SuicideSquid
- Joined
- Jan 20, 2022
- Messages
- 1,157
- Likes
- 3,209
I know this review is primarily about audio, but three HDMI inputs on a flagship A/V pre/pro is simply unacceptable. Five seems to be the minimum with most having 6-7.
A five-figure price, but only three HDMI inputs?This is a review and detailed measurements of the Lyngdorf MP-40 version 2.1 12-channel Audio/Video Processor. It is on kind loan from a member and costs US $11,299.
Apologies for lousy beauty shot. I did not want to remove the protective plastics. I was very pleased to see a "real" volume control with flywheel momentum and very responsive input selection knob. A highly useful web interface is provided which I used to configure the unit. In addition to being an AV Processor, the MP-40 can also act as a USB DAC (a rarity in AV products) and supports Roon streaming over the network, both of which I tested below.
The unit is targeted at the Custom Integration (CI) channel as evidenced by extensive triggering functionality and such things as serial interface. Not many HDMI inputs are provided though.
Lyngdorf MP-40 2.1 AV Processor Measurements
Let's start by testing HDMI input and measuring noise+distortion:
Channel 2 has excellent performance ranking at the top of our SINAD tier. Sadly distortion is higher in Channel 1 (Left) bringing their average a couple of notches lower:
Bits should be bits and MP-40 shows this by having identical performance with both USB input and Streaming:
It is easier for me to test using USB input so that is what you will see in the rest of the tests. Output goes up to a healthy 8 volts:
Unlike some other AV products, the volume control does not change the gain structure. You just get less output voltage which is one expects. You can see that performance is maintained almost up to max output. We see that lower performing channel takes a hit at just 1.4 volt. Very strange.
Linearity also shows a strange negative tilt at lower levels:
IMD performance is very good by AV standards:
Here, we see an increase in distortion at around -8 dB which is likely due to 60 Hz component in this test. We see that increase in THD+N vs frequency:
For compatibility with stereophile testing, here is 50 Hz response into a very low load impedance:
Jitter performance is again good for an AV product:
I did not see a configurable filter but what is there is good:
It does droop a bit in frequency response though:
The build quality and feature set of MP-40 V2.1 is excellent. Measured performance seems very good, just stopping the best we have tested. I am wondering whether there are part variations that caused the one channel to underperform. One main feature, RoomPerfect EQ, was tested before and turns in excellent performance. So as a package, I expect this processor to perform quite well. Some of you may know that the company/its founder have funded Purifi amplifier companies. Seeing how they squeeze every bit of distortion and noise out of their products, I am hoping that the same gets done in their processors in the future.
I am going to put the Lyngdorf MP-40 V 2.1 on my recommended list.
With only 3 HDMI inputs, this AVP is virtually useless for most home theater owners... I'm currently using 5 inputs on my Denon AVR (HTPC, Apple TV, Sheild TV, Zidoo Z9X Pro, and Eversolo dmp-a6 connected via HDMI).
As a system designer in the CI world, I have not found the lack of HDMI inputs to be an issue. On most of our projects we use an outboard HDMI switch or matrix sending a parallel HDMI output to the AV processor exclusively for audio processing and avoid sending video to the processor entirely. This allows the audio portion of the system to remain installed and working for a number of years and allows the video portion to get updates as the technology evolves.I know this review is primarily about audio, but three HDMI inputs on a flagship A/V pre/pro is simply unacceptable. Five seems to be the minimum with most having 6-7.
Understanding why people spend money is an entire area of study in its own right.Don't understand why people pay this crazy money for av,performance is good but should be better for the price,ud get better performance for around £1000 for a good av with pre outs and £1200 for a external amp
If you really want 9.4.4 then Storm Audio or Trinnov are the way to go. That said, take a hard look at the 9 in that layout. There is precious little content that is beyond 7 primary speakers.I have considered Lyngdorf as one of the options.
Deal breaker for me was seriously limited channel count. 12 (or 16 for MP60) is not enough for the market segment it is supposed to serve.
9.4.4 seems tp be healthy minimum today for high performance cinemas with 1-2 rows,
yes, Iwith Trinnov I have 9.8.7 setup combined atmos/auro layout and going for front wides was at 60dg was audible improvement over 7.x.x.If you really want 9.4.4 then Storm Audio or Trinnov are the way to go. That said, take a hard look at the 9 in that layout. There is precious little content that is beyond 7 primary speakers.
www.audiosciencereview.com
Not only do I personally have an MP-40 in my home theater, I have designed systems where we have installed a few MP-40s and quite a number of MP 50s and MP-60s. They have been providing excellent audio performance and reliable audio processing over the years. By using the outboard HDMI switch, we can replace a compact lower cost video device and not have to rebuild a rack with each video upgrade.
I would love to discuss this with him. I'd be curious how he has come to that conclusion.My integrator was rating Lyngdorf (I assume in its McIntosh iteration) as hardest and most time consuming to tune properly. As you have experiemce with multiple DRC systems (I assume) - what would be your opinion on ease of use, if you want to do real fine tuning?
Somehow paradoxically for him most comfortable to work with was Trinnov. I can understand where he is coming from - also for me now it is much easier to adjust Trinnov than Audyssey via the Multeq-x …,
Curious as to what you do for video upgrades. Do you use a separate video processor like lumagen/MadVR?
Or can you provide examples where you have upgraded the video portion whole still using MP 40?
Can you give an example of such a device (outboard HDMI switch)?As a system designer in the CI world, I have not found the lack of HDMI inputs to be an issue. On most of our projects we use an outboard HDMI switch or matrix sending a parallel HDMI output to the AV processor exclusively for audio processing and avoid sending video to the processor entirely. This allows the audio portion of the system to remain installed and working for a number of years and allows the video portion to get updates as the technology evolves.
