Wrote a really long message, then realized it was too long with lots of info nobody will care about. Short version: I need new speakers for use with myc computer for general listening--no music production. Low to moderate volume, near field with listening distance of 36-42 inches. Speakers 4.5-5 feet apart due to multiple monitors. Small, live room with no treatment and none or very little foreseen in the future. Bass is good but accurate, smooth (no raspiness, "glare," or sibilance) midrange and treble, followed by soundstage and imaging are all more important to me. Plan to EQ when I can get a measurement mic--hopefully in a few months. In home or even in-hotel-room auditions are impossible. The best I might manage is to listen in a noisy shop for 2-3 minutes with the speakers on a counter.
I live in Cambodia where almost nothing is available, but I can also buy in Thailand in a couple of months when I go there. Prices on most speakers are very high, so the ones I'm listing are literally the only choices within my budget (about $425). Trust me, I have done a LOT of research over the past year since I was stuck here due to COVID, so you will just be wasting your time to suggest anything else
Here are my options (prices per pair):
In Cambodia:
Edifier S2000 MKIII: $300
Yamaha HS5: $380 (have not verified they are still in stock)
In Thailand:
M-Audio BX5 D3 $270
Mackie MR524: $420
AudioEngine A5: $420
JBL Stage A130 (the nice two tone ones) + Aiyima A07: $335
Wharfedale Diamond 12.0 + Aiyima A07: $288
Wharfedale Diamond 12.1 + Aiyima A07: $425
Genelec 8010a: $660
I've regretfully pretty much eliminated the Yamahas from contention after reading both objective and subjective reviews. I can't see a compelling reason to favor the A5 over the MR524 when I value SQ over the additional features, and the JBLs worry me due to the significantly poorer results Erin measured compare to Amir. The Genelecs are included for comparison but definitely out of my budget, especially considering they will almost certainly also require a Presonus Eris Sub8 for an additional $300, which I'd have to figure out how to get here from Thailand. (The LSR310S is $600, so no way.)
The Edifiers are really big for desktop usage, especially depth, and the Wharfedale 12.1 are pushing it. I would not have even known about the Mackie or M-Audio speakers if not for your posts, so thanks very much. The Wharfedale 12.0 + A07 is really intriguing but no measurements available, which also means no EQ settings from
@Maiky76.
So if you or anyone else who has heard at least two of these has any opinions or additional info to share, I'd appreciate it. (And yes, that is the short version of my post.)
