Deleted member 51459
Guest
- Thread Starter
- #41
other speakers will be made better...If the problem is room and speaker placement - why do you think changing the speakers (and not those things) are going to make it better?
so they will sound better in my desk i guess ? i am guessing i am noob newbie.
Revel i cant get in my country,
So i am again considering any of these .
Please tell me about these -
I am currently considering Focal kanta 1,sopra 1, diablo utopia,
bowers and wilkinsons 805 d4,
kef reference 1 meta, which one do you like the most. ?
Which is the best the most amazing sound quality reproducing speaker compared to my chinese kef .
All sensible, but you need to read the other half dozen threads to understand how we reached this point - everything you've said has been covered, multiple times.
Our best approach at the moment is to try to make what is there work as well as possible. At the moment Bladest is wanting to replace the speakers with something more expensive. Quite frankly, I'm happy for him to do that, or take up your suggestions, or keep what he has: but none of those options are any good until he has a grip on what is wrong today, with his current stuff.
While I don't like working from videos, it appears that he has bad bass and that is to do with the desk and placement. Dirac is just modifying the bass output of the desk in effect.
Please tell me your favourites
Which is the best the most amazing sound quality reproducing speaker compared to my chinese kef ?
Who is the best rock solid reference sound speaker from these? all expensive stuff smells like money to me $$$$.
i cant return the nad its written as company accountant purchase first of all, and 2nd it was special order for me people doesnt do returns for such things at least where i am dealership try to extract from me maximum profit with 000 returns happy days for them.
Genelec no dealership, i like nad m33 its cool unit it have some issues like power on and off missing from the app i dont like
no way to place speakers other place, i have door on my left side, i cant put speaker there with or without stand door wont be able to be opened.
thats best i can do.
i improved the space a lot i removed a lot of the things from my desk... in order to make place for nad m33 and speakers ...
OK, I broke the habits of a lifetime and listened to your video.
The sound is nowhere near as bad as I expected! It's not my kind of music, but hardly matters. I'll put the treble rolloff down to the mic for now, that can be improved with full DIrac if it's down in the room. Vocals are clear, I can hear every word. Treble sounds OK. In other words, the speakers are plenty good enough there.
Bass - ugh. It does sound a bit better without the Dirac to me.
Does that concur with what you are hearing in the room?
If that's right then changing speakers without other changes won't help much.
Can you put the sub back, crossover at the highest frequency available to you and make another video?
Have you tried the books under the speakers thing I suggested earlier?
I'm thinking that the R3s are exciting the desk a lot more than the Muso did and that's a big chunk of your problem.
Muso was very dynamic and exiting all in one box.
without missing anything.... i have no books where i am so i cant test or try test i read online books these days only no physical books sorry. But please tell me your favourites so i can pre order next speakers.
My sub is junk.
what kinda of song and music you want to hear, can you advice?
The video won't help me. it might help other people. I am concerned with the nature of what you are hearing, not what the microphone gives.
I'll try again. I know you are trying hard to fix this, but I can't get from your posts much that helps my way of thinking about this.
What is the source you are listening to? If you have plugged an analogue cable from the computer to the amp, we have to go through the computer audio setup from scratch as well. I don't want to go there.
Turn Dirac OFF for now. It isn't going to help you yet. Take the sub out of the system. It isn't going to help you yet. It sounds like you have tried that and still get bad sound, that is our starting point.
What cable are you using for the speakers? Can you move things around to do the fourth thing I asked for?
For "sixthly" I don't just want you to listen "in mono". I want you to listen to just one of the speakers. That means in mono, but also with the balance adjusted so only one speaker is making a sound. If that sounds better in terms of balance (obviously you don't get a stereo effect from one speaker) then we know that the problem is with the position of your desk and speakers. If it's still bad to you, then maybe you do have the wrong speakers.
Next - I want you to try to describe the sound. Your usual word "junk" tells me precisely nothing. Is the sound boomy, too bright, confused so you can't hear the words, does it sound like one speaker is much louder than the other - what are you hearing? Without some sort of description it's hard to go further. I want to know something about your expectations. As far as I know, your Muso would have had slightly boosted bass and treble but the KEFs shouldn't sound as lousy as you are implying. Something else is up here, and I'm thinking we could recommend speakers to you all day and expect the same result.
The R3 is a perfectly reasonable speaker. While you may prefer something different, they should not be "junk". So maybe the problem is that you are expecting a totally different sound to the "reference" you first asked for.
With the dealers, I'm NOT asking you to go and buy something from them. You go there, ask to listen to some system, see what you like of what they do have. Then you politely say "thank you, I'll think about it for a bit" and leave again. If everything you hear sounds bad to you, something else is up. Turn what they do back onto them: if they can't demo what you want to hear, hear what they want to demo, and use that in your search. If you get to hear something good, then great. If you need to drive over the border for a day to visit a dealer in a different country and exploit them, in this case do it - if you find a good dealer outside of Bulgaria that has equipment you would consider on demo, then it may be worth spending the money with them to fix this.
As you said, you have to wait for two years to claim the tax anyway and it might get rejected. If you want good music in your basement it's worth the money and time - or if it isn't then buy something cheap and save for that move.
One more question. Your car systems, do they have equalisers and such? Can you let us know if you are running them with bass or treble. turned up high? That will help with any recommendations we give.
You can ask about different speakers all day. Do you think, after you've bought an amp and speakers sight unseen based on advice, that I'm going to risk any more of your money without knowing a lot more about what you are hearing and doing? I'm happy to stand behind the M33, it is a good platform for you to work from unless you can get to hear active alternatives that you are prepared to buy. The problem is somewhere else.
I replied many times about this here is it again, it doesnt matter if i am listening flac,mp3 or something else i listen 2 sources , 1st my computer connected with digital cable to nad m33,
2nd source my phone airplay same songs same quality........ mp3 or flac...
it was these sources i have listened to naim muso as well , the source is not the problem.
Of course issue is the position with the speaker if i got space i will get stands and it will be little bit improvet but not major.
My car and every single system i own / have
is running at 0 bass
0 treble... no dsp and nothing else turned to the maximum.
or above the balanced treshold...
just as example muso have much better vocals and everything...
with kef everything is much worse...
at least in their current placement withor without dirac...
Difference between my jvc integrated amp and nad m33 is kinda 0000 most people cannot hear it.
Cables i use are brand new forgot the brand from Europe.
so i tried mono and listening to one of the speakers only , not good for me.
Currently i am working everyday and i cant go to dealers outside my country.
I have a lot of things to pay...
i dont USE anywhere EQ.so i have EQ but it stays OFF, in every single car i got.
their eq is simular to crappy dirac mic measures and tunes for you.... so i keep it off.
In terms of quality i can say, that the speakers it self sound bad, terrible, they sound like 5$ my headphone or even worse... lacking details, lacking everything........
