No conflict. A few people have offered to test their Mac gear but none came through at the end. I have also had offers of their older products but they weighed a ton so I passed.Is there a reason why we haven't we seen a single McIntosh (home) component tested? Has no one ever offered to send you one? Or is there some conflict of interest?
Curious as to what you do for video upgrades. Do you use a separate video processor like lumagen/MadVR?
Or can you provide examples where you have upgraded the video portion whole still using MP 40?
Yes on Lumagen/MadVR if needed especially for projectors.Can you give an example of such a device (outboard HDMI switch)?
Thanks
You're more than welcome to purchase an overpriced piece of McIntosh gear and submit it for testing. I think that most people here realize that Mac is overpriced and then don't buy their gear.
I have some 20+ year old Mac speakers. Too heavy to ship. I know they'll perform poorly.
That's interesting.Linearity also shows a strange negative tilt at lower levels
Well, it doesn't seem too bad, objectively, if you compare with similar products.this product is getting a way better review than it deserves
Audio ADC/DAC have always been designed for an usable upper frequency limit of 20 kHz. For fs = 44.1 kHz and for ADC, that leaves a zone of ~2 kHz (upper usable frequency to fs/2) for the analog anti-alias filter work with....
The LPF with 44.1kHz white noise data is -14.2dB at FS/2 and that's "good"? Right.
OOps. I did but forgot to post it. Review updated with it:Didn't you measure dynamic range ?
No it isn't:It's patently clear in my opinion, that this product is getting a way better review than it deserves, solely due to the name on the front.
It is on top-3 best AV products tested and one channel ties for best there is.
I would expect Mac gear to perform well these days, at least the solid state electronics, but I would not expect their old speakers to do well, and all their gear is still overpriced.
The Mx100 which is based on a D&M platform is pretty good
And the automotive audio McIntosh amp tested here was pretty impressive too.
I would love to discuss this with him. I'd be curious how he has come to that conclusion.
I am not sure how running RoomPerfect in the McIntosh based equipment differs from using it in Steinway Lyngdorf or Lyngdorf gear, but it is surprisingly simple. It can take as little as 15 minutes or longer depending on the room. The procedure is to set the mic at the primary listening position for an initial reading and you run the program... it will play its test tones through each speaker and then you randomly move the mic around the room changing the height and angle each time you run the test tones again. You continue to repeat this until the system has satisfactorily mapped the room. Depending on the room, this can take as little as four measurements or perhaps 8-10 for some rooms.
You then save the correction file and that is it... certainly not complicated.
The whole discussion was more of a small talk, while he was setting up Altitude at my place. If I remember correctly, customer [super VIP for them] wanted to have only blue VU meters so they opted for McIntosh Processor.
He was not complaining about the measurements as such, which I assume is pretty straightforward, but about how hard and time consuming is to get proper results, as Room Perfect is pretty automated and has only limited options for calibrator/end user to really influence the final result. So it ended with plebeian MiniDsp getting better results than Lyngdorf in managing multi-subs and helping Lyngdorf to sound acceptable for HT purposes. In his opinion it is more a lifestyle product for design conscious customers that works best in living rooms etc, but not for serious dedicated HT's.
True it is pretty looking and is absolutely automated, though we usually also go into the settings and massage it a bit.In his opinion it is more a lifestyle product for design conscious customers that works best in living rooms etc, but not for serious dedicated HT's.
Those special functions impact performance. These products have a chain of signal processing components. Each work independently which means each needs its own digital headroom to avoid overflow. The net result is that you loose good bit of dynamic range relative to a simple DAC.Amir, you're just testing the left and right channel D/A converters in pass through. It's acting as a D/A converter with a variable output and it gets special treatment because it has a million other functions you didn't test??
It's patently clear in my opinion, that this product is getting a way better review than it deserves, solely due to the name on the front. If it was Arcam or NAD or Marantz, it would have been savaged.
