Audiochap786
- Joined
- Nov 15, 2022
- Messages
- 18
- Likes
- 3
Does RP calibrate 2x subwoofers as one, or does it do it independently?
Thanks
Thanks
According to model 60 manual subwoofers are handled in stereo and separate from the LFE. There’s no more detail.Does RP calibrate 2x subwoofers as one, or does it do it independently?
Thanks
The OP was asking if the subwoofers were calibrated individually. The manual calls them stereo subwoofers. This may imply they are not calibrated individually but the whole signal is. As LFE is handled by a separate sub the subs and front are basically fed by a stereo active crossover.View attachment 244228
You can have up to 4 discrete subwoofers depending on how you choose to configure the system. This image shows a standard 5.1 configuration. (Highlighted)
I have not set one up other than as an LFE configuration.If you know different maybe you can point us to the source so that we can investigate further.
Can you see the changes made by Room Perfect?I have not set one up other than as an LFE configuration.
My understanding is that if you assign alternative sub outs, they are handled discretely, but I have not verified this. I just shot a note to my Lyngdorf rep for clarification.
I am not sure what you are asking. See how?Can you see the changes made by Room Perfect?
My understanding of the LFE only mode means no bass management. The fronts receive the full signal and the single sub only receives the LFE signal. Am I correct?
Most DSP based automated equalisers tell you what the automated system did after they applied the corrections.I am not sure what you are asking. See how?
Thank you. The user manual is not clear, for me.No, that is not correct. LFE absolutely has bass management. During speaker setup you enter the capabilities of each speaker (LF cutoff frequency) and the processor will steer the signal as appropriate to the subwoofer(s).
You mean like the Audyssey idealized plot that they show you? No, they do not.Most DSP based automated equalisers tell you what the automated system did after they applied the corrections.
You are correct, the manual is not clear on several things. Luckily the guided setup prevents you from most user errors. The folks who designed the software are better than the folks who wrote the manual.Thank you. The user manual is not clear, for me.
My question, and I believe OP is asking the same is what EQ applied on each subwoofer channel? For instance on Trinnov, subwoofers are treated as part of the overall signal. There is no individual sub EQ. All subs receive the same signal. This is why people use an external miniDSP to EQ the subwoofers outside of that AVP. Trinnov admits that and promises the new version will handle subs “discreetly.” Even though any output could always could have fed multiple subs. The word “discreetly” is not clear enough to explain the process. Devil is in the detailYou can have up to 5 discrete subwoofer channels. LFE + four assigned. As long as you input their own distances and amp delay, they will each be handled discretely.
According to my rep, as long as you set up each subwoofer with its discreet channel and distance setting, Room Perfect will calibrate (equalize) each bass channel separately just as it does every other channel.My question, and I believe OP is asking the same is what EQ applied on each subwoofer channel? For instance on Trinnov, subwoofers are treated as part of the overall signal. There is no individual sub EQ. All subs receive the same signal. This is why people use an external miniDSP to EQ the subwoofers outside of that AVP. Trinnov admits that and promises the new version will handle subs “discreetly.” Even though any output could always could have fed multiple subs. The word “discreetly” is not clear enough to explain the process. Devil is in the detail
Thank you. You have been most helpful.According to my rep, as long as you set up each subwoofer with its discreet channel and distance setting, Room Perfect will calibrate (equalize) each bass channel separately just as it does every other channel.
For my two-channel system I use a 2.2 configuration. For home theaters, I use an XX.1.XX configuration. In my personal HT, it is a 5.1 system and I am considering making it a 5.1.2.Thread starter here... Have I been led down a rabbit hole, that a amplifier must have independent sub outs to sound best?
Happy to help.Thanks
Which amplifier are you using, out of curiosity
