That won't take it to the "next level"... like most DAC's the analog audio output will be audibly indistinguishable from the other, unless the Moon is really poor or broken.I may take it to the next level using USB-out to a Chord DAC… currently it’s optical out to a Moon 300D .
The late 2012 Mini is . . . currently it’s optical out
Hence the potential move to a Chord DAC & FGPA..Which on a Mac, will limit you to 96 KHz. If you're paying Qobuz for 192 KHz audio, you need to up your game, hardware-wise.
A/B testing CD out to the Moon DAC against the streamed output.. nothing in it.Hello and welcome to ASR.
JSmith
Will this difference be distinguishable?Which on a Mac, will limit you to 96 KHz. If you're paying Qobuz for 192 KHz audio, you need to up your game, hardware-wise.
No.Will this difference be distinguishable?
TBH - something to keep in mind if one was looking at purchasing high res downloads to not buy anything higher than 96. Then again, many ASR folks say "nobody can tell in blind ABX from 16/44"
Quite agree… my first DAC that still sees use is a CAL Sigma II that’s limited to 16/44.1. The biggest improvement to that was a fresh JJ 12Ax7 valve…TBH - something to keep in mind if one was looking at purchasing high res downloads to not buy anything higher than 96. Then again, many ASR folks say "nobody can tell in blind ABX from 16/44"
Which will make absolutely zero difference - except perhaps to pass more ultrasonic noise through to the output.Which on a Mac, will limit you to 96 KHz. If you're paying Qobuz for 192 KHz audio, you need to up your game, hardware-wise.
I thought 24/96kHz allows the most realistic dynamic range of 144dB vs "merely" 96dB of 14/44?Which will make absolutely zero difference - except perhaps to pass more ultrasonic noise through to the output.
We are for now, Not addressing that many residential speakers would self destruct at 144dB LOL
In systems that are capable of high, relatively clean SPL, the 24/96 would be the optimum format to reproduce the MOST true to life, realistic transientsNot to mention your eardrums being shredded.
In the post you quoted, I was saying that 96khz up to 192 will make no difference.
But in reality - 16/44.1 is indistinguishable from higher bit rates.
24/192 Music Downloads are Very Silly Indeed
people.xiph.org
???In systems that are capable of high, relatively clean SPL, the 24/96 would be the optimum format to reproduce the MOST true to life, realistic transients
Currently, a Magnum Dynalab MD208 receiver & UK-built Monitor Audio SE 25th Anniversary towers. 12GA speaker cables.What’s downstream of the DAC?
You can’t tell the difference between a 96dB peak vs 144dB????
Not audibly.
They are dynamic ranges - not peaks.You can’t tell the difference between a 96dB peak vs 144dB?
As I said 24/96 is the point of diminishing returns on resolution as far as human perception meeting real music reproductionEverything we have argued, discussed, and dissected here says there will be no noticeable difference. Will the OP feel better about it? I can't answer that as I'm not him. I don't stream, anything, so I have nothing to compare it to.
After testing my own CD rips a long time ago, I came to a rather rapid subjective conclusion that 24/48 FLAC files were good enough—for me—for general listening pleasure. So I rip to AIFF to archive and convert to FLAC for playback compatibility. The only time I have to put up with sample rate conversion is when I use my run-of-the-mill PowerBeats wireless IEMs—but that's not critical listening so, c'est la vie.
