oscilloscope achieve the same as the DMM? I know enough to realize not to probe the hot side with this tool.
A scope would be perfect. But without knowing how to read and understand the schematics (and find the points to test on the PCB) further probing is almost impossible.
My approach would be to feed a test signal and check the output of each opamp with a scope. There is a lot of them, each triangle in the schematics is one.
Thank you so much for your suggestion. I do see approximately 20 small chips; will look at their respective datasheets to figure out which pins to probe.
Will come back here with an update if any relevant discoveries are found.
Again, your help is much appreciated.
In cases like this you need to identify and follow the signal path and look for suitable points to split it or monitor the signal.
What I noticed is that this one has a green Signal LED, alongside a red PEAK indicator. If you cannot get the former lit up, for example, you have already narrowed down the problem area substantially, and could continue checking at TP2 and TP1.
As an aside, use all your senses in general. The presence of hiss in the tweeter (or lack thereof) could tell you a fair bit already.
Here is an update.
Tested all opamps (close to 20) and they are all getting the +/- 15 volts: NJM4560M & NJM2068.
Same goes for both LM339 & SSM2164.
All measurements were done with reference to ground.
Next, I'll try to understand how to feed a test signal and follow the path.
Thank you all for sharing your knowledge; I shall continue trying to revive this thing.
I may have found something.
There are approximately 12 electrolytic capacitors marked 47µf 25v which have an ESR of 2.2 Ohms which is too high. Tested a few others I had laying around and they are reading 0.2 which is night and day difference. Kind of odd that all would go bad at the same time.
@AnalogSteph and or @LTig, could this be related?
Are those 47µf 25v caps in the signal path (coupling caps for the audio signal) or at the supply voltages? Anyway this would explain hum or not enough bass but not no output at all.
These are in the signal path. I'll get clarification from my friend as to what the exact symptoms are with this speaker.
Hello, it's been a while and finally had time to work on this amp again.
Looking at the amp with a thermal camera, there were 2 chips which were not even warm at all so replaced them as follows.
LM339D via direct replacement & NJM4560 with NJM4580.
After replacing these, the new chips lit up with some heat, the amp's front LEDs came on fully, but one problem remains.
The audio is very faint and can only be heard (barely) with the volume pot turned all the way up.
Could this be an issue with the pot itself? It feels wobbly and not very secured although the solder points are fine.
Measured the resistance (on the board) between the 3 legs of the pot's which actually connect to something and got reading about 24K between the 2 outside legs although it takes some time to settle; starts at around 21K and keeps going up until it stops at 24.
Found the problem! It's the volume potentiometer.
Touched one of its contact points with a metal pick and the audio gets restored to normal volume.
Anyone know what the actual value of these pots are supposed to be?
I'm seeing values in 10K, 50K, 100K but nothing close to the 24K this one is measuring at.
According to the schematics it should be R265B, which is 10 k.
Thank you very much; the existing one also shows the same value after removing it from the board so will order accordingly. Appreciate all your help!
I'll come back with an update once the replacement part has been found and installed.
For curiosity's sake, I'd attempt to test the comparator and opamp you replaced on a breadboard or something. I won't be entirely surprised if they turn out to be working fine, meaning the actual problem was bad solder joints. The speaker seems to have been through some things, so finding some of those wouldn't surprise me in the least.
